![]() On Mon, 27 Apr 2009 11:58:30 +0100, Chris Reed wrote: *Never* winch launch with wet wings, as this could lead to a stall and spin off the wire. I wouldn't aerotow with anything more than mildly damp wings either. My experience with wet wings (DG-300 and PIK 20B) when winch launching is that the droplets disappear from the wing surface long before you enter rotation and to all intents and purposes the launch is normal. Both above-mentioned gliders had a well polished surface finish though. I've also aerotowed on many occasions with wet wings - "operations normal" at 60-65 kts airspeed. In cruising flight there is a tendency to fly fast to "blow" the wings free of water - this tends to be counter productive and I've settled on 60-65 kts as the optimum for my PIK 20B. I estimate about a 20% reduction in L/D with wet wings. Simply allow for a nominal 40:1 dropping to 32:1! Geoff Vincent Melbourne, Australia |
Geoff Vincent wrote:
My experience with wet wings (DG-300 and PIK 20B) when winch launching is that the droplets disappear from the wing surface long before you enter rotation and to all intents and purposes the launch is normal. Both above-mentioned gliders had a well polished surface finish though. The British Gliding Association advice is never to winch launch with wet wings. From memory of Steve Longland's book (effectively part II of the BGA Instructor's Manual), your minimum winch speed is calculated as 1.5 x Vs (free flight), to allow a safe margin over the increased stall speed on the winch caused by the weight of cable + pull of winch. If wet wings increase the stall speed by, say, 15% (for my Open Cirrus it's 15-20%), the safe winch launch window is much smaller. For my aircraft the normal launch window is 90-110 kph (50-59 kt). With wet wings, the free flight stall speed rises from 60kph to 69kph (say 70 for ease of calculation), and 1.5 x this is 105kph. Max winch speed remains the same, so I now have a safe window of only 5 kph (3 kt)! It might be that the rain in the Southern hemisphere runs off wings quicker, but I'm not taking chances on that if I get the opportunity to fly there! |
The performance of some gliders is badly effected by wet wings. PIK 20,
Kestrel 17 and 19, Grob 103 spring to mind but there are others. The Kestrel and PIK have a Wortman Section and the Grob an Eppler. All these gliders suffer from very high sink with wet wings. Other gliders are not so badly effected, the ASW17 would climb in rain. It very much depends on the wing section as the ASW17 has a different Wortman Section. Whatever the performance issues I would agree with the rule that a winch launch should not be undertaken with wet wings, doing so could result in you being served by undertakers. At 15:11 29 April 2009, Chris Reed wrote: Geoff Vincent wrote: My experience with wet wings (DG-300 and PIK 20B) when winch launching is that the droplets disappear from the wing surface long before you enter rotation and to all intents and purposes the launch is normal. Both above-mentioned gliders had a well polished surface finish though. The British Gliding Association advice is never to winch launch with wet wings. From memory of Steve Longland's book (effectively part II of the BGA Instructor's Manual), your minimum winch speed is calculated as 1.5 x Vs (free flight), to allow a safe margin over the increased stall speed on the winch caused by the weight of cable + pull of winch. If wet wings increase the stall speed by, say, 15% (for my Open Cirrus it's 15-20%), the safe winch launch window is much smaller. For my aircraft the normal launch window is 90-110 kph (50-59 kt). With wet wings, the free flight stall speed rises from 60kph to 69kph (say 70 for ease of calculation), and 1.5 x this is 105kph. Max winch speed remains the same, so I now have a safe window of only 5 kph (3 kt)! It might be that the rain in the Southern hemisphere runs off wings quicker, but I'm not taking chances on that if I get the opportunity to fly there! |
On 30 Apr 2009 09:30:03 GMT, Don Johnstone
wrote: The performance of some gliders is badly effected by wet wings. PIK 20, Kestrel 17 and 19, Grob 103 spring to mind but there are others. The Kestrel and PIK have a Wortman Section and the Grob an Eppler. All these gliders suffer from very high sink with wet wings. Other gliders are not so badly effected, the ASW17 would climb in rain. It very much depends on the wing section as the ASW17 has a different Wortman Section. .... text deleted It has been said a number of times before in this group, but probably needs repeating for those new to the sport as ships like the PIK come on the used market. The impact of rain on the wings of the PIK is significant and easily recognized, but based on my 2000+ hrs in a PIK20B, including multiple 500K+ flights, the effect