On Apr 16, 8:39*pm, Tman wrote:
Dudley Henriques wrote: On Apr 15, 6:15 pm, "RST Engineering" wrote: YOu and I were taught by different people. *A checklist is just that ... a step by step list of todos so that you don't forget something. *It is very easy for the mind to go through a "familiar list" and be so rote that you really DID think you were on both mags when you were only on one. Jim The quickest thing that disqualified an applicant on any check flight I ever gave was the non-use or improper use of a checklist. Dudley Henriques An admittedly small sample, but I've actually never seen a professional pilot do a walkaround on an airplane with a checklist in hand. *Not even when I'm watching the A320 FO do a walkaround. *I'm sure it happens though. *I've only seen students and pilots on a checkride do that. *My instructor told me to "have the checklist in your hand but you don't really need to look at it" -- for the preflight. So -- Dudley and others. *Let's be clear here as I am curious. *Which phases of flight do you use the checklist for? _ preflight planning _ drive out to the airport _ preflight examination _ getting in and getting fastened _ engine start and post-start _ pre-taxi _ runup _ pre-takeoff _ climbout _ approaching a fix on an IFR flight plan _ cruise (log fuel, check nav, switch tanks) _ pre-approach ("WIRE") _ approach _ pre-landing / landing "GUMPS" _ clear of runway _ pre-taxi _ shutdown ("fuel not on both, master off") _ post-shutdown ("tie down, pick up your x, y, and z) _ walk-away ("hobbs, lock gate") I have a friend that would honestly "x" everything in each column. I consider myself a pretty safe pilot. *Answers for me below. *I do a lot of GUMPS, WIRE, and I use the instrument panel placards (pre-landing check, etc), in particular, but I am not thinking it is "checklist usage" unless you have the thing in your hand... Would I pass your flight test? _ preflight planning _ drive out to the airport _ preflight examination _x getting in and getting fastened x_ engine start and post-start _ pre-taxi _x runup _ pre-takeoff _ climbout _ approaching a fix on an IFR flight plan _ pre-approach ("WIRE") _ approach _ pre-landing / landing "GUMPS" _ clear of runway _ pre-taxi _ shutdown ("fuel not on both, master off") _ post-shutdown ("tie down, pick up your x, y, and z) _ walk-away ("hobbs, lock gate") I use a lot of flow and mnemonics for the other stuff tho. Tman. I both use and teach the use of checklists for any and all procedures so recommended by the manufacturer. I also use and teach mnemonics as a supplement to checklists. The trick with checklists is not to get bogged down in minutia to the point where you are checking every nut and bolt. A lot depends on the equipment being flown. Each pilot is a product of that pilot's exposure to the learning curve at any instant in that pilot's career. How a pilot views the use of checklists varies within this context. Some overdue checklist use. Some are lax on the subject of checklists. The good pilot develops an attitude toward flight safety that makes use of any and all appropriate tools devoted toward that end. How each pilot uses these tools will in large part be determined by the habit patterns that pilot has developed through the learning process (which never ends) Dudley Henriques Dudley Henriques |
I both use and teach the use of checklists for any and all procedures so recommended by the manufacturer. I also use and teach mnemonics as a supplement to checklists. The trick with checklists is not to get bogged down in minutia to the point where you are checking every nut and bolt. A lot depends on the equipment being flown. OK, I want to get specific. I pulled my C172 POH. It has "checklist procedures" , but nowhere does it say to use it as a checklist. Anyways, the checklist procedures cover Preflight, Pre-Start, Start, Pre-Takeoff, Takeoff, Climb, Cruise, Pre-Landing, Landing, After-Landing, Securing Airplane. From my sample of experience I have never seen a pilot use a checklist on all or even half of these procedures. Is that what you (or anyone else that opines an honest answer) looks for on a checkride? And when you use a checklist -- are you looking for it to be used as a "do-list" or a post-do "check" list. I can tell you if i had to pull the damn book of cards out every time i changed phase in flight, and used it as a do-list, it would be incredibly unnatural, and probably detract from safety. Anyways, just trying to get more specifics and separate checklist reality from checklist religion. TRUE story. A local flight instructor had a letter to editor published in a major av magazine admonishing everyone from students to ATP's on the need for "thorough checklist usage" just about everywhere. I think he had the required anecdote on the guy who took off with the control lock, pitot cover, or one such thing. Many words were dispensed in the letter. I've flown with him and he never pulled the g'darn checklist out or even hinted I might want to. Sigh... T |
On Apr 16, 9:51*pm, Tman wrote:
