Darryl Ramm wrote:
On Jun 2, 5:09 am, "Ken Kochanski (KK)" wrote: Good Morning, How does SeeYou calc wind speed and direction when you are reviewewing flight logs. I notice the wind shifts direction and velocity ... even while running ridges ... so I assume it is not using some measurement of drift while thermal-ing ... KK It depends on the IGC file, there may be TAS data in the file or wind vectors in the K-record in the IGC file. This has been discussed here in the past. For a plain IGC file SeeYou can only use circle drift. Darryl From the SYM manual: Wind is calculated using three methods in SeeYou Mobile .. Position drift when Lat/Lon are the only available data .. Groundspeed difference when groundspeed and track are received from the GPS .. Combination of Groundspeed and straight flight when true air speed is received from the instrument. In this case, the wind is updated in straight flight as well. |
On Jun 2, 7:39*pm, Ray wrote:
Darryl Ramm wrote: On Jun 2, 5:09 am, "Ken Kochanski (KK)" wrote: Good Morning, How does SeeYou calc wind speed and direction when you are reviewewing flight logs. I notice the wind shifts direction and velocity ... even while running ridges ... so I assume it is not using some measurement of drift while thermal-ing ... KK It depends on the IGC file, there may be TAS data in the file or wind vectors in the K-record in the IGC file. This has been discussed here in the past. For a plain IGC file SeeYou can only use circle drift. Darryl *From the SYM manual: Wind is calculated using three methods in SeeYou Mobile . Position drift when Lat/Lon are the only available data . Groundspeed difference when groundspeed and track are received from the GPS . Combination of Groundspeed and straight flight when true air speed is received from the instrument. In this case, the wind is updated in straight flight as well. You are quoting the SeeYou Mobile documentation, the question was for SeeYou. It is not what was received from the GPS but what is in the IGC file. And don't assume because some logger has or gets certain data it is going to write it to the file. e.g. The C302 will often output very nice TAS data on NMEA but does not log it to it's own IGC file (but SeeYou Mobile will log the TAS data to it's IGC flight log file if it is being driven from that C302). Also just be cautions looking at the wind vector, it can appear to jump around but have very low values even when driven by not really meaningful data. I may be wrong on what I said on the K-record with wind direction/ speed data. SeeYou does just seem to be ignoring that. Seems a bit stange to do that if SeeYou Mobile bothers to write them in the first place to an IGC file. Darryl |
Vector Wind, Relative Wind calculation C 302/303 | [email protected] | Soaring | 2 | December 9th 08 07:23 PM |
SeeYou and wind | GARY BOGGS | Soaring | 4 | April 24th 08 02:17 AM |
Seeyou NMEA to Winpilot/Seeyou | Jean | Soaring | 4 | June 3rd 06 11:38 AM |
Three leg GS to TAS calculation | Mike Rapoport | Owning | 21 | September 12th 04 04:37 AM |
LX4000 wind calculation | AttentionLEcureuil | Soaring | 2 | June 23rd 04 04:33 AM |
