ATC Radar Question
Old June 19th 09, 10:31 PM posted to rec.aviation.piloting
Mike
Default ATC Radar Question
"Clark" wrote in message
"Morgans" wrote in :
"Bob Noel" wrote
the elevation radar determines altitude the same way the azimuth radar
determines bearing.
There are actually two radars running for PAR, right? One sweeping left
to right and one sweeping up and down, I think.
As far as I know you are entirely correct. The installations I've seen
(years
ago and far away) have two independent radar systems, one for the
horizontal
and one for the vertical. Of course I've only seen ancient technology and
I'm
sure that these days it could be done with one steerable beam.
Older PARs (which there are many still around) don't really have two
independent systems. They basically separate the radar signal between two
antenna (one for azimuth and one for elevation). Newer designs (which are
still quite old) use a phase array which steers the beam. In both designs
the transponder is neither required or used.
Old June 12th 09, 07:49 AM posted to rec.aviation.piloting
Stealth Pilot[_2_]
On Fri, 12 Jun 2009 03:54:29 +0000 (UTC), Clark
Jackie wrote in
[snip]
Does precision approach radar require a transponder to report altitude?
PAR uses a height finder radar to provide sufficient vertical resolution for
precision approaches.
Mode C only provides 100 foot altitude resolution. bzzzzt!
Mode C provides a height eg 1252ft which is deemed only accurate to
100ft because the calibration errors are limited to 100ft.
Old June 12th 09, 11:36 AM posted to rec.aviation.piloting
Bob Noel[_2_]
I believe that Mode C provides 100 foot altitude resolution because
the least significant bit is 100'
Old June 12th 09, 11:23 PM posted to rec.aviation.piloting
Matt Barrow[_8_]
"Stealth Pilot" wrote in message
Jackie wrote in
[snip]
And when local BARO is not available, the minimums go up.
And why the slop (calibration error) is taken into account when developing the
approach procedure.
Old June 15th 09, 12:33 AM posted to rec.aviation.piloting
BT
and that has nothing to do with Mode C accuracy
"Matt Barrow" wrote in message
Jackie wrote in
[snip]
for
approach procedure.
below the radar Philip Stroh Aviation Photos 31 November 27th 06 03:12 PM
Integrating onboard weather radar data with satellite-fed Doppler radar [email protected] General Aviation 3 January 9th 05 08:57 PM
Question about the F-22 and it's radar. Scott Ferrin Military Aviation 128 June 13th 04 01:23 AM
Yet another "Radar Required" question. Roy Smith Instrument Flight Rules 14 April 27th 04 05:07 PM
F15E Radar question. Bill Silvey Military Aviation 5 August 30th 03 06:17 PM
