Beginner questions about buying a sailplane...
Old May 6th 09, 10:20 PM posted to rec.aviation.soaring
Doug Hoffman
Default Beginner questions about buying a sailplane...
Chris Reed wrote:
Leaving the glider assembled is very much over-rated. Apart from
anything else, if you're experienced in putting it together and taking
it apart, then you have no fear of heading off XC because, after all, it
needs to be disassembled somewhere (so why not a field?). I've known
friends who don't fly XC because they're afraid they'll have problems
retrieving the glider if they land out
My experience was just the opposite. I had my longest x-country flight
ever in the LAK-12, i.e., I ventured much farther away from home. The
glide and performance are very confidence-inspiring. But I agree with
you that one should have competent rigging/derigging aids, which my LAK
has, so that fear of land-out is removed from the equation. I have no
fear whatsoever of outlanding and field derigging. They are easy to
take apart because precision alignment is not an issue. Reassembling
however is best done on a hard and level surface back at the airport.
Regards,
-Doug
Buying questions - which plane? John Doe Owning 26 July 25th 05 08:19 AM
Another beginner Q Ramapriya Piloting 9 December 31st 04 05:19 PM
Buying used homebuilt: questions on ELSA Jim Carriere Home Built 2 October 5th 04 03:00 AM
suggestion for beginner sunbearpcs Owning 5 January 21st 04 04:35 PM
ASW 24 WL for beginner ? Harry Soaring 37 July 26th 03 02:02 PM
