On May 13, 3:50*am, "Ken S. Tucker" wrote:
On May 13, 1:03 am, frank wrote: On May 12, 5:13 pm, Andrew Swallow wrote: Ken S. Tucker wrote: [snip] For instance using ADC (Analog to Digital) and DAC (Digital to Analog) converters going into an Elektronic Brain....was nearly sci-fi. It still is sci-fi. Although nowdays it is the analog side they do not know about. Andrew Swallow Not really. We were collecting analog data as late as early 90s. Some were doing digital , most data was analog. Had to do conversions, did that on tape systems, read analog tape, created digital tape, ran digital tape as input to computer systems. I don't know if they do digital data recordings directly, now, would make sense but there are reasons not to do it. you can get higher frequency of data with analog data. highest was FM, could get 1000 samples / sec. Real interesting looking at realtime data. Usually wouldn't print it until right at where you needed data. Recorders spit out tons of thermal paper. Fun to watch. Vast majority was 20 samples / sec at most, which was fine for analog. I had some data requirements at 10000 cycles / sec, what they did was run it at 10th of the speed it was recorded at. For some reason, analog to digital was a 1:1 time write to tape. One hour of data took one hour to convert to digital record. Then we had to run the digital tape through some other programs to make sense of it all. Usually was just a voltage point. Conversion created say acft, tail, flight #, date, time, mach #, alt and whatnot. Lots of the conversion literally was a patch board hookup. Flight data reels in raw format were probably an inch, inch and a half wide, weighed about 50 lbs. One wasn't bad, two were real strain to carry. Most fighters had one tape recorder. Easier to do analog data right off of transducers. Let me guess, corrections invited. Today, software and computer enhanced flying is well known to a military pilot. (The rumor that the F-22's crossing the International dateline caused the computer - via software glitch - to crash is a typical example). In a sense, software removes pilots burden. When was software first used? I'm guessing it was 1st used to automatically control the F-111 wing sweep. Ken Good question. Incidentally, there was a problem in the F-16, I think early mid 80s. OK, remember all your trig? Yeah, the class you never though made sense. Had some function, was something divided by cosine of heading, and something else divided by sine of heading. You guessed it. When they hit due north, system went nuts. There was a reason they taught us division by zero didn't work. Would fly great then just go nuts. Took a while to figure that one out. Fix was if you went to something divided by zero enter some other function into it. I think guidance and control was the initial area. IF you ever studied aero engineering, that was the course that would kill your prospect for a degree. Yeah, in the real world, all those formulas were really used. Honest. Except in the real world, you programmed it, not solving it by hand to get all the sub sub sub sub scripts right. Been there, did that, you know what I'm talking about. The more complex the systems, the more problems crop up. Some aren't found for years. Then the active AF comes back and screams that its broke and it needs to be fixed. Keeps flight test funded anyway. Its not like we broke it on purpose. Sometimes we sent it out knowing we couldn't figure something out. B-1 had nose wheels getting stuck up in flight. Every airplane probably has something. Fly by wire in 80s was when computers really came into their own. Some like the X-29 were all computer controlled. Forward swept wing. Test pilots said it was real smooth. Feedback was something like 50 times a second. You would say fly to this point, it would do it smoothly even in turbulence. Early B-1A crash, #059 was due to going to test point high speed at 200 ft, wings swept back. When wings went back, all the weight in the wings caused CG to go aft, once it pitched beyond limits, nose went up, then everything went South real fast. Couldn't move fuel fast enough to get over it, departed controlled flight. There was a FCGMS Fuel Center Gravity Management System but it was turned off. That was upgraded, pretty much harder to turn off. Spent a lot of time on stability with vanes on nose of a/c and TF and other stuff. About mid 80s lots more TF or TA (terrain following, terrain avoidance) showed up. Some were tied to altimeter, keep this distance to ground, some looked ahead worked on some sort of mapping data to figure where they were going. Some were IR systems instead of RADAR. That got tied into autopilot. Big deal to convince somebody to fly 200 ft at .85 Mach and say, trust me it works. I think that was lowest limit, at least what we used. Heard Tornado pilots were absolutely insane. Then again they were RAF and sort of didn't have to follow our regs. Were supposed to, but its their airplanes. Heard all sorts of stuff about those guys being just no fear at all. USAF used to be higher faster farther, they were pretty much lower & faster. Once you put computers in airplanes, data increased a lot. B-1 had I think 6000 possible data points. Not all used at once, not all in one airplane. Usually 200 or so realtime in a flight test, others post flight. By the time AC-130U and MC-130H showed up, they were up to 80,000 parameters. Instrumentation Engineers went insane. Then again, they could add stuff all over the airplane. Pretty much all