Dudley Henriques wrote: I both use and teach the use of checklists for any and all procedures so recommended by the manufacturer. I also use and teach mnemonics as a supplement to checklists. The trick with checklists is not to get bogged down in minutia to the point where you are checking every nut and bolt. A lot depends on the equipment being flown. OK, I want to get specific. I pulled my C172 POH. *It has "checklist procedures" , but nowhere does it say to use it as a checklist. *Anyways, the checklist procedures cover Preflight, Pre-Start, Start, Pre-Takeoff, Takeoff, Climb, Cruise, Pre-Landing, Landing, After-Landing, Securing Airplane. *From my sample of experience I have never seen a pilot use a checklist on all or even half of these procedures. *Is that what you (or anyone else that opines an honest answer) looks for on a checkride? And when you use a checklist -- are you looking for it to be used as a "do-list" or a post-do "check" list. I can tell you if i had to pull the damn book of cards out every time i changed phase in flight, and used it as a do-list, it would be incredibly unnatural, and probably detract from safety. Anyways, just trying to get more specifics and separate checklist reality from checklist religion. TRUE story. *A local flight instructor had a letter to editor published in a major av magazine admonishing everyone from students to ATP's on the need for "thorough checklist usage" just about everywhere. *I think he had the required anecdote on the guy who took off with the control lock, pitot cover, or one such thing. *Many words were dispensed in the letter. I've flown with him and he never pulled the g'darn checklist out or even hinted I might want to. *Sigh... T I believe my answer was specific enough. It is not my desire to change your opinion about how you use checklists, nor do I wish to argue the use of checklists on a micro level. If your aircraft HAS a checklist in my opinion you should USE IT! For operations with your aircraft where a checklist isn't "officially" suggested in the POH such as a pre-flight, use common sense. I'm sitting here looking at the POH for a 1966 Cessna 172. Section 1 includes checklists for all phases of operation in this aircraft. Do I insist that you go through each item on these checklists and check it off as you're flying the airplane; NO! As a check pilot, I'm expecting you to demonstrate a complete knowledge of these items and to be using the information on these pages in a way that shows proper planning and execution. The exact method you use to demonstrate this is entirely up to you as an applicant. There will be portions of the flight where I'll expect to see you use a checklist such as runup and portions of the flight such as the establishment of a Vy climb attitude for example where I'll expect you to perform that task with a smooth and thorough flow pattern rather than staring at a checklist. If this means you are using an abbreviated checklist or a mnemonic that's up to you. Just don't miss anything! Personally, I prefer seeing a flow pattern in a pilot that includes a verbal touch and affirmation BASED on the operation checklists when checklists are used. On most light airplanes, the in-flight checklists can be done using a Mnemonic which is perfectly acceptable. Demonstrate a flow pattern, touch it, identify it, use it. The item will be on the checklist but performed as part of your mnemonic checklist. Perfectly acceptable! -DH |
![]() "Dudley Henriques" wrote in message ... On Apr 16, 9:51 pm, Tman wrote: Dudley Henriques wrote: I both use and teach the use of checklists for any and all procedures so recommended by the manufacturer. I also use and teach mnemonics as a supplement to checklists. The trick with checklists is not to get bogged down in minutia to the point where you are checking every nut and bolt. A lot depends on the equipment being flown. OK, I want to get specific. I pulled my C172 POH. It has "checklist procedures" , but nowhere does it say to use it as a checklist. Anyways, the checklist procedures cover Preflight, Pre-Start, Start, Pre-Takeoff, Takeoff, Climb, Cruise, Pre-Landing, Landing, After-Landing, Securing Airplane. From my sample of experience I have never seen a pilot use a checklist on all or even half of these procedures. Is that what you (or anyone else that opines an honest answer) looks for on a checkride? And when you use a checklist -- are you looking for it to be used as a "do-list" or a post-do "check" list. I can tell you if i had to pull the damn book of cards out every time i changed phase in flight, and used it as a do-list, it would be incredibly unnatural, and probably detract from safety. Anyways, just trying to get more specifics and separate checklist reality from checklist religion. TRUE story. A local flight instructor had a letter to editor published in a major av magazine admonishing everyone from students to ATP's on the need for "thorough checklist usage" just about everywhere. I think he had the required anecdote on the guy who took off with the control lock, pitot cover, or one such thing. Many words were dispensed in the letter. I've flown with him and he never pulled the g'darn checklist out or even hinted I might want to. Sigh... T I believe my answer was specific enough. It is not my desire to change your opinion about how you use checklists, nor do I wish to argue the use of checklists on a micro level. If your aircraft HAS a checklist in my opinion you should USE IT! For operations with your aircraft where a checklist isn't "officially" suggested in the POH such as a pre-flight, use common sense. I'm sitting here looking at the POH for a 1966 Cessna 172. Section 1 includes checklists for all phases of operation in this aircraft. Do I insist that you go through each item on these checklists