Building an electronic Angle of Attack indicator
Old May 12th 09, 06:06 PM posted to rec.aviation.homebuilt
Stuart Fields
Default Building an electronic Angle of Attack indicator
"who cares?" wrote in message
In article , rich
Well of course, the best is to use an AOA vane, like the jets use. The
biggest problem is where the jets conveniently mount it on the side of
the fuselage, on most singles, that's right in the prop blast,
rendering it useless. If you could find someplace to mount it outside
of the prop blast, then it would work great. But finding that
place......
I would like to see a vain mounted on each wingtip with two indicators on
glareshield.
I'd like to see how much difference there is in AA from one side to the
other
during steep turns, slow turns, and less than perfect rudder work.
Sounds like an interesting idea. Encoding the position of the vane would be
needed. One way might be to use minature shaft angle optical encoders ( I
tend to think digitally as opposed to analog) . I've seen prices as low as
$20 each. Put one on each wing tip mounted vane and as Jim says the rest is
easy. (If you know some good electronic tech). If you know the AoA for
stall, the output of the encoder could be compared to a preset number and an
alarm into the head set could easily be produced digitally. I've used a
combination of a modification of one of Jim's circuits produced for
Kitplanes along with some additional digital circuitry for a High/Low
helicopter rotor speed alarm and it works great.
__________ Information from ESET NOD32 Antivirus, version of virus signature database 4068 (20090512) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
Old May 12th 09, 06:20 PM posted to rec.aviation.homebuilt
Dan[_12_]
In article , rich
place......
glareshield.
other
Good idea, you can use a DIP switch (do they still call them that?)
to set your alarm point.
Dan, U.S. Air Force, retired
Prop angle of attack vs age sid Piloting 47 July 13th 08 04:46 PM
Glider angle of attack indicator by SafeFlight Bill Daniels Soaring 53 December 20th 07 12:29 PM
Angle of attack Bill Daniels Soaring 27 December 19th 07 06:17 AM
preferrred bank angle indicator? Matt Herron Jr. Soaring 34 July 10th 06 02:22 PM
Lift and Angle of Attack Peter Duniho Simulators 9 October 2nd 03 10:55 PM