is not dramatic. You will hear this effect described by those with no experience in the type as "falling out of the sky". This is NOT the case. When encountering rain in the PIK, you can feel the separation as a low frequency vibration usually before you can actually see the rain accumulation on the wing. As rain builds up on the wings, the sink impact is probably about 20%, significant, but not severe. I have continued flight many times penetrating though rain showers. and, if the lift is strong enough to compensate for the slight sink increase (less severe at slower climb airspeeds), the PIK will climb perfectly well in the rain. I never noticed any effect in landing during rain showers, though I would add 5 knots or so to my landing speed. That said, there is no arguing with the fact that the PIK (and others with this airfoil) were more strongly effected by rain when compared with the earlier non-laminar airfoil ships, and the later thin airfoil ships. But this concern should not be a significant factor in the decision of a pilot to consider one of these older, and often very affordable sailplanes. I sold my PIK over 10 years ago, but still would have no safety concerns about flying the ship through the rain. Bob |
On Thu, 30 Apr 2009 20:33:38 -0500, Bob Gibbons
wrote: On 30 Apr 2009 09:30:03 GMT, Don Johnstone wrote: The performance of some gliders is badly effected by wet wings. PIK 20, Kestrel 17 and 19, Grob 103 spring to mind but there are others. The Kestrel and PIK have a Wortman Section and the Grob an Eppler. All these gliders suffer from very high sink with wet wings. Other gliders are not so badly effected, the ASW17 would climb in rain. It very much depends on the wing section as the ASW17 has a different Wortman Section. ... text deleted It has been said a number of times before in this group, but probably needs repeating for those new to the sport as ships like the PIK come on the used market. The impact of rain on the wings of the PIK is significant and easily recognized, but based on my 2000+ hrs in a PIK20B, including multiple 500K+ flights, the effect is not dramatic. You will hear this effect described by those with no experience in the type as "falling out of the sky". This is NOT the case. When encountering rain in the PIK, you can feel the separation as a low frequency vibration usually before you can actually see the rain accumulation on the wing. As rain builds up on the wings, the sink impact is probably about 20%, significant, but not severe. I have continued flight many times penetrating though rain showers. and, if the lift is strong enough to compensate for the slight sink increase (less severe at slower climb airspeeds), the PIK will climb perfectly well in the rain. I never noticed any effect in landing during rain showers, though I would add 5 knots or so to my landing speed. That said, there is no arguing with the fact that the PIK (and others with this airfoil) were more strongly effected by rain when compared with the earlier non-laminar airfoil ships, and the later thin airfoil ships. But this concern should not be a significant factor in the decision of a pilot to consider one of these older, and often very affordable sailplanes. I sold my PIK over 10 years ago, but still would have no safety concerns about flying the ship through the rain. Bob Well spoken Bob - exactly my own experience, albeit with only 1600 hrs in the PIK 20B. It is rarely acknowledged, but many other early glass ships world-wide were equipped with the same Wortman FX 67-K- 170 (150) airfoil and suffered from performance degradation when the wings were wet: e.g. Kestrel 17/19, Glasflugel 604, Nimbus 2, Mini-Nimbus, Janus, Caproni Calif, Open Jantar 1& 2, Mosquito, LS-2 (only one built, but won a world championship - Reichmann, Australia 1974), LS-3, HP-18, Zuni and several others. It is such a pity that the PIK 20 seems to cop all the flak when the subject of wet wings comes up! In almost all respects it's a great aircraft. Geoff V Melbourne, Australia |
Bob,
This is WAY off subject; however, your old Ka-6E (http://www.soaridaho.com/photogallery/valley/Ka-6E.jpg) is sitting in its' trailer in a hangar here in Idaho. I sold it to the current owner a little over 10 years ago. He has never flown it and seems to have no desire to sale it. Wayne HP-14 "6F" http://www.soaridaho.com/ "Bob Gibbons" wrote in message ... On 30 Apr 2009 09:30:03 GMT, Don Johnstone wrote: The performance of some gliders is badly effected by wet wings. PIK 20, Kestrel 17 and 19, Grob 103 spring to mind but there are others. The Kestrel and PIK have a Wortman Section and the Grob an Eppler. All these gliders suffer from very high sink with wet wings. Other gliders are not so badly effected, the ASW17 would climb in rain. It very much depends on the