I don't see how a mis-adjusted altimeter gets by the pre-flight
checklist. Instruments: altimeter set to field elevation? Mike |
On May 1, 6:01*am, Mike125 wrote:
I don't see how a mis-adjusted altimeter gets by the pre-flight checklist. Instruments: altimeter set to field elevation? Mike Do I detect a bit of "invulnerability" there. ![]() It is easy to not be able to see how it can happen, until it happens to you. Under the right circumstances it can be very easy to do. To the point even a highly trained, F16 Thunderbird pilot can do it i.e. Mountain Home AFB Crash. Brian CFIIG/ASEL |
In article
, Mike125 wrote: I don't see how a mis-adjusted altimeter gets by the pre-flight checklist. Instruments: altimeter set to field elevation? You check it, see that it's a bit off, and set it so that it's correct. All the while, never noticing that the thousands hand is in the wrong place. The human brain has a powerful capacity for illusion. If you "know" that something is true, it can be difficult to see otherwise. Especially when the object in question is small and you're not concentrating on it. -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
On May 1, 12:23*pm, Mike Ash wrote:
In article , *Mike125 wrote: I don't see how a mis-adjusted altimeter gets by the pre-flight checklist. Instruments: altimeter set to field elevation? You check it, see that it's a bit off, and set it so that it's correct. All the while, never noticing that the thousands hand is in the wrong place. The human brain has a powerful capacity for illusion. If you "know" that something is true, it can be difficult to see otherwise. Especially when the object in question is small and you're not concentrating on it. -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon I agree anything can happen to anyone, especially me. Having the altimeter off by 1000' is would be easy to overlook in a hurried check. Having it off by several hundreds should be caught. I assume that would grounds for failure on a check ride. Mike |
In article
, Mike125 wrote: On May 1, 12:23*pm, Mike Ash wrote: In article , *Mike125 wrote: I don't see how a mis-adjusted altimeter gets by the pre-flight checklist. Instruments: altimeter set to field elevation? You check it, see that it's a bit off, and set it so that it's correct. All the while, never noticing that the thousands hand is in the wrong place. The human brain has a powerful capacity for illusion. If you "know" that something is true, it can be difficult to see otherwise. Especially when the object in question is small and you're not concentrating on it. I agree anything can happen to anyone, especially me. Having the altimeter off by 1000' is would be easy to overlook in a hurried check. Having it off by several hundreds should be caught. I assume that would grounds for failure on a check ride. Right, hundreds errors are easy and should always be caught, thousands errors are tougher. When it happened to me, I think the altimeter was reading around 0, with field elevation at 700ft. I turned it the quicker way, ending up with a reading of -300ft, never noticing that the thousands hand was under the zero. I didn't notice at any time during the tow either, even though I was watching it in order to release at 3,700ft. It was only after release, when I could relax and take my time, that I finally noticed that it was reading 1,000ft low. -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
Checkride Wednesday...followup to: "Tips for Commercial Glider Checkride?" | Don Byrer | Soaring | 4 | July 19th 08 03:57 AM |
Phrase "landing runway" vs. "cleared to land" | Robert M. Gary | Piloting | 168 | February 5th 08 05:32 PM |
Phrase "landing runway" vs. "cleared to land" | Robert M. Gary | Instrument Flight Rules | 137 | February 5th 08 05:32 PM |
Old polish aircraft TS-8 "Bies" ("Bogy") - for sale | >pk | Aviation Marketplace | 0 | October 16th 06 07:48 AM |
