ATC Radar Question
Old June 14th 09, 01:09 AM posted to rec.aviation.piloting
Jim Logajan
Default ATC Radar Question
"Matt Barrow" wrote:
"Jackie" wrote in message
I understand that ATC radar uses an encoding altimeter and a
transponder operating with Mode C to determine an aircraft's
altitude. Let's forget about Mode C for a moment and switch to
Mode A only or just a primary return.
If an aircraft is at 18,000 ft (approx 3 nm) and 3 nm away from the
radar antenna, as seen on a map, how does the radar correct for
slant distance when distance is displayed (e.g. using concentric
circle distance markers on the scope or relative to a known
distance, such as a marker on the display)?
In other words how does the radar know that the aircraft is
actually 3 nm away laterally and not 4.25 nm (approx slant distance
at that altitude)?
Asquared + B squared = C squared, I'd guess.
And how does it separate A and B?
"A" is the radar range, "B" is garnered from the encoding altimiter.
Nit: Actually "C" would be radar range and either "A" or "B" would be from
the altimeter, solving then for "B" or "A".
below the radar Philip Stroh Aviation Photos 31 November 27th 06 03:12 PM
Integrating onboard weather radar data with satellite-fed Doppler radar [email protected] General Aviation 3 January 9th 05 08:57 PM
Question about the F-22 and it's radar. Scott Ferrin Military Aviation 128 June 13th 04 01:23 AM
Yet another "Radar Required" question. Roy Smith Instrument Flight Rules 14 April 27th 04 05:07 PM
F15E Radar question. Bill Silvey Military Aviation 5 August 30th 03 06:17 PM
