Beginner questions about buying a sailplane...
Old May 6th 09, 08:32 PM posted to rec.aviation.soaring
Chris Reed[_2_]
Default Beginner questions about buying a sailplane...
Bob wrote:
Another thing, K-8's sell from 1500€ (2000$). These planes are still
flyable and have pased inspection in the last year as here in Germany
all planes get inspected yearly by the LVB. I checked about shipping
on 2 months ago and was quoted a price of 2000€ from Bremerhaven to
Charleston.
K8s are fun to fly, but very dispiriting if you have any headwind at
all. If you have USD10-20k to spend, and want to do any more than soar
locally around your home airfield, then glass is the only way to go
IMHO. I've had fun flying a K6, in which you can do good XC flying, but
this also becomes too tiring for a new XC pilot - serious XC in a K6 is
for the more experienced pilot.
The advantage of anything with a claimed 38:1 L/D or better (Astir,
ASW15, Libelle, etc) is that you can fly into wind and sample more than
one or two potential thermals. With the K6, K8 and, I suspect, the I-26,
if you don't connect first or second time you're on the ground.
As other posters have said, you will want a glider which (a) has a good
trailer and (b) is easy to rig. Every glider is made easier to rig with
two or more trestles (wood, nails hinges and carpet - dead easy to
build), and one man rigging gear can be really effective if you have
space in the trailer to store it. As an example, I fly a 1968 Open
Cirrus, which has pretty heavy wings and is not thought easy to rig.
With home-made (sub-USD100) rigging gear I can assemble it without help
in up to 15kt winds in about 20 mins. This means I can take it anywhere
to fly it, and even self-retrieve by hitch-hiking back and collecting
the trailer (though I've not yet alienated my friends so much as to need
to do so).
I used to fly a Grob Astir (again, not thought easy to rig), and using
two trestles and a simple wing root dolly two of us could assemble it in
15 mins with almost no lifting. One man rig would have been possible if
the trailer had had space to store the gear.
Leaving the glider assembled is very much over-rated. Apart from
anything else, if you're experienced in putting it together and taking
it apart, then you have no fear of heading off XC because, after all, it
needs to be disassembled somewhere (so why not a field?). I've known
friends who don't fly XC because they're afraid they'll have problems
retrieving the glider if they land out - I know mine will be back in the
trailer in 15 mins, so off I go.
In summary, my advice would be:
a. Buy 38:1 L/D (claimed) or better;
b. A good trailer is essential;
c. Assemble/dissassemble every time you fly until this is no barrier to
flying/going somewhere - make as many rigging aids as you need to make
this easy.
d. Fly it lots! Rig unless it's clearly not soarable. Don't be one of
those pilots who says, mid-afternoon, "it would have been worth rigging
after all". If you don't launch, it's only 15 mins (see (c) above) to
put the glider back in its trailer after all.
Old May 6th 09, 10:20 PM posted to rec.aviation.soaring
Doug Hoffman
My experience was just the opposite. I had my longest x-country flight
ever in the LAK-12, i.e., I ventured much farther away from home. The
glide and performance are very confidence-inspiring. But I agree with
you that one should have competent rigging/derigging aids, which my LAK
has, so that fear of land-out is removed from the equation. I have no
fear whatsoever of outlanding and field derigging. They are easy to
take apart because precision alignment is not an issue. Reassembling
however is best done on a hard and level surface back at the airport.
Regards,
-Doug
Old May 7th 09, 07:06 AM posted to rec.aviation.soaring
Bob
Charleston.
Chris
I wasn't advocating the K-8 as much as giving it as an alternative to
the 1-26, same performance for less money.
I agree totally about glass! An Astir, Cirrus, ASW15... The list is
endless and all can be had for 10-20$ with sutable (not perfect but
usable) trailer.
Bob (Who's first plane purchase is a part of a Nimbus 3DT)
Old May 7th 09, 03:30 PM posted to rec.aviation.soaring
Nigel Pocock[_2_]
Dont rule out a share in a higher performance 2 seater. At our club we have
about 8 syndicates with high performance 2 seaters such as AS25, Duo
Discus, DG1000t and Nimbus 3dt. The share price would be about the same
but the running costs, insurance etc are split several ways. The
advantages are that you are very often flying with experienced pilots ( I
can think of several national champions and national team members.)who can
teach and coach you in cross country techniques and advanced soaring. It is
also companionable and one can be flying the aircraft whilst the other is
navigating, sorting out the sandwiches, using the radio etc.
Nigel
Buying questions - which plane? John Doe Owning 26 July 25th 05 08:19 AM
Another beginner Q Ramapriya Piloting 9 December 31st 04 05:19 PM
Buying used homebuilt: questions on ELSA Jim Carriere Home Built 2 October 5th 04 03:00 AM
suggestion for beginner sunbearpcs Owning 5 January 21st 04 04:35 PM
ASW 24 WL for beginner ? Harry Soaring 37 July 26th 03 02:02 PM
