Jackie wrote:
I understand that ATC radar uses an encoding altimeter and a transponder operating with Mode C to determine an aircraft's altitude. Let's forget about Mode C for a moment and switch to Mode A only or just a primary return. If an aircraft is at 18,000 ft (approx 3 nm) and 3 nm away from the radar antenna, as seen on a map, how does the radar correct for slant distance when distance is displayed (e.g. using concentric circle distance markers on the scope or relative to a known distance, such as a marker on the display)? In other words how does the radar know that the aircraft is actually 3 nm away laterally and not 4.25 nm (approx slant distance at that altitude)? Absent something else, it doesn't. All a primary paint radar knows is azimuth and slant range. -- Jim Pennino Remove .spam.sux to reply. |
below the radar | Philip Stroh | Aviation Photos | 31 | November 27th 06 03:12 PM |
Integrating onboard weather radar data with satellite-fed Doppler radar | [email protected] | General Aviation | 3 | January 9th 05 08:57 PM |
Question about the F-22 and it's radar. | Scott Ferrin | Military Aviation | 128 | June 13th 04 01:23 AM |
Yet another "Radar Required" question. | Roy Smith | Instrument Flight Rules | 14 | April 27th 04 05:07 PM |
F15E Radar question. | Bill Silvey | Military Aviation | 5 | August 30th 03 06:17 PM |
