In addition to Bill's comments the calibrations process must consider the position of the flaps. Remember you are measuring the AOA of the airfoil, not just the airflow relative to the fuselage.
Wayne http://www.soaridaho.com/Schreder .. "bildan" wrote in message ... I've worked this problem for a number of years. Let me offer a few simple points. Any system of measuring AOA will need to be calibrated. It doesn't really need to be linear since the major interest is in the region near stall and Cl max. It just needs to give a variable output that is related to AOA - and be very repeatable. If the cockpit is in clean free air flow as with a pusher or sailplane, an effective AOA indicator can be made with a simple string taped to the side of the canopy. On sailplanes, these 'pitch strings' tends to 'over-indicate' by about 2:1 which is fine as it increases the resolution of the indicator. Stall, Cl max and L/D max can be marked on the inside of the canopy with grease pencil. It helps to put one on each side of the canopy as they tend to validate each other. If you like the pressure differential AOA probes, this is a good one. http://www.cgmasi.com/aviation/index.html If you want NASA quality data, the gold standard is the pitch vane mounted on an air-data nose boom. There are a number of vendors who sell these for UAV's which are about the right size for homebuilt airplanes. Here's an example: http://www.spaceagecontrol.com/Adpmain Bill D |
Prop angle of attack vs age | sid | Piloting | 47 | July 13th 08 04:46 PM |
Glider angle of attack indicator by SafeFlight | Bill Daniels | Soaring | 53 | December 20th 07 12:29 PM |
Angle of attack | Bill Daniels | Soaring | 27 | December 19th 07 06:17 AM |
preferrred bank angle indicator? | Matt Herron Jr. | Soaring | 34 | July 10th 06 02:22 PM |
Lift and Angle of Attack | Peter Duniho | Simulators | 9 | October 2nd 03 10:55 PM |
