jan,
I had a nice graphic that explained the range of effects on Reynolds Number from the "fall of dew" to Mach 3. Unfortunately I haven't found it - yet. But getting away from airplane wings for a moment, How fast does dew fall? How big is a droplet of water in the morning dew? At that scale, viscosity (stickiness of the air - and yes, air is "sticky") effects are the major forces involved. Accumulate more water into a raindrop. Now there is enough mass for much higher velocities. Now the inertial forces predominate. The wake left behind is fairly clean, but noticeable. Freeze a bunch of that into hail stones! Lots of mass - much higher speeds. Now we start seeing funny things in the shape of the wake - swirling vortices. http://en.wikipedia.org/wiki/Von_K%C..._vortex_street Notice how the animation shows the wake whipping back and forth. Get enough mass and size, and altitude to fall (ie much higher speeds), and we see the air ahead of the object starting to pile up - can't get out of the way fast enough - resulting in super sonic shock waves. It's all the same air. The differences are how long (chord length) and fast something is going through it. Or, as another pointed out, increase the density of the fluid. |
Guys, please, if you really only do have a marginal understanding,
don't post or at least mark it as such. Explaining in entirety what the Reynolds numbers means will fill one or two chapters in a good aerodynamics textbook. What Cavelamb wrote is good, what Jim wrote is, as he said, marginal understanding, but not wrong, but what Gerry wrote is between borderline and wrong. I will try and summarize a bit (but after 7 years of university, it's probably pretty theoretical): The Reynolds number is determined as Re = v * L / nu v is the speed of the airflow, L is the "characteristic length" (I'll get into that) nu is the "cinematic viscosity" (dynamic viscosity divided by density, which yields roughly 1.5 * 10^-5 m^2/s at ISA MSL conditions - no fudge factors such as "9346" when using SI. The density effects Gerry wrote about are 99% due to the impact of density on the dynamic pressure, and not on Re - and the dynamic viscosity of air and water are much different to begin with) Physically speaking, it gives you the relation between viscous and inertial forces in a fluid (as has been said). Which won't really tell you anything in the beginning. Very roughly it means whether the airflow will be laminar or turbulent (see last post by Cavelamb). This means you can get an infinite number of Re on an airplane, just as has been written. It cannot (really) be chosen, but is determined by size and operating conditions of the airplane. On an airfoil, the characteristic length L is the chord. Wind tunnel measurements on airfoils are done at certain Re. So if you know your airflow speed and chord, you can get the right polar to figure out how your airfoil will behave. Re mostly has an effect on the length of laminar airflow (transition usually occurs at a certain Re, which is then not calculated with L, but rather with x, meaning the length of surface the air has travelled on the airfoil up to this point) and hence drag, and since laminar and turbulent flow behave differently with regard to flow separation (check for pictures on Google what this means), it also has an effect on the maximum lift coefficient the airfoil will achieve. In general, higher Re lead to lower drag coefficients and higher max lift coefficients, but a smaller "laminar bucket", which means the range of lift coefficients the airfoil can operate in to achieve low drag is smaller (especially interesting for sailplane and other low- drag applications). In short, you need it if you (seriously) want to design an airplane and estimate its performance. But the difference between wind tunnel testing and reality is much greater than the difference between Re = 1 * 10^6 and 2 * 10^6, so it doesn't really matter for homebuilders. It can become interesting for builders of high-performance model airplanes and of course aerodynamically challenging tasks such as designing sailplanes. Oliver |
Thanks for your post Oliver, you are of course absolutely correct in
everthing you've said. I was regretting my second post with the 'thought exercise' as I hit the button, the intent was to demonstrate the relationship of Re to density, and I think I missed the mark. My intent for posting was not to provide an accurate engineering description of Reynolds number, but to help a non-engineer understand the basic concept. As you've provided, Re = v * L / nu. If we consider air viscocity / density / stickyness to be constant, then it holds that an airfoil operating at half the speed and twice the length of another will calculate out to the same Reynolds number, and both will essentially behave the same. I will submit for your consideration that giving a fully accurate and complete engineering description of the effects of Re that is gold for we engineers will do little or nothing to help the layman understand the underlying concept. (I'm a mechanical engineer, but not an aerodynamicist) I will contend that the terms kinematic and dynamic viscosity, drag polar, laminar and turbulent flow, laminar bucket, lift coefficient, while joyful for us engineers to bat around in aircraft design, they are abolutely meaningless to the non-engineer. (You did mean kinematic and not 'cinematic' didn't you? Sorry, just a friendly dig there. ;^) I'll try to restate: Reynolds number is essentially a count of how much air is acting on a wing in a unit of time. If a given length of airfoil traveling at a given speed calculates to a certain Re, then the same airfoil shape in a smaller size will have to go faster to have the same quantity of air working on it. Would that statement pass the accuracy test for you? Jan, is the concept starting to come together for you? Best regards all Gerry |
To All:
I've always appreciated my father's explanation, which some of you may find suitable if you have a nine-year old who is just getting into free-flight. Model competitions were quite popular up until WWII but never regained their past glory after. My dad and several of his friends were discussing a new wing for an existing fuselage and Reynold's number was mentioned several times. When I asked what it was his friends started to grin; a couple even laughed but he told me there were somethings that we couldn't scale, such as the size of a molecule of air. so a fellow named Reynold came up with a way of calculating a number that could be used as a kind of artifical scaling factor. -R.S.Hoover (Do they still use Banana Oil?) |
First, thanks to Oliver for a much better explanation.
