![]() "bildan" wrote in message ... The interest for me is a sailplane installation where AOA is a performance issue in addition to a safety issue. My glider can be flown at 1000 pounds up to 1433 pounds gross weight and spends a lot of time in 2G turns thermalling. The AOA for minimum sink is always the same but the airspeed at which that happens changes a lot. The same thing with best L/D. A very 'slippery' glider takes a while for the airspeed to settle down after a pitch change. Flying to an exact AOA would be easier than chasing airspeed. An AOA indicator that shows minimum sink and maximum L/D as well as stall would be quite useful. Bill, I tatally agree! It would also be nice to have the AOA measure units instead of degrees and be calibrated so to give the same readings for max L/D and Min Sink at all flap settings. When I was flying A-6 Intruders 21 units of AOA was the Max Range value (best L/D) at all flap settings. I don't believe you can develop an effective unit for aircraft with flaps without integrating the flap setting into the system. This requires knowing the performance curve for each setting in order to calculate a single Max L/D (Max Range) indicator reading and a single Min Sink (Max endurance) indicator reading. This isn't as simple of a problem as some seem to think it is. Wayne HP-14 with flap settings from -5 to +90. http://www.soaridaho.com/Schreder |
On May 14, 7:30*pm, "Wayne Paul" wrote:
"bildan" wrote in ... The interest for me is a sailplane installation where AOA is a performance issue in addition to a safety issue. My glider can be flown at 1000 pounds up to 1433 pounds gross weight and spends a lot of time in 2G turns thermalling. *The AOA for minimum sink is always the same but the airspeed at which that happens changes a lot. *The same thing with best L/D. A very 'slippery' glider takes a while for the airspeed to settle down after a pitch change. *Flying to an exact AOA would be easier than chasing airspeed. An AOA indicator that shows minimum sink and maximum L/D as well as stall would be quite useful. Bill, I tatally agree! *It would also be nice to have the AOA measure units instead of degrees and be calibrated so to give the same readings for max L/D and Min Sink at all flap settings. * When I was flying A-6 Intruders 21 units of AOA was the Max Range value (best L/D) at all flap settings. *I don't believe you can develop an effective unit for aircraft with flaps without integrating the flap setting into the system. *This requires knowing the performance curve for each setting in order to calculate a single Max L/D (Max Range) indicator reading and a single Min Sink (Max endurance) indicator reading. This isn't as simple of a problem as some seem to think it is. Wayne HP-14 with flap settings from -5 to +90.http://www.soaridaho.com/Schreder Yes, there would have to be additional hardware/software to do it with flaps. But, as long as the AOA system knew what flap setting was being used, it could still display AOA data for that flap polar. Of course, a continuously variable system like yours could be complicated. To simplify the system, min sink is only of interest at thermalling flap settings and best L/D only at zero flap. (I'm guessing if you are in negative flap, you're not interested in flying at best L/D.) Also, the newer airfoils have made non-flapped gliders just about as good as flapped ones so the flap issue may be becoming moot anyway. It could be that a glider without flaps but flown with the precision possible with an AOA indicator might not be at much of a disadvantage. |
Prop angle of attack vs age | sid | Piloting | 47 | July 13th 08 04:46 PM |
Glider angle of attack indicator by SafeFlight | Bill Daniels | Soaring | 53 | December 20th 07 12:29 PM |
Angle of attack | Bill Daniels | Soaring | 27 | December 19th 07 06:17 AM |
preferrred bank angle indicator? | Matt Herron Jr. | Soaring | 34 | July 10th 06 02:22 PM |
Lift and Angle of Attack | Peter Duniho | Simulators | 9 | October 2nd 03 10:55 PM |
