ATC Radar Question
Old June 12th 09, 03:22 AM posted to rec.aviation.piloting
Jim Logajan
Default ATC Radar Question
Jackie wrote:
If an aircraft is at 18,000 ft (approx 3 nm) and 3 nm away from the
radar antenna, as seen on a map, how does the radar correct for slant
distance when distance is displayed (e.g. using concentric circle
distance markers on the scope or relative to a known distance, such as
a marker on the display)?
Without altitude information from the pilot or a Mode C transponder, the
radar system can't extract the horizontal distance from the slant distance.
Where did you read that their systems correct for altitude without Mode C
transponders? If they could do that then they wouldn't have ever needed the
transponders to report altitude.
Old June 12th 09, 04:31 AM posted to rec.aviation.piloting
Jackie
So if a pilot turns his Mode C from off to on, does the radar then
correct the distance plotted (less distance from the antenna) based on
the altitude reported?
Old June 15th 09, 12:32 AM posted to rec.aviation.piloting
BT
I don't think that altitude from the ModeC is ever factored into where to
plot the target. The target was always slant range.
BT
"Jackie" wrote in message
distance. Where did you read that their systems correct for altitude
without Mode C transponders? If they could do that then they wouldn't
have ever needed the transponders to report altitude.
So if a pilot turns his Mode C from off to on, does the radar then correct
the distance plotted (less distance from the antenna) based on the
altitude reported?
Jackie
transponders?
I don't believe I indicated I read this.
Does precision approach radar require a transponder to report altitude?
Old June 12th 09, 11:22 PM posted to rec.aviation.piloting
Matt Barrow[_8_]
Jim Logajan wrote:
Jackie wrote:
If an aircraft is at 18,000 ft (approx 3 nm) and 3 nm away from the radar
antenna, as seen on a map, how does the radar correct for slant distance
when distance is displayed (e.g. using concentric circle distance markers on
transponders?
At the altitudes involved during approach, it's not so critical (altitude is,
but not the angle), but during
approach the heading data is as critical as the altitude reporting.
Old June 15th 09, 12:34 AM posted to rec.aviation.piloting
BT
reported altitude from a ModeC transponder is never used for vertical
guidance on a PAR approach.
"Matt Barrow" wrote in message
Jim Logajan wrote:
radar
distance
markers on
distance.
C
transponders?
is, but not the angle), but during
Old June 13th 09, 04:47 AM posted to rec.aviation.piloting
Bob Noel[_6_]
No.
The beauty of the PAR approach is the aircraft only needs a
functioning radio.
Old June 12th 09, 04:56 AM posted to rec.aviation.piloting
Jackie
Clark wrote:
Jackie wrote in
[snip]
PAR uses a height finder radar to provide sufficient vertical resolution for
precision approaches.
Could you elaborate on how the "height finder" works?
Old June 12th 09, 05:17 AM posted to rec.aviation.piloting
Bob Noel[_2_]
Jackie wrote:
Clark wrote:
Jackie wrote in
[snip]
resolution for precision approaches.
the elevation radar determines altitude the same way the azimuth radar
determines bearing.
Old June 12th 09, 08:20 AM posted to rec.aviation.piloting
Morgans[_2_]
determines bearing.
There are actually two radars running for PAR, right? One sweeping left to
right and one sweeping up and down, I think.
Jim in NC
below the radar Philip Stroh Aviation Photos 31 November 27th 06 03:12 PM
Integrating onboard weather radar data with satellite-fed Doppler radar [email protected] General Aviation 3 January 9th 05 08:57 PM
Question about the F-22 and it's radar. Scott Ferrin Military Aviation 128 June 13th 04 01:23 AM
Yet another "Radar Required" question. Roy Smith Instrument Flight Rules 14 April 27th 04 05:07 PM
F15E Radar question. Bill Silvey Military Aviation 5 August 30th 03 06:17 PM
