On Jun 23, 9:14*am, Martin Gregorie
wrote: On Tue, 23 Jun 2009 06:24:24 -0700, bildan wrote: On Jun 23, 4:34*am, John Smith wrote: ucsdcpc wrote: The routine we are taught is as follows, all part of the pre-flight eventualities check before each launch: 1. * *decide on appropriate approach speed for conditions 2. * *in the event of a launch failure (not just cable brake) lower the nose to an appropriate attitude Wrong, very wrong, very dangerous. The correct sequence is: 1. Push the stick forward and pull the release knob. 2. If possible, land ahead on the remaining runway. 3. If you're too high to land ahead, you have all the time to decide your further actions. This can be an abbreviated circuit or a downwind landing, depending on the circumstances. And yes, doing a 180 too hasty will put you in a situation where you don't have enough runway to land. So whatever you do, don't panic. Everything else depends. Please explain why pulling the release is priority one. Apart from anything else, your hand should be on the release knob during the launch, so pulling it a couple of times immediately after pushing over and just before letting go of it is an obvious move. That is taught as SOP in my club. *Most likely the remaining rope