#11
On Jun 13, 7:17*pm, Brad wrote:
On Jun 13, 5:55*pm, "Paul Remde" wrote: Hi, The IR port may very well be the problem. *The PDA may think that the sun is another PDA trying to talk to it through the IR port. *I show how to disable the IR port in training video #6 of my Pocket PC training. *You can see it hehttp://www.cumulus-soaring.com/train...TrainingCD-PPC Best Regards, Paul Remde Cumulus Soaring, Inc. "John Scott" wrote in message . .. I had a PDA mounted on the dash of my car that exhibited extreme slowness. I finally discovered it was due to the IR port trying to communicate with the sun. *I tried to turn it off in the software, but ultimately covered over the port on the top of the PDA with a small piece of *black electrical tape. Problem solved. I initially discovered this was the problem when I threw my hat over the unit in disgust and discovered that the perforance immediatly recovered. You can usually see the port flashig if you point it at a webcam and look at the resulting video on your computer screen. The webcam sensors are usually sensitive to IR. John Hi Paul, thanks for the video tip, I've turned off the beam function and will let you all know what I discover next time I fly. Cheers, Brad Please don't issue any stop commands while it's communicating with the sun. 9B |
![]() Andy wrote: On Jun 13, 7:17 pm, Brad wrote: On Jun 13, 5:55 pm, "Paul Remde" wrote: Hi, The IR port may very well be the problem. The PDA may think that the sun is another PDA trying to talk to it through the IR port. I show how to disable the IR port in training video #6 of my Pocket PC training. You can see it hehttp://www.cumulus-soaring.com/train...TrainingCD-PPC Best Regards, Paul Remde Cumulus Soaring, Inc. "John Scott" wrote in message .. . I had a PDA mounted on the dash of my car that exhibited extreme slowness. I finally discovered it was due to the IR port trying to communicate with the sun. I tried to turn it off in the software, but ultimately covered over the port on the top of the PDA with a small piece of black electrical tape. Problem solved. I initially discovered this was the problem when I threw my hat over the unit in disgust and discovered that the perforance immediatly recovered. You can usually see the port flashig if you point it at a webcam and look at the resulting video on your computer screen. The webcam sensors are usually sensitive to IR. John Hi Paul, thanks for the video tip, I've turned off the beam function and will let you all know what I discover next time I fly. Cheers, Brad Please don't issue any stop commands while it's communicating with the sun. 9B On the other hand, maybe a "Slow down" command would fix the global warming problem. :-) -- Regards, Adrian Jansen adrianjansen at internode dot on dot net Design Engineer J & K Micro Systems Microcomputer solutions for industrial control Note reply address is invalid, convert address above to machine form. |
Funny! On the other hand, if it does succeed in communicating with
the sun please post the resulting conversation. It would be ... fascinating. ;| Please don't issue any stop commands while it's communicating with the sun. 9B |
On Jun 13, 9:39*pm, Brian wrote:
On Jun 13, 9:48*am, Mike wrote: Brad, I am using an iPAQ 3970 with PPC2003. I found 5.2.2 to be a bit buggy and went back to 5.1.8, although I do not recall the problem you mentioned. Are you using PPC2002 in your iPAQ? If so, switching to PPC2003 may solve your problem. Not sure where you can find the update now though. Mike On Jun 13, 8:30*am, Brad wrote: Anyone else running XC flight software on a PDA find them to be sluggish and almost unuseable during a flight? I am using an iPAQ 3850 running XC-Soar, the unit is hooked to a Garmin Map60CS. Sure everything works, but while in the air, if I push a button or touch the screen somtimes it takes several seconds for the function to work.. This often leads to stacked commands that eventually cycle thru, but inevitably end up not on the command I wanted/needed. Case in point: Mountain XC flight the other day.....................middle of the Cascades and I am wanting to look up my alternate airports/LZ's.............it is almost impossible to get the PDA/software to do this. Instead I just used the GPS, which has the same data the PDA has. Is there some setting on the PDA to speed things up? I know there is a setting to allocate more memory to the programs....could that be tweaked? Thanks, Brad After have 5.2.2 just shut down, but still locks the Serial port requiring me to do a hard reset on the PDA. I went back to 5.1.8 as well. Brian HP16T N16VP Got a chance to fly yesterday after turning off the receive beams function on my PDA. I think that solved the problem! Thanks, Brad |
Sarah schrieb:
Funny! On the other hand, if it does succeed in communicating with the sun please post the resulting conversation. It would be ... fascinating. ;| Please don't issue any stop commands while it's communicating with the sun. 9B use some tape to cover the IR-Port |
PDA's Interface | Ray Lovinggood | Soaring | 11 | August 31st 05 03:20 PM |
FS-PDA's | Ed Hollestelle | Soaring | 0 | September 21st 04 05:26 PM |
FS PDA's | Ed Hollestelle | Soaring | 0 | July 21st 04 03:31 PM |
PDA's | Tony | Owning | 15 | February 6th 04 10:20 PM |
Overstocked on PDA's | Ed Hollestelle | Soaring | 16 | December 4th 03 01:40 PM |