It's not about the size of a molecule, but how they interact with each other and surfaces at different energy levels. These links are a few animations and film clips that depict air flow and increasingly higher Reynolds numbers. This first one is at VERY LOW Reynolds and displays a nearly Newtonian reaction. I suspect that if people think about air flow, this is how they would expect it to behave. http://www.youtube.com/watch?v=rbMx2...eature=related But kick the velocity up to flying speeds and see what actually happens... http://www.youtube.com/watch?v=A4taH...eature=related http://www.youtube.com/watch?v=vQHXI...eature=related Transonic range... http://www.youtube.com/watch?v=ZMEQJhiebu4 And a standing shock wave on a sub sonic airliner wing! http://www.youtube.com/watch?v=duCHF...eature=related Actual photographs of supersonic shock waves (an interesting film about supersonic flight too) http://www.youtube.com/watch?v=atItR...eature=related So, what about an actual airfoil? Department of Engineering, University of Cambridge, multimedia video from Physics Education, 2003, by Holger Babinsky. The smoke tunnel really lays it out clearly. And the pulsed smoke flow can start a lot of arguments! http://www.youtube.com/watch?v=6UlsA...eature=related This one I like because it shows a "long bubble" developing on the top surface of the wing. It's not what they were after, but it clearly shows the bubble development. http://www.youtube.com/watch?v=J-xxC...eature=related |
Oliver Arend schreef:
The Reynolds number is determined as Re = v * L / nu v is the speed of the airflow, L is the "characteristic length" (I'll get into that) OK OK thanks but that wasn't really my question. Excuse me if I wasn't clear enough, what I really meant to ask is "when designing a plane, need I be concerned about the Reynolds number and if so, in what way?" My first understanding was that it is a property of the airfoil, that seems wrong now. ( ... ) This means you can get an infinite number of Re on an airplane, just as has been written. It cannot (really) be chosen, but is determined by size and operating conditions of the airplane. But NOT by the airfoil, then? Does one first determine the (max?) Re the plane will be operating at, and choose an airfoil accordingly? In short, you need it if you (seriously) want to design an airplane and estimate its performance. That is a very useful answer to me. But the difference between wind tunnel testing and reality is much greater than the difference between Re = 1 * 10^6 and 2 * 10^6, so it doesn't really matter for homebuilders. It can become interesting for builders of high-performance model airplanes and of course aerodynamically challenging tasks such as designing sailplanes. So if I'm not wanting the ultimate bit of performance from my DreamBird, I needn' t bother too much? How then do I go about selecting an airfoil? PS1 I am very happy with the tone of this discussion: only positive reactions, and people willing to accept correction. It's one of the reasons I like to lurk a bit here, and even dare to launch some questions about a silly dream I am not likely to ever realise. PS2 Oliver, verstehe ich gut du bist Deutsch? Das koennte mal Spass machen, anderes als Englisch zu schreiben... |
jan,
Perhaps it would be easier to think of it as a property of the fluid (in this case - air) - not the wing... The air is moving past the wing(!) and will stratify (or separate into layers) moving at different speeds. Read these arrows as a vectors - direction and length = velocity ----------------------------------------- Free stream velocity ------------------------------------ ------------------------------ boundary layers move faster -------------------------- --------------------- ----------------- ------------- boundary layers move slower --------- closer to surface --- ========================================= surface In special cases, air in the the boundary layer can even move in the OPPOSITE direction! ----------------------------------------- Free stream velocity ------------------------------------ ------------------------------ boundary layers move faster -------------------------- farther from surface --------------------- ----------------- ------------- boundary layers move slower --------- closer to surface ----- - here, the flow has reversed --- ========================================= surface Note: the Re of the layers could be different due to differences in velocity. |
"jo" == jan olieslagers writes:
jo OK OK thanks but that wasn't really my question. Excuse me if jo I wasn't clear enough, what I really meant to ask is "when jo designing a plane, need I be concerned about the Reynolds jo number jo PS1 I am very happy with the tone of this discussion: only jo positive reactions, Hmmm. This may be the first negative one. If someone doesn't understand Re, should they be designing an airplane? I don't think one can pick up sufficient fluid and structural mechanics on Usenet to be a reliable aircraft designer. -- Suppose you were an idiot, and suppose you were a member of congress; but I repeat myself. ~ Mark Twain |
