On May 21, 10:21*am, wrote:
One quick question, will a motorcycle chain system work for a prop? Hey Canuck, Where-the-hell you been for the last 106 years? Take a look at a few old photos and you'll see the answer to your question. Now before everyone assumes that they know where I'm going with this response, let me dispell a few myths: 1. it was NOT a bike chain. It was a #35 solid-link chain made by Diamond. Two props means only 5.75hp per prop, so the #35 was the correct size for our two brothers from Ohio (same size would work well on a go-cart). 2. The two biker-brothers from OH were NOT the only ones to use a chain PSRU successfully. Ben Epps did it in 1907. And some Italian did it in the teens. Never did identify that plane, but it was a flying- boat with a high-mounted chain-driven prop. 3 Tortional (sp??) vibration would be a serious issue if you don't know about the working solution for it. That being a prop-shaft made of spring-steel. Think tortion-bar suspension. Wil and Orv discovered this the hard way by cracking two sets of tubular prop-shafts before treking back home and making a suitable replacement. (Oh yea, don't forget to squirt a little "Arnstein's tire cement" on the threads of your shaft nuts or they'll come loose.) Now would a modern motorcycle chain work? You bet. Would it be really heavy? You bet. Could you find a suitable airframe that would handle the weight, deal with the vibes, and last a reasonable amount of time? Hmmmm. One thing is certain about chains though. They typically draw 1-3% of the engine's power. A belt is usually 5-15%. That's why you don't see too many belt-driven bicycles out there. If it were me, I'd be inclined to try two B&S Vanguards driving outrigger-props via chains or serpentine belts on a test-bench just to see what I could get. Probably a waste of time, but we are here to experiment. Too bad all of the small I/C diesels are rediculiously expensive and super-heavy. Hey Euro-pilots, got any small diesels that might work with direct- drive? No dice here in the States. Diesel here equals truck. Harry |
Dear Canuck,
Please accept my sincere apology for my unfair assumption (and for Harry's too) that everyone in the whole wide world is balanced on the razor's edge of Aviation History. Harry has paid his dues, however. Perhaps he will point us toward some pictures. The Wright's 'Flyer' is surprisingly up to date for anyone interested in low-cost flight. Not a very good example, however, but given the era it's surprising how much we can learn from their efforts. The lubrication problem is common to all chain drives: you need to get the lubricant down around the bar which supports the roller, rather than on the roller itself. At one time Chain Drive was considered the cat's meow when it came to trucks, cars and other vehicles. And still is! (Ever seen the equipment used in a modern lumber mill? They've got a kind of straddle-lifter that will make a believer out of you when it comes to chain-driven vehicles. Modern chains impregnate the bar (which probably has a more appropriate name) with 'solid lubricant,' which I take to mean Tungsten Disulfide or similar. Also note the amount of work a chain absorbs, as compared to a belt drive. There is also rope drives (!!) which I suggest we reserve for Emergencies Only. Mention 'chain drive' and almost everyone knows what you're talking about, even though real chain, such as used for pulling a truck out of the mud, is also used, typically in chain hoists and the like. But most folks accept 'chain drive' as meaning the roller-chain common to bicycles, motor cycles, AIRPLANES and so forth. Motor cycle engines AND their chain drive, was fitted to a number of gliders and sailplanes in the 1930's. There's no reason to think we've seen the last of such conversions in the Twenty-First Century, although we'll probably see a v-twin industrial engine replacing the motorcycle engine. Why? Because it's blower driven cooling system allows it to be submerged within the fuselage. Someone has even suggested a twin-engine version, one pushing the other pulling, which is pretty smart thinking, in that with both engines on-line you would have plenty of thrust for take-off. Shutting down one of the engines -- and allowing the prop to self-feather -- would allow you to cruise on the remaining engine. Indeed, such a system may offer a significant advantage with regard to price when compared to a larger engine and a PSRU. -R.S.Hoover |
On May 22, 12:06*pm, Bob wrote:
Dear Canuck, Please accept my sincere apology for my unfair assumption (and for Harry's too) that everyone in the whole wide world is balanced on the razor's edge of Aviation History. No harm here gentlemen, I'm too old and all us Canadian lads are a tough bunch, skin like a rhino. Actually guys I am aware of the Wright brothers but surely what they did has no relevance here! I believe it was Quad city UL's or at least someone who still supplies chains as a PRSU for rotax (i]'ll track down a link). Also Kitplanes had a great article of a guy using a Japanese crotch rocket bike motor with a chain drive off the original sprocket to drive a prop quite a bit above the engine. He ran 10000 rpm and shifted his tranny for different flight regimes. I was caught up in the discussion about doing a plane extremely cheap. Chain drives and sprockets, pillow blocks, cheap shafts, and everything needed to build a prsu are available and salvagable from dead machines. A discussion of the merits of the different pulley and belts is nonsense for a guy in Siberia, Central China and the Himalayan foothills. Motorcycles and chain driven small farm machines are EVERYWHERE on this planet in the third world. |
On May 22, 10:17*am, wrote:
On May 21, 10:21*am, wrote: One quick question, will a motorcycle chain system work for a prop? Hey Canuck, Where-the-hell you been for the last 106 years? Take a look at a few old photos and you'll see the answer to your question. Now before everyone assumes that they know where I'm going with this response, let me dispell a few myths: 1. it was NOT a bike chain. It was a #35 solid-link chain made by Diamond. Two props means only 5.75hp per prop, so the #35 was the correct size for our two brothers from Ohio (same size would work well on a go-cart). 2. The two biker-brothers from OH were NOT the only ones to use a chain PSRU successfully. Ben Epps did it in 1907. And some Italian did it in the teens. Never did identify that plane, but it was a flying- boat with a high-mounted chain-driven prop. 3 Tortional (sp??) vibration would be a serious issue if you don't know about the working solution for it. That being a prop-shaft made of spring-steel. Think tortion-bar suspension. Wil and Orv discovered this the hard way by cracking two sets of tubular prop-shafts before treking back home and making a suitable replacement. (Oh yea, don't forget to squirt a little "Arnstein's tire cement" on the threads of your shaft nuts or they'll come loose.) Now would a modern motorcycle chain work? You bet. Would it be really heavy? You bet. Could you find a suitable airframe that would handle the weight, deal with the vibes, and last a reasonable amount of time? Hmmmm. One thing is certain about chains though. They typically draw 1-3% of the engine's power. A belt is usually 5-15%. That's why you don't see too many belt-driven bicycles out there. If it were me, I'd be inclined to try two B&S Vanguards driving outrigger-props via chains or serpentine belts on a test-bench just to see what I could get. Probably a waste of time, but we are here to experiment. Too bad all of the small I/C diesels are rediculiously expensive and super-heavy. Hey Euro-pilots, got any small diesels that might work with direct- drive? No dice here in the States. Diesel here equals truck. Harry Geschwender used the Morris Hy-Vo chain in his redrives, and they worked well. That chain has teeth that engage sprockets that look like gears instead of sprockets, and as the chain curves onto the sprocket the teeth spread and get tight between the sprocket teeth so there's no slop. See http://www.alternate-airpower.com/ and http://www.fairmont-mn.com/altpower/psru.html Dan |
"Anthony W" wrote in message
... wrote: Geschwender used the Morris Hy-Vo chain in his redrives, and they worked well. That chain has teeth that engage sprockets that look like gears instead of sprockets, and as the chain curves onto the sprocket the teeth spread and get tight between the sprocket teeth so there's no slop. See http://www.alternate-airpower.com/ and http://www.fairmont-mn.com/altpower/psru.html Dan Ford used a set up like this in the transfer case on some 4 wheel drive trucks so the parts could be available that way... Tony I have heard that GM did as well, and possibly others. However, I have not seem tham apart, not studied their manuals. Peter |
![]() "Anthony W" wrote Ford used a set up like this in the transfer case on some 4 wheel drive trucks so the parts could be available that way... The problem there is that both sprockets are the same size, so no prop speed reduction, there. I don't know about all of the Chevy front wheel drive cars, but I think they use hy-vo chains on them. I know the Chevy Citation automatic transmission used them. I had one fail, after it was side loaded in a collision. -- Jim in NC |
Morgans wrote:
"Anthony W" wrote Ford used a set up like this in the transfer case on some 4 wheel drive trucks so the parts could be available that way... The problem there is that both sprockets are the same size, so no prop speed reduction, there. I don't know about all of the Chevy front wheel drive cars, but I think they use hy-vo chains on them. I know the Chevy Citation automatic transmission used them. I had one fail, after it was side loaded in a collision. I never had the Ford that I had apart so I can't say for sure but odds are if someone really wanted to go that route, you could scrounge up sprockets of various sizes. I'd rather use a Harley belt primary drive. It's an off the shelf set up that would require minimal machining to adapt to the purpose. Off the top of my head, I'd say the reduction is better than 2 to 1 and replacement belts can be purchased in any city in North America if you didn't want to bother with mail order. Tony |
![]() "Anthony W" wrote I'd rather use a Harley belt primary drive. It's an off the shelf set up that would require minimal machining to adapt to the purpose. Off the top of my head, I'd say the reduction is better than 2 to 1 and replacement belts can be purchased in any city in North America if you didn't want to bother with mail order. I had thought the same thing before, also. I've never priced that type of thing, before. Are prices reasonable? Probably not, I'm thinking. -- Jim in NC |
Morgans wrote:
"Anthony W" wrote I'd rather use a Harley belt primary drive. It's an off the shelf set up that would require minimal machining to adapt to the purpose. Off the top of my head, I'd say the reduction is better than 2 to 1 and replacement belts can be purchased in any city in North America if you didn't want to bother with mail order. I had thought the same thing before, also. I've never priced that type of thing, before. Are prices reasonable? Probably not, I'm thinking. Define reasonable. No not cheap new but you can find complete belt primary drives used on eBay when the hotrodders are swamping them out for the 3.5 and 4" belts for the custom engines. The 3.5 and 4" belt setups are running about $1500 and probably not worth it for what we're talking about. These belts are for engines that run over 100 BHP peak and the riders of these bikes can be very abusive when doing burnouts and drag racing. Tony Tony |
A Camcorder for Homebuilders | [email protected] | Home Built | 3 | June 1st 08 03:27 PM |
Mexico City - Homebuilders ... | ......... :-\)\) | Home Built | 2 | February 7th 05 12:04 PM |
Is this the place for Homebuilders? | Gilan | Home Built | 2 | September 23rd 04 02:06 PM |
NPR Segment on Elderly Homebuilders | Jay Honeck | Piloting | 0 | May 29th 04 11:32 PM |
Best Homebuilders Books? | [email protected] | Home Built | 5 | January 21st 04 01:06 AM |