and check it off as you're flying the airplane; NO! As a check pilot, I'm expecting you to demonstrate a complete knowledge of these items and to be using the information on these pages in a way that shows proper planning and execution. The exact method you use to demonstrate this is entirely up to you as an applicant. There will be portions of the flight where I'll expect to see you use a checklist such as runup and portions of the flight such as the establishment of a Vy climb attitude for example where I'll expect you to perform that task with a smooth and thorough flow pattern rather than staring at a checklist. If this means you are using an abbreviated checklist or a mnemonic that's up to you. Just don't miss anything! Personally, I prefer seeing a flow pattern in a pilot that includes a verbal touch and affirmation BASED on the operation checklists when checklists are used. On most light airplanes, the in-flight checklists can be done using a Mnemonic which is perfectly acceptable. Demonstrate a flow pattern, touch it, identify it, use it. The item will be on the checklist but performed as part of your mnemonic checklist. Perfectly acceptable! -DH ------------------------------------------------------------------------- And other instructors will vary. |
On Apr 16, 11:09*pm, "Tim" #__#@__.- wrote:
"Dudley Henriques" wrote in message ... On Apr 16, 9:51 pm, Tman wrote: Dudley Henriques wrote: I both use and teach the use of checklists for any and all procedures so recommended by the manufacturer. I also use and teach mnemonics as a supplement to checklists. The trick with checklists is not to get bogged down in minutia to the point where you are checking every nut and bolt. A lot depends on the equipment being flown. OK, I want to get specific. I pulled my C172 POH. It has "checklist procedures" , but nowhere does it say to use it as a checklist. Anyways, the checklist procedures cover Preflight, Pre-Start, Start, Pre-Takeoff, Takeoff, Climb, Cruise, Pre-Landing, Landing, After-Landing, Securing Airplane. From my sample of experience I have never seen a pilot use a checklist on all or even half of these procedures. Is that what you (or anyone else that opines an honest answer) looks for on a checkride? And when you use a checklist -- are you looking for it to be used as a "do-list" or a post-do "check" list. I can tell you if i had to pull the damn book of cards out every time i changed phase in flight, and used it as a do-list, it would be incredibly unnatural, and probably detract from safety. Anyways, just trying to get more specifics and separate checklist reality from checklist religion. TRUE story. A local flight instructor had a letter to editor published in a major av magazine admonishing everyone from students to ATP's on the need for "thorough checklist usage" just about everywhere. I think he had the required anecdote on the guy who took off with the control lock, pitot cover, or one such thing. Many words were dispensed in the letter. I've flown with him and he never pulled the g'darn checklist out or even hinted I might want to. Sigh... T I believe my answer was specific enough. It is not my desire to change your opinion about how you use checklists, nor do I wish to argue the use of checklists on a micro level. If your aircraft HAS a checklist in my opinion you should USE IT! For operations with your aircraft where a checklist isn't "officially" suggested in the POH such as a pre-flight, use common sense. I'm sitting here looking at the POH for a 1966 Cessna 172. Section 1 includes checklists for all phases of operation in this aircraft. Do I insist that you go through each item on these checklists and check it off as you're flying the airplane; NO! As a check pilot, I'm expecting you to demonstrate a complete knowledge of these items and to be using the information on these pages in a way that shows proper planning and execution. The exact method you use to demonstrate this is entirely up to you as an applicant. There will be portions of the flight where I'll expect to see you use a checklist such as runup and portions of the flight such as the establishment of a Vy climb attitude for example where I'll expect you to perform that task with a smooth and thorough flow pattern rather than staring at a checklist. If this means you are using an abbreviated checklist or a mnemonic that's up to you. Just don't miss anything! Personally, I prefer seeing a flow pattern in a pilot that includes a verbal touch and affirmation BASED on the operation checklists when checklists are used. On most light airplanes, the in-flight checklists can be done using a Mnemonic which is perfectly acceptable. Demonstrate a flow pattern, touch it, identify it, use it. The item will be on the checklist but performed as part of your mnemonic checklist. Perfectly acceptable! -DH ------------------------------------------------------------------------- And other instructors will vary. That is correct. -DH |
Post Annual Flight check - Video | A Lieberma[_2_] | Owning | 3 | January 23rd 09 03:34 PM |
Post Annual Flight check - Video | [email protected] | Instrument Flight Rules | 2 | January 18th 09 01:30 AM |
Post-Annual Flight | Jay Honeck[_2_] | Piloting | 114 | March 2nd 08 10:55 PM |
Post-Annual Flight | Jay Honeck[_2_] | Owning | 111 | March 2nd 08 10:55 PM |
Preflieght for first flight after annual | Michael 182 | Piloting | 15 | June 18th 05 04:12 PM |
