On Jun 9, 9:47*am, Veeduber wrote:
To All: Recent posts about the Pobjoy radial engine have generated a number of private messages which indicate some subscribers to this Newsgroup lack a basic understanding in how the Internal Combustion engine actually works. *For example ALL engines have some degree of overlap in their cam timing. *If you have a text book that says otherwise, it is in error. The reason for this overlap is fairly simple: *The incoming fuel/air charge has mass and all mass has inertia. *If the cam did not open the intake valve until TDC there would be no in-flow of the fuel-air charge until several degrees of crankshaft rotation AFTER the valve opens because it takes that long for the difference in PRESSURE between the combustion chamber and the inlet manifold to overcome the inertia inherent in the fuel/air charge. By the same token, the exhaust valve must remain OPEN for several degrees past TDC for the pressure in the combustion chamber to fall to a value equal to or less than that of the inlet manifold. *Without that difference in pressure there can be no flow. The amount of overlap determines the engine's maximum rpm. *If you want an engine that turns 6,000 rpm, it would have to have an appreciable amount of overlap. The opening and closing of a valve takes the SAME amount of crank rotation, regardless of the speed of the engine. *Factors that effect the RATE at which the valves open or close is the MASS or weight of the components in the system, meaning the tappet, push-rod and valve, as well as the strength of the SPRING, the tension of which must be overcome in order to OPEN either valve. *And of course, if you want the valve to CLOSE quickly, you will need a stronger spring, *but you must pay for that greater strength upon opening the valve. The thought that OVERLAP will cause some of the fuel/air charge to be drawn out the exhaust port is largely nonsense except for engines having a great deal of overlap -- too much to allow the engine to be installed in a normal car. This matter becomes significant with small aircraft engines, or any aircraft engine that drives the propeller directly. *For such engines the AVERAGE OVERLAP is 33 crankshaft degrees (14 on the INTAKE, 19 on the EXHAUST) but for some geared engines the overlap may be as much as 95 degrees. The R-Type Pobjoy used cam-rings giving an overlap of 15 degrees (4 on the intake, 11 on the exhaust). -R.S.Hoover |
![]() "Veeduber" wrote Factors that effect the RATE at which the valves open or close is the MASS or weight of the components in the system, meaning the tappet, push-rod and valve, as well as the strength of the SPRING, the tension of which must be overcome in order to OPEN either valve. And of course, if you want the valve to CLOSE quickly, you will need a stronger spring, but you must pay for that greater strength upon opening the valve. -R.S.Hoover I'm going to go out on a limb here Bob and say that the RATE of valve opening and closing is a function of RPM and cam lobe contour only. Mass of the valve train would primarily affect the max RPM attainable without destructive valve float. Tom |
On Jun 9, 8:35*pm, "Tom Wait"
wrote: I'm going to go out on a limb here Bob and say that the RATE of valve opening and closing is a function of RPM and cam lobe contour only. Mass of the valve train would primarily affect the max RPM attainable without destructive valve float. ------------------------------------------------------------------------------------------------------- Dear Tom, Not a problem. There's plenty of room on the limb for the two of us. (See my error as caught by Charlie.) With regard to the rate at which the valve opens, what I'm trying to say is that a valve train having greater mass will open more slowly than a valve train having less mass. The assumption here is that all else -- including the factor you've mentioned -- are equal. The object here was ways to increase Volumetric Efficiency, for which the rate at which the cylinder fills is a critical factor. According to Taylor (or possibly Litton) the shape of the combustion chamber, especially with regard to the shrouding of the intake valve, AND the mass of the valve train components, are the only ways of improving VE without going to super-charging. I can see where you're coming from with regard to RPM but as you must know, VE falls as rpm increases. The idea behind lighter valve train components is to allow more time for charging the cylinder at a given RPM. For the purpose of this exercise, RPM is fixed. So put away the saw -- there's plenty of room for the two of us on this branch :-) In a more serious vein, I apologize for stating my explanation so poorly. -R.S.Hoover |
Going back to some hot rodding roots,I believe V.E. was increased
in the late '60's-70's thru the use of a specially designed double cone affair placed in the collector pipe of a tuned exhaust system,which created a stronger vacuum effect , creating stronger scavenging of exhaust, and to some extent , helping draw more fuel/air mix into the cylinder. |
I believe that Ballenger Headers had the "pickle" located in the
collector of 4 tube equal length headers and there was also the "coanda" effect which is specifically what I think you were speaking of. It was used experimentally in a truly weird exhaust setup in the early days by of one of the major racing teams back in the mid 60s, but my memory is a bit foggy for specifics that far back, such as who or on what car, sorry. cmyr wrote: Going back to some hot rodding roots,I believe V.E. was increased in the late '60's-70's thru the use of a specially designed double cone affair placed in the collector pipe of a tuned exhaust system,which created a stronger vacuum effect , creating stronger scavenging of exhaust, and to some extent , helping draw more fuel/air mix into the cylinder. |