wing section as the ASW17 has a different Wortman Section. ... text deleted It has been said a number of times before in this group, but probably needs repeating for those new to the sport as ships like the PIK come on the used market. The impact of rain on the wings of the PIK is significant and easily recognized, but based on my 2000+ hrs in a PIK20B, including multiple 500K+ flights, the effect is not dramatic. You will hear this effect described by those with no experience in the type as "falling out of the sky". This is NOT the case. When encountering rain in the PIK, you can feel the separation as a low frequency vibration usually before you can actually see the rain accumulation on the wing. As rain builds up on the wings, the sink impact is probably about 20%, significant, but not severe. I have continued flight many times penetrating though rain showers. and, if the lift is strong enough to compensate for the slight sink increase (less severe at slower climb airspeeds), the PIK will climb perfectly well in the rain. I never noticed any effect in landing during rain showers, though I would add 5 knots or so to my landing speed. That said, there is no arguing with the fact that the PIK (and others with this airfoil) were more strongly effected by rain when compared with the earlier non-laminar airfoil ships, and the later thin airfoil ships. But this concern should not be a significant factor in the decision of a pilot to consider one of these older, and often very affordable sailplanes. I sold my PIK over 10 years ago, but still would have no safety concerns about flying the ship through the rain. Bob |
On May 1, 9:29*am, "Wayne Paul" wrote:
Bob, This is WAY off subject; however, your old Ka-6E (http://www.soaridaho.com/photogallery/valley/Ka-6E.jpg) is sitting in its' trailer in a hangar here in Idaho. *I sold it to the current owner a little over 10 years ago. *He has never flown it and seems to have no desire to sale it. Wayne HP-14 "6F"http://www.soaridaho.com/ "Bob Gibbons" wrote in message ... On 30 Apr 2009 09:30:03 GMT, Don Johnstone wrote: The performance of some gliders is badly effected by wet wings. PIK 20, Kestrel 17 and 19, Grob 103 spring to mind but there are others. The Kestrel and PIK have a *Wortman Section and the Grob an Eppler. All these gliders suffer from very high sink with wet wings. Other gliders are not so badly effected, the ASW17 would climb in rain. It very much depends on the wing section as the ASW17 has a different Wortman Section. ... text deleted It has been said a number of times before in this group, but probably needs repeating for those new to the sport as ships like the PIK come on the used market. The impact of rain on the wings of the PIK is significant and easily recognized, but based on my 2000+ hrs in a PIK20B, including multiple 500K+ flights, the effect is not dramatic. You will hear this effect described by those with no experience in the type as "falling out of the sky". This is NOT the case. When encountering rain in the PIK, you can feel the separation as a low frequency vibration usually before you can actually see the rain accumulation on the wing. As rain builds up on the wings, the sink impact is probably about 20%, significant, but not severe. I have continued flight many times penetrating though rain showers. and, *if the lift is strong enough to compensate for the slight sink increase (less severe at slower climb airspeeds), the PIK will climb perfectly well in the rain. I never noticed any effect in landing during rain showers, though I would add 5 knots or so to my landing speed. That said, there is no arguing with the fact that the PIK (and others with this airfoil) were more strongly effected by rain when compared with the earlier non-laminar airfoil ships, and the later thin airfoil ships. But this concern should not be a significant factor in the decision of a pilot to consider one of these older, and often very affordable sailplanes. I sold my PIK over 10 years ago, but still would have no safety concerns about flying the ship through the rain. Bob- Hide quoted text - - Show quoted text - That is really sad. A Ka-6 would make some beginning glider pilot very happy. I sure do love mine.... Pete |
Our second encounter with freezing rain | Longworth | Piloting | 7 | February 19th 08 02:14 AM |
Rain, rain, go away... | PJ Hunt | Rotorcraft | 3 | October 30th 04 07:51 AM |
Pic 20's in the rain | Matt | Soaring | 23 | May 14th 04 03:04 AM |
Date of effect now 1 October 2004 for revised IGC-approvals for certain legacy types of GNSS flight recorder | Ian Strachan | Soaring | 0 | March 15th 04 02:32 PM |
Date of effect now 1 April 2004 for revised IGC-approval for certain legacy types of GNSS flight recorder | Ian Strachan | Soaring | 56 | December 2nd 03 08:08 AM |
