On May 25, 7:44*pm, "BT" wrote:
are they using different antenna? did you notice a power problem in the glider? Maybe you flew through and area of GPS Jamming. Different Jamming techniques will do different things, from totally denying reception of GPS signals.. to tweaking the reception to make you think you are going one way.. when the GPS is actually taking you off track wrote in message ... On my last two flights at Marfa Texas May 24 and May 10 I have lost GPS navagation fixes for a few minutes on both flights. *I have two GPS receivers (cambridge GPS/Nav and a lx-7000) both units lost their fix at the same time and came back together. *Both flights are up on the OLC if you want details. *Anyone else have the same experience? Is it anything I can fix? Bill Snead 6W- Hide quoted text - - Show quoted text - The two units have seprate antennas. The atmospheric pressure trace was not effected. The units kept working (displays were on just no nav info). I think the power was OK. Bill Snead |
Did you check the GPS Nav Center from USCG? They put up advisories on
GPS testing. They look like this: http://www.navcen.uscg.gov/gps/gpsno...terference.pdf If any of the testing areas are close, you have an answer. If there was a magnetic storm, it could explain it, too - see space weather (I doubt it right now, the sun is very quiet). They also have prediction of dop - dillution of precision, or accuracy, at http://www.navcen.uscg.gov/gps/pdop.htm (lower is better). If you report your gps problem at http://www.navcen.uscg.gov/gps/default.htm, they will generally get back to you and tell you why there was a problem. Dan On my last two flights at Marfa Texas May 24 and May 10 I have lost GPS navagation fixes for a few minutes on both flights. *I have two GPS receivers (cambridge GPS/Nav and a lx-7000) both units lost their fix at the same time and came back together. *Both flights are up on the OLC if you want details. *Anyone else have the same experience? Is it anything I can fix? Bill Snead 6W- Hide quoted text - |
US, Retrieve Cell service getting worse, Analog service disappearing. | chris | Soaring | 10 | December 24th 07 11:50 PM |