On Jun 11, 11:32�am, George wrote:
I believe that Ballenger Headers had the "pickle" located in the collector of 4 tube equal length headers and there was also the "coanda" effect which is specifically what I think you were speaking of. � It was used experimentally in a truly weird exhaust setup in the early days by of one of the major racing teams back in the mid 60s, but my memory is a bit foggy for specifics that far back, such as who or on what car, sorry. cmyr wrote: � �Going back to some hot rodding roots,I believe V.E. was increased in the late '60's-70's thru the use of a specially designed double cone affair placed in the collector pipe of a tuned exhaust system,which created a stronger vacuum effect , creating stronger scavenging of exhaust, and to some extent , helping draw more fuel/air mix into the cylinder.- Hide quoted text - - Show quoted text - You remembered the word I couldn't put my finger on........coanda |
![]() "cmyr" wrote in message ... On Jun 11, 11:32?am, George wrote: I believe that Ballenger Headers had the "pickle" located in the collector of 4 tube equal length headers and there was also the "coanda" effect which is specifically what I think you were speaking of. ? It was used experimentally in a truly weird exhaust setup in the early days by of one of the major racing teams back in the mid 60s, but my memory is a bit foggy for specifics that far back, such as who or on what car, sorry. cmyr wrote: ? ?Going back to some hot rodding roots,I believe V.E. was increased in the late '60's-70's thru the use of a specially designed double cone affair placed in the collector pipe of a tuned exhaust system,which created a stronger vacuum effect , creating stronger scavenging of exhaust, and to some extent , helping draw more fuel/air mix into the cylinder.- Hide quoted text - - Show quoted text - You remembered the word I couldn't put my finger on........coanda --------------------------------------------------------------------------------------------------------- Back in the 70s or so, there was a three cylinder two stroke radial, with all three cylinders in a common crank case - that used the exhaust system exclusively for scavenging the engine. There was no intake draft without it. It was featured on an ultralight one year at OSH. |
... Going back to some hot rodding roots,I believe V.E. was increased in the late '60's-70's thru the use of a specially designed double cone affair placed in the collector pipe of a tuned exhaust system,which created a stronger vacuum effect , creating stronger scavenging of exhaust, and to some extent , helping draw more fuel/air mix into the cylinder. There have been a number of things that improved VE: Generally, higher compression ratios help especially at higher RPM, roller tappets seem to withstand much faster ramp angles and can stay open further during the open part of the valve cycles, and anti-reversion cones in the exhaust are said to work very well in the mid-range of RPM for any given four cycle engine. In addition, intake and exhaust port shapes play a major role; as do other aspects of head ad piston crown design. In a nut-shell, there has been a lot of progress over the past three quarters of a century, and the only place that I can think of in which aircraft engines have led the way has been in the area that we used to call "blue printing" in which the ports are more carefully caste, machined, and finished to closely match the design drawings for the engine. Today, every late model engine that I have seen is done that way at the factory; but forty years ago, automotive engines were really crude. Peter |
On Thu, 11 Jun 2009 07:40:10 -0700 (PDT), cmyr
wrote: Going back to some hot rodding roots,I believe V.E. was increased in the late '60's-70's thru the use of a specially designed double cone affair placed in the collector pipe of a tuned exhaust system,which created a stronger vacuum effect , creating stronger scavenging of exhaust, and to some extent , helping draw more fuel/air mix into the cylinder. The anti reversion cone was a dirty fix for a crappy header design. Better than a manifold, but not as good as a proper "tuned" header. |
On Jun 11, 8:06�pm, wrote:
On Thu, 11 Jun 2009 07:40:10 -0700 (PDT), cmyr wrote: � Going back to some hot rodding roots,I believe V.E. was increased in the late '60's-70's thru the use of a specially designed double cone affair placed in the collector pipe of a tuned exhaust system,which created a stronger vacuum effect , creating stronger scavenging of exhaust, and to some extent , helping draw more fuel/air mix into the cylinder. The anti reversion cone was a dirty fix for a crappy header design. Better than a manifold, but not as good as a proper "tuned" header. As I recall, this system was on the cover of Hot Rod magazine, on a high end test vehicle,and was "scientifically" researched. In this instance the reference to a crappy header design would be wrong. |
Back to basics? | Ol Shy & Bashful | Piloting | 3 | September 2nd 08 09:45 PM |
airframe basics | Mike | Piloting | 6 | June 7th 06 04:37 PM |
Scratch Building Basics for Metal Aircraft DVD | jon | Home Built | 1 | March 28th 06 11:51 PM |
Learning piston engine basics | [email protected] | Owning | 9 | December 24th 05 09:19 PM |
Tent basics // Oshkosh prep | Mike Z. | Piloting | 35 | December 31st 03 10:54 PM |