digital. Literally took 8 hours to run the program to set up what you were looking for off the airplane for each flight test, this was to determine what parameters to look at from the data stream. Data for instrumentation sort of was like swiss cheese. Think parameters in columns, rows were calibration coefficients, thickness was flight number. Insane. Even decades later. Stole it from AEC or whatever it turned into. F-22 wanted 2 Gb / second data rate, sent to I think 5 locations real time, ability to quick look at data instead of strip charts. No ARIA following it. Forgot how many parameters. Some high data rate. Usually used 20 samples / sec or less (1991 anyway). That was what RADAR was set to capture data at. Cameras also, so if you merged RADAR, camera with other data it all fit at 20 samples / sec. Engineers would slice and dice data depending on what they were doing tests on. wing sweep was set initially with a level. Only had a few settings. Wasn't like you could do 12 degrees, 13 degrees. Was like 15, 30, 67. On B-1 both wings were at same setting. F-14 had problems where one was say 50 , one was 15. Real emergency to get it down. That eventually got fixed, but don't know the details. Don't know if F-111 would have that problem. But, it had other problems to solve. Big one was fatigue on wings moving in flight. Lost more than a few with wings coming off. GD eventually solved that but it was pulled when sent to Vietnam pretty quickly. Got a real reputation as a problem child until Desert Storm and the Libyan raid. Considering how far we went with from pretty much levers and all that to hydraulic controls to computer controlled, its nothing short of just amazing. Obvious when you look back, at the time pretty much computers in an airplane????? Especially when punch cards and 8 inch floppy disks were state of the art. |
On May 14, 1:15 am, frank wrote:
On May 13, 3:50 am, "Ken S. Tucker" wrote: On May 13, 1:03 am, frank wrote: On May 12, 5:13 pm, Andrew Swallow wrote: Ken S. Tucker wrote: [snip] For instance using ADC (Analog to Digital) and DAC (Digital to Analog) converters going into an Elektronic Brain....was nearly sci-fi. It still is sci-fi. Although nowdays it is the analog side they do not know about. Andrew Swallow Not really. We were collecting analog data as late as early 90s. Some were doing digital , most data was analog. Had to do conversions, did that on tape systems, read analog tape, created digital tape, ran digital tape as input to computer systems. I don't know if they do digital data recordings directly, now, would make sense but there are reasons not to do it. you can get higher frequency of data with analog data. highest was FM, could get 1000 samples / sec. Real interesting looking at realtime data. Usually wouldn't print it until right at where you needed data. Recorders spit out tons of thermal paper. Fun to watch. Vast majority was 20 samples / sec at most, which was fine for analog. I had some data requirements at 10000 cycles / sec, what they did was run it at 10th of the speed it was recorded at. For some reason, analog to digital was a 1:1 time write to tape. One hour of data took one hour to convert to digital record. Then we had to run the digital tape through some other programs to make sense of it all. Usually was just a voltage point. Conversion created say acft, tail, flight #, date, time, mach #, alt and whatnot. Lots of the conversion literally was a patch board hookup. Flight data reels in raw format were probably an inch, inch and a half wide, weighed about 50 lbs. One wasn't bad, two were real strain to carry. Most fighters had one tape recorder. Easier to do analog data right off of transducers. Let me guess, corrections invited. Today, software and computer enhanced flying is well known to a military pilot. (The rumor that the F-22's crossing the International dateline caused the computer - via software glitch - to crash is a typical example). In a sense, software removes pilots burden. When was software first used? I'm guessing it was 1st used to automatically control the F-111 wing sweep. Ken Good question. Incidentally, there was a problem in the F-16, I think early mid 80s. OK, remember all your trig? Yeah, the class you never though made sense. Had some function, was something divided by cosine of heading, and something else divided by sine of heading. You guessed it. When they hit due north, system went nuts. There was a reason they taught us division by zero didn't work. Would fly great then just go nuts. Took a while to figure that one out. Fix was if you went to something divided by zero enter some other function into it. Yes, the heading indicator needed to go from due North to due South, going over the North pole. It's peculiar to using "spherical coordinates" with latitude using 180 degrees and longitude using 360. (I have a program on that, I'll look it up). I think guidance and control was the initial area. IF you ever studied aero engineering, that was the course that would kill your prospect for a degree. Yeah, in the real world, all those formulas were really used. Honest. Except in the real world, you programmed it, not solving it by hand to get all the sub sub sub sub scripts right. Been there, did that, you know what I'm talking about. Yes, an Array like A(a,b,c,d). Once the array variables are properly defined, it really becomes straighforward, but documentation is the key. The more complex the systems, the more problems crop up. Some aren't found for years. Then the active