Bamboo Propellers
Old May 27th 09, 02:17 AM posted to rec.aviation.homebuilt
Brian Whatcott
Default Bamboo Propellers
Ron Webb wrote:
I lived on the island of Guam from 1985 thru 1988. One of the things I noted
there was that if you went down to the lumber yard, the 2x4's you got would
be straight grained Phillipine mahogany. And it was cheap!
I've sometimes wondered if it would be profitable to travel to Guam, or the
Phillipines, or wherever, and put together a big platform consisting of
nothing but the most valuable wood at hand, then mount a GPS, a satellite
phone, and a set of sails controlled by computer. Tell the thing to sail
itself to L.A. or wherever, and call me when you're close...then sell all
that beautiful wood...
What an imaginative idea. I know there is a certain class of folks who
already make surface submersibles (only the snorkels show...)
but they keep them crewed, and run a diesel to get them to the US with
their valuable aromatic or sensory modification goods.
Brian W
Old May 27th 09, 08:28 AM posted to rec.aviation.homebuilt
Veeduber[_2_]
Dear Brian (and the Group),
If you are familiar with trans-Atlantic flights of model airplanes...
or of the campus-to-campus flights of model airplanes buzzing along a
carefully pre-planed flight-path between Miami and Boston, the
following will not come as a surprise.
The original Varieze was meant to be powered by a VW... and would have
been far more successful, in my opinion, had they used my engine
instead of Ted's. Water under the bridge and so forth. However, some
diligent gentlemen from south of the border have apparently been
making flights north of it in un--manned Variezes using VW engines
with the prop on the proper end of the crank. One of their flight
paths is said to be from the strip at the LA Bay junction to one of
the WWII air strips out in the Mohave, where control is transferred to
a local transmitter for landing. Once on the ground the cargo is
removed, the bird refueled and sent back south. Another flight path,
said to be the original, was from a strip in Sinaloa to a stretch of
highway in Arizona, the move to Baja and the Mojave the result of
inter-tribal warfare.
All just Hobby Shop rumor, of course. Or rather the product of
several hundred rumors about home-built RPV's heard but not seen as
they putter their merri way back & forth at zero altitude, delivering
Ami-Rica's most popular yarb at a hundred keys per trip. And if they
lose one now & then it's no big deal. VW engines are cheap and so are
N7EZ's if you don't have to worry about a canopy nor any human flight
controls.
-R.S.Hoover
Old May 27th 09, 12:14 PM posted to rec.aviation.homebuilt
Dana M. Hague[_2_]
On Wed, 27 May 2009 00:28:42 -0700 (PDT), Veeduber
...However, some
making flights north of it in un--manned Variezes...
Hmmm, "back in the day" I recall discussing the possibility of such
flights in a VariEze, which would naturally have a very low radar
signature. The idea was to paint it black, except for weird
phosphorescent shapes on the underside, and a small black light
mounted under the aircraft to light them up. The idea was that even
if anyboby _did_ report such a strange apparition crossing the border,
he wouldn't be believed...
-Dana
When you get it right
mighty beasts float up into the sky
When you get it wrong
people die
-Roger Bacon (c1384)
Old May 28th 09, 02:25 AM posted to rec.aviation.homebuilt
Brian Whatcott
controls.
-R.S.Hoover
Ha! I had heard about the trans-Atlantic trips (and maybe some
Trans-Pacific endeavors too,) but the inter campus express had passed me by.
But in that connection, I can tell you about a hardware equivalent to
the hugely successful Open Software movement, GNU, copyleft, and all
that good stuff.
It focusses on a little microcontroller card called the Arduino,
of which the current implementation is called the Duemilanuove
(Italian for "2009") It is about 2 X 2 inches.
This has attracted a large active following from
people who make things. It has a USB socket for power and downloading.
A FREE soft development capability on your PC. Hundreds or thousands
of applications in software - available cards for expanders and whatever.
And the good news is - the entry price for the whole shebang is under
$50 - and you will be testing an on board flasher you programmed and
compiled, on the first day you get it. It has AtoDs DtoAs, DOs DIs
a k or two of memory for code, etc, etc....
The reason I gushed on about this is that I stumbled on it when reading
about a drone (RPV) autopilot, wing leveler, GPS waypoint follower -
with smooth switchover to radio control. This is the Ardupilot.
Around $100 basic.
Less than $500 gets the controller, the servoes the GPS the
application, the custom PCB, an IR horizon wing leveler and pitch
controller. Oh, and the model electric plane and RC gear to try it out with.
First batch sold out....
http://blog.makezine.com/archive/200...le_uav_co.html
or in tiny format:
http://tinyurl.com/pqz2ev
Ardupilot home page
http://diydrones.com/profiles/blog/s...ogPost%3A44814
or in tiny format:
http://tinyurl.com/5g5gho
Amazing!
Brian W
Old May 28th 09, 09:54 PM posted to rec.aviation.homebuilt
Veeduber[_2_]
On May 27, 6:25*pm, Brian Whatcott wrote:
Brian said...
Ha!
....and later on...
Amazing!
Well... Ha! right back atchew :-)
(and tanks for the URL's)
I first mentioned the 'Roll Yer Own RPV' 'way back when sometime...
back before the Big C came to call. The typical response was from
Good Ol' Boyz telling me all the reasons why it couldn't be true,
which generally boiled down to the fact they'd never heard of it
before.
Among the reasons why it wouldn't work was the 'fact' that every one
of those 'mystery' aircraft penetrating American air space was being
tracked by FLIR-equipped helicopters, so that by the mystery airplane
touched down, there was a reception committee there to meet it.
Not so. Because APPARENTLY each of those mystery airplanes was NOT
carrying anything besides extra fuel. So let's say ten drones cross
the border. Their flight path takes them through a populated area
where they are VISUALLY checked to see if they are being followed. If
they are, the flight path is re-programmed and eventually returns home
without ever touching down. Or it may be carrying external tanks,
dropped near downtown Sage, California. (Lookitup :-)
The guy on the ground with the sound-tracking FLIR is the 'cleaner.'
His job is to look for anything-anyone following the Mystery
Airplane. If the answer is 'yes' it simply turns around and goes
home. But the truth is, we don't have enough aerial assets to track
each Mystery Airplane 100% of the time.
But the very BEST of the Good Ol' Boy reasons is that Messicans just
aren't smart enough to run 'something like that.' Meaning the Good
Ol' Boys aren't bright enough to appreciate the problem.
Personally, I think it's funny as hell :-) Because as soon as someone
underestimates the problem, they've lost the war by default.
-R.S.Hoover
Pills & Propellers [email protected] Home Built 15 December 3rd 08 01:16 PM
Wooden Propellers Danny Deger Piloting 11 March 4th 07 10:17 AM
Propellers [email protected] Home Built 6 March 30th 06 01:41 PM
Bamboo bomber lost. JDupre5762 Military Aviation 4 May 10th 04 07:04 AM
AT-10 "Bamboo Bomber" Question [email protected] Military Aviation 4 March 18th 04 09:13 PM
