Spin recovery vs tail design
Old May 12th 09, 03:00 AM posted to rec.aviation.soaring
Ron Ogden
Default Spin recovery vs tail design
At 23:54 11 May 2009, Andreas Maurer wrote:
On Tue, 12 May 2009 01:25:24 +0200, John Smith
It may quicken up the recovery, but JAR-22 requires a sailplane to
recover with any flap setting.
Indeed - but many gliders who are still popular were designed before
JAR-22.
I'm always amazed about how much easier the ASW-27 handles in this
regard compared to a, say, ASW-20.
Bye
Andreas
Thanks to all who have contributed to answering my original question. I
am especially interested in the comments about the ASK-21, especially in
reference to changes in how it behaves as the spin continues through more
than one or two turns. My club has one with the spin kit and we look
forward to practicing but it is better to do so fully prepared with
knowledge of the experiences others have had. Thanks!
Old May 12th 09, 08:44 AM posted to rec.aviation.soaring
John Smith
The short answer is: With all legal loading it recovers by the book from
as many turns as your or your student's wallet allows.
The somewhat longer answer is that usually it recovers in less than half
a turn, but in certain special circumstances recovery may take up to two
turns. This will frighten you if you aren't prepared, but the ASK *will*
eventually recover. Some people will tell you that the ASK may bite you;
actually, it will not, but probably those people have experienced a
longer than expected recovery delay. (Or more probably have been told
the story from somebody who knows somebody who knows somebody...)
The longest answer is that a long time ago there has been a spin
accident with a cadet of the USAF academy. Subsequently the USAF topk
the ASK 21 through a thorough spin test program, in which they found
what I wrote above. Schleicher will probably send you a copy of the 120
page report if you kindly ask them.
One more thing: Outward ailerons will flatten the spin considerably
which doesn't help on recovery. I've never tried whether it will recover
at all from that flat attitude.
Old May 12th 09, 01:15 PM posted to rec.aviation.soaring
Nyal Williams[_2_]
"One more thing: Outward ailerons will flatten the spin considerably which
doesn't help on recovery."
What does that mean?
I
in
more
recover
Old May 12th 09, 01:25 PM posted to rec.aviation.soaring
John Smith
First it probably means bad terminology. Second, it means that the pitch
attitude of the ASK in the spin depends on aileron position. Play enough
with the ailerons and you will find yourself in something like a flat
spin which may be reluctant to recovery. But you can always continue to
play with the ailerons until you'll find yourself in a normal spin again.
Old May 12th 09, 02:45 PM posted to rec.aviation.soaring
Nyal Williams[_2_]
I've never tried this, but I have wondered whether adding downward
deflected aileron on the outside wing during a spin might 1) add drag that
would slow the rotation, stall that wing and further reduce the asymmetric
lift, and thus aid in stopping the spin.
Comments, anyone?
which
again.
Old May 12th 09, 02:56 PM posted to rec.aviation.soaring
John Smith
Spins are aerodynamically extremely complex and each aircraft type
reacts differently.
Old May 12th 09, 03:15 PM posted to rec.aviation.soaring
Nyal Williams[_2_]
that
asymmetric
reacts differently.
No question; that's why it's important to read the POH.
Old May 13th 09, 01:09 AM posted to rec.aviation.soaring
TonyV[_2_]
reacts differently.
"Spins are a normal mode of flight, unsuitable for landing".
Unknown British aerodynamicist (sp?).
Tony V.
Old May 13th 09, 02:00 AM posted to rec.aviation.soaring
Don Johnstone[_4_]
reacts differently.
One too many words in that statement, delete the word type.
Spin Recovery Training Before First Solo? [email protected] Piloting 16 September 9th 07 03:48 AM
Spin Recovery Training Before First Solo? [email protected] Piloting 1 September 5th 07 09:51 PM
SR22 Spin Recovery gwengler Piloting 9 September 24th 04 07:31 AM
inverted spin recovery explanation Alan Wood Aerobatics 18 August 19th 04 03:32 PM
Edelweiss - Spin recovery procedures Uri Saovray Soaring 7 March 15th 04 12:41 AM
