![]() Before I'd consider any particular airfoil, what's your Reynolds Number range? -------------------------------------------------------------------------------------------- "Towed by a boat" and "..stall speed of 25mph" pretty well defines the lower end of the envelop. Since the thing is a water craft, apparently meant for recreational purposes we can assume two-place, side-by-side for the load and a stepped hull, probably with a T-tail. As with most water craft it probably needs to be designed to allow it to be taken to where the water is. The need for portability tends to suggest a wide-chord, low- aspect wing, probably strut-braced to improve it's portability and ease of set-up, which points us toward one of the low-speed airfoils developed at Gottingen University during the 1920's... or an RAF- series airfoil from the same era... or something from the fat end of the 23000 series...23021 or whatever... but that would probably want a full-span, all-flying Junkers 'aileron' for control, as mentioned by Oliver. Brian's mention of biplane wings is a hands-down winner for strength but becomes a mare's nest when it comes to portability and ease of erection. As for getting off of the water and into the air I think the real problem is getting free of the water without the characteristic 'pop- up.' In any case, the fact you want it to take-off and land on water,, plus the fact it is a flying boat rather than an airplane on floats, means it's going to have to be hell for stout if you want it to last more than one season. ---------------------------------------------------------------------------------- As always, this Group can over-engineer the thing for you :-) Or you could just jump right in, whip something out and play with it until it breaks. -R.S.Hoover |
Bob wrote:
As always, this Group can over-engineer the thing for you :-) Or you could just jump right in, whip something out and play with it until it breaks. An old contrarian saying comes to mind: "A month in the lab can save you an hour in the library." In this case I say it never hurts to try to sit down and try to make some estimates, however rough. Otherwise yes, one can always start building something and after enough trial and error construction and testing eventually come up with something. |
Jim Logajan wrote:
An old contrarian saying comes to mind: "A month in the lab can save you an hour in the library." Every time! |
On Jun 22, 5:32*pm, cavelamb wrote:
An old contrarian saying comes to mind: "A month in the lab can save you an hour in the library." Every time! Not every time! You never did the book research and then tried to apply it ............... only to find out the author didn't have any real world experience? Bought an EconoTIG years ago. Wasted money on published (not direct advertising) "expert" advice. ================= Leon McAtee Always on the look out for contrary points of view. |
![]() wrote in message ... On Jun 22, 5:32 pm, cavelamb wrote: An old contrarian saying comes to mind: "A month in the lab can save you an hour in the library." Every time! Not every time! You never did the book research and then tried to apply it ............... only to find out the author didn't have any real world experience? Bought an EconoTIG years ago. Wasted money on published (not direct advertising) "expert" advice. ================= Leon McAtee Always on the look out for contrary points of view. However, he did say an hour in the library, not an hour with a random book. I have been tricked as well, although in my case, it was a class in mechanical drafting--in which the Prof prattled on, asserting that he understood common processes, but clearly had no clue at all how a sheet metal brake actually stretches metal. Peter |
airfoil | [email protected] | Soaring | 0 | July 2nd 07 11:57 PM |
Jantar Std Airfoil | [email protected] | Soaring | 4 | May 8th 06 10:41 PM |
GA 35-A-415 airfoil | [email protected] | Home Built | 0 | November 1st 05 02:56 AM |
S-18 airfoil | JDKAHN | Home Built | 0 | October 30th 04 04:35 AM |
Best airfoil? | Scott | Soaring | 5 | January 27th 04 06:30 PM |