AF comes back and screams that its broke and it needs to be fixed. Keeps flight test funded anyway. Its not like we broke it on purpose. Sometimes we sent it out knowing we couldn't figure something out. B-1 had nose wheels getting stuck up in flight. Every airplane probably has something. Fly by wire in 80s was when computers really came into their own. Some like the X-29 were all computer controlled. Forward swept wing. Test pilots said it was real smooth. Feedback was something like 50 times a second. You would say fly to this point, it would do it smoothly even in turbulence. Early B-1A crash, #059 was due to going to test point high speed at 200 ft, wings swept back. When wings went back, all the weight in the wings caused CG to go aft, once it pitched beyond limits, nose went up, then everything went South real fast. Couldn't move fuel fast enough to get over it, departed controlled flight. There was a FCGMS Fuel Center Gravity Management System but it was turned off. That was upgraded, pretty much harder to turn off. Spent a lot of time on stability with vanes on nose of a/c and TF and other stuff. That was a sad experiment. IIRC it was called pilot error. Reminds me of the the F-23 excursion, the fly by wire is good, but has limitations, imposed by flight dynamics, like if it's too tail heavy, the horizontal stabilizer over-shoots, and complex oscillations set in. The horizontal stabilizer near a stall condition, drags and so on. About mid 80s lots more TF or TA (terrain following, terrain avoidance) showed up. Some were tied to altimeter, keep this distance to ground, some looked ahead worked on some sort of mapping data to figure where they were going. Some were IR systems instead of RADAR. That got tied into autopilot. Big deal to convince somebody to fly 200 ft at .85 Mach and say, trust me it works. I think that was lowest limit, at least what we used. Heard Tornado pilots were absolutely insane. Then again they were RAF and sort of didn't have to follow our regs. Were supposed to, but its their airplanes. Heard all sorts of stuff about those guys being just no fear at all. USAF used to be higher faster farther, they were pretty much lower & faster. Watched some video of Tornadoes during Iraqi war, it looked like them guys were blowin' dust off the sand, bet the occasional guy went to 30'. Once you put computers in airplanes, data increased a lot. B-1 had I think 6000 possible data points. Not all used at once, not all in one airplane. Usually 200 or so realtime in a flight test, others post flight. By the time AC-130U and MC-130H showed up, they were up to 80,000 parameters. Instrumentation Engineers went insane. Then again, they could add stuff all over the airplane. Pretty much all digital. Literally took 8 hours to run the program to set up what you were looking for off the airplane for each flight test, this was to determine what parameters to look at from the data stream. Data for instrumentation sort of was like swiss cheese. Think parameters in columns, rows were calibration coefficients, thickness was flight number. Insane. Even decades later. Stole it from AEC or whatever it turned into. F-22 wanted 2 Gb / second data rate, sent to I think 5 locations real time, ability to quick look at data instead of strip charts. No ARIA following it. Forgot how many parameters. Some high data rate. Usually used 20 samples / sec or less (1991 anyway). That was what RADAR was set to capture data at. Cameras also, so if you merged RADAR, camera with other data it all fit at 20 samples / sec. Engineers would slice and dice data depending on what they were doing tests on. wing sweep was set initially with a level. Only had a few settings. Wasn't like you could do 12 degrees, 13 degrees. Was like 15, 30, 67. On B-1 both wings were at same setting. F-14 had problems where one was say 50 , one was 15. Real emergency to get it down. That eventually got fixed, but don't know the details. Don't know if F-111 would have that problem. But, it had other problems to solve. Big one was fatigue on wings moving in flight. Lost more than a few with wings coming off. GD eventually solved that but it was pulled when sent to Vietnam pretty quickly. Got a real reputation as a problem child until Desert Storm and the Libyan raid. Considering how far we went with from pretty much levers and all that to hydraulic controls to computer controlled, its nothing short of just amazing. Obvious when you look back, at the time pretty much computers in an airplane????? Especially when punch cards and 8 inch floppy disks were state of the art. On behalf of the NG, thanks for the post Frank. For me, it was about 1975 (22yo slow learner) when I had a "holy ****" moment and realized analog had pretty much run it's course but digital was unlimited, which I think is still true. Once IC's (including OP amps and ADC's) got reliable and cheap enough that I could buy 1 for a couple of $'s, the digital revolution had already begun. Regards Ken |
"Pentagon Wants Kill Switch for Planes" | Jim Logajan | Piloting | 24 | June 16th 08 03:27 PM |
Spinner strobing as a "Bird Strike Countermeasure" | Jim Logajan | Piloting | 259 | December 13th 07 05:43 AM |
Spinner strobing as a "Bird Strike Countermeasure" | Jim Logajan | Home Built | 212 | December 13th 07 01:35 AM |
"British trace missile in copter strike to Iran" | Mike[_7_] | Naval Aviation | 8 | March 10th 07 08:20 PM |
"Pentagon Command Shuffle Rekindles Equity Debate" | Mike | Naval Aviation | 1 | January 26th 07 03:04 PM |
