there are likely a number of simple or handheld GPS receivers that can be used and supply the needed info for L/Nav but the easiest and most common connection is with a GPS/Data-Logger. Nearly any current GPS data-logger will provide the needed data for the L/Nav including the Cambridge 302 or (cheaper) 302A, Colibri, and also look at new "Erixx" Flight Recorder on my website http://www.wingsandwheels.com/page11.htm, these are FAI/IGC approved loggers for all flight records and badges and by comparison in the same relative price range as typical GPS handheld units with aviation data strings available and price worthy of consideration in the place of most used GPS data-loggers.
tim Please visit the Wings & Wheels website at www.wingsandwheels.com "soaringtheskies" wrote in message ... I have a Cambridge LNAV and I want to replace my LX400, which is currently being used purely as a GPS receiver, with something else to provide a GPS feed to the LNAV, preferably without taking up a space on my instrument panel. Any suggestions? -- soaringtheskies |
The LNAV, according to the manual, requires GPRMB and GPRMC sentences. I'm wanting to use as much of it's functionality as possible. I'm using an EW MicroRecorder as a logger, unfortunately although this can be used to supply a GPS signal to other things (it has it's own receiver) it does not transmit GPRMB sentences. So "all" I'm after is a GPS that will transmit both GPRMB and GPRMC sentences to my LNAV, it doesn't need to be able to log anything, although I see the point about needing something to transmit the next waypoint to it. Might end up putting that LX back in...there must be soemthing simpler out there though.
I'm also running SeeYou Mobile off a PDA, but I don't think there's any easy way of getting this to talk to the LNAV. |
On Apr 28, 2:05*pm, soaringtheskies soaringtheskies.
wrote: The LNAV, according to the manual, requires GPRMB and GPRMC sentences. I'm wanting to use as much of it's functionality as possible. *I'm using an EW MicroRecorder as a logger, unfortunately although this can be used to supply a GPS signal to other things (it has it's own receiver) it does not transmit GPRMB sentences. *So "all" I'm after is a GPS that will transmit both GPRMB and GPRMC sentences to my LNAV, it doesn't need to be able to log anything, although I see the point about needing something to transmit the next waypoint to it. *Might end up putting that LX back in...there must be soemthing simpler out there though. I'm also running SeeYou Mobile off a PDA, but I don't think there's any easy way of getting this to talk to the LNAV. -- soaringtheskies Any older inexpensive Garmin with transmit the sentences you need and allow you to transmit the next waypoint. Richard www.craggyaero.com |
On Tue, 28 Apr 2009 18:45:48 -0700, rhpf wrote:
On Apr 28, 2:05Â*pm, soaringtheskies soaringtheskies. wrote: The LNAV, according to the manual, requires GPRMB and GPRMC sentences. I'm wanting to use as much of it's functionality as possible. Â*I'm using an EW MicroRecorder as a logger, unfortunately although this can be used to supply a GPS signal to other things (it has it's own receiver) it does not transmit GPRMB sentences. Â*So "all" I'm after is a GPS that will transmit both GPRMB and GPRMC sentences to my LNAV, it doesn't need to be able to log anything, although I see the point about needing something to transmit the next waypoint to it. Â*Might end up putting that LX back in...there must be soemthing simpler out there though. I'm also running SeeYou Mobile off a PDA, but I don't think there's any easy way of getting this to talk to the LNAV. -- soaringtheskies Any older inexpensive Garmin with transmit the sentences you need and allow you to transmit the next waypoint. The OP wanted to avoid taking up panel space with the GPS, which rules out putting a waypoint into it. However, putting that type behind the panel merely provides another gotcha with at least some of them: the ON switch. If the GPS has a mechanical on switch, no problem. Just wire it to the main battery and strap it down behind the panel, making sure the batteries are out and the switch is ON. This way it will wake up when you turn the master switch on. However, many Garmins have a 'soft' power switch. I know the GPS II+ has one and IIRC the 12XL has as well. The problem here is that after the glider power is on you still have to prod the 'on' switch on the GPS, which is hard to do if its OOS behind the panel. ==== Another problem with the older Garmins is that they will all stop working in a few years. The 12 channel Garmin models (12XL, II+, III+ and others of the same vintage) all contain battery-backed RAM which is kept alive by a factory-fitted lithium cell. Will replacements for these cells still be available when they start to die some time after 2011? My first GPS II+, bought in 2001, was from a batch fitted with faulty lithium cells. In mine it failed just after the GPS guarantee ran out. I rang Garmin, expecting to pay for a new cell to be fitted but they told me that that, although the GPS guarantee was quite short (1-2 years), the Li cell had a 10 year guarantee and offered to replace it for free. However, I noticed that in fact they replaced the entire GPS, so swapping out the Li cell may be quite a difficult job. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
LPV versus LNAV/VNAV versus LNAV+V | Wyatt Emmerich[_2_] | Instrument Flight Rules | 6 | December 17th 07 01:38 AM |
King KN73 GS receiver | Jaros³aw Androsiuk | Owning | 4 | February 24th 06 05:57 AM |
LNAV preferable over LNAV/VNAV | [email protected] | Instrument Flight Rules | 4 | October 16th 05 06:34 PM |
GPS Receiver obsolescence | Ron Lee | Piloting | 6 | August 17th 05 06:26 PM |
SSR Receiver | Steven Archibald | General Aviation | 0 | November 6th 03 09:41 AM |