Excuse me if I wasn't clear enough, what I really meant to ask is "when designing a plane, need I be concerned about the Reynolds number and if so, in what way?" Yes, you should. But not much (see below, answer to Bob's post). My first understanding was that it is a property of the airfoil, that seems wrong now. True. As Richard said, it's more of a property of the air flowing around the airfoil. But NOT by the airfoil, then? Does one first determine the (max?) Re the plane will be operating at, and choose an airfoil accordingly? You should determine the range of Re the plane/airfoil is operating at. For low speeds/low Re, evaluate cLmax for stall. For higher speeds/ higher Re, evaluate drag in the cL range you're going to encounter. For example, I'm currently trying to fit winglets to an existing wing. The wing itself operates (roughly) at Re=1M...5M, the winglets at 300k...5M. Esp. the latter poses a serious challenge for the airfoil designer/airfoil choice. So if I'm not wanting the ultimate bit of performance from my DreamBird, I needn' t bother too much? How then do I go about selecting an airfoil? Well... cLmax predictions from calculations and wind tunnels don't always relate well to what you get or seem to get in flight. The so- called "laminar bucket" (range of cL with low drag) does so much better. So what you do is choose an airfoil that gets you low drag in the your cruise speed range, and if you're lucky it has a decent cLmax. Size the wing accordingly (e.g. to satisfy stall speed requirements). It all boils down to a trade-off, which is easier with flaps. If you don't want to use flaps, the NACA airfoils that have been proposed (4- and 5-digit-series) do the job pretty well, but don't expect a high-performance aircraft to come out of it. There's also a lot of other areas you can work on to reduce drag. The plane I'm working on has a no-lift-cD of around 0.035, out of which only maybe 0.006 come from the wing (the rest is fuselage, turbulence from the prop, struts, empennage, landing gear etc.). RVs for example use countersunk rivets much more than other metal homebuilts it seems (and maybe larger engines), so they achieve higher performance. Hmmm. This may be the first negative one. If someone doesn't understand Re, should they be designing an airplane? I don't think one can pick up sufficient fluid and structural mechanics on Usenet to be a reliable aircraft designer. You don't really have to understand Re. You only have to apply it. I think that's a difference between somebody who specialized in aerodynamics (me ;-) opposed to someone who specialized in aircraft design (me too ;-). And I don't think anyone would design a plane with knowledge from Usenet. Rather pick up a book and get questions that remain unanswered in the book answered on Usenet (neither Raymer nor Roskam _explain_ Re, but they probably mention it somewhere). And structural design on a (homebuilt) aircraft can be simplified to the point of only having beams under tension/compression, bending and torsional loads with maybe some buckling thrown in. Gets you three or four different equations. The rest is structural testing. Wasn't there a post about "Designing your homebuilt in 10 equations" mentioned a while back? PS2 Oliver, verstehe ich gut du bist Deutsch? Das koennte mal Spass machen, anderes als Englisch zu schreiben... Absolut richtig, Jan, und so weit ich das verstehe bist Du Niederländer? Oder Flämisch-Belgier? Ik kann een wenig Platt verstahn, aber dat is nich dat selbe wie Nedderlannsch ;-) Oliver |
Bob Fry wrote:
"jo" == jan olieslagers writes: jo OK OK thanks but that wasn't really my question. Excuse me if jo I wasn't clear enough, what I really meant to ask is "when jo designing a plane, need I be concerned about the Reynolds jo number jo PS1 I am very happy with the tone of this discussion: only jo positive reactions, Hmmm. This may be the first negative one. If someone doesn't understand Re, should they be designing an airplane? I don't think one can pick up sufficient fluid and structural mechanics on Usenet to be a reliable aircraft designer. There are two kinds of design (and science, and lots of other stuff..) incremental, and original. As it happens, the great majority of design (and lots of other stuff) is incremental. That's not such a cop out as you might think. In terms of airplanes: you examine the mission. (EVERY airplane has a mission, but some folks don't necessarily realise that) Then, you gather data on every airplane with a similar mission. Then (as best you can) you evaluate the positive user feedback, and the negative stuff, and associate design features with the desirable features. Then you try to package all the desirable features and none of the undesirable features in one package. At NO point have I mentioned Re have I? I could even go a little further: if you get yourself in a situation when you have to deploy your considerable engineering skills in evaluating Re, it is because you forgot to use your even more considerable judgment is selecting well-liked, useful, relevent airfoils. :-) Brian Whatcott Altus OK |
Minden Pilots - Ping Jim Reynolds | Al | Soaring | 0 | July 14th 06 06:45 PM |
Reynolds: "Come Out of the White House with Your Hands Up!" | mrtravel | Piloting | 2 | May 16th 06 08:28 PM |
Reynolds: "Come Out of the White House with Your Hands Up!" | [email protected] | Piloting | 0 | May 9th 06 04:11 AM |
Clark G. Reynolds dies | Jim Beaver | Naval Aviation | 0 | December 22nd 05 07:48 AM |
Pitts Number 1 registration number | Mirco | Aerobatics | 3 | December 4th 04 11:50 AM |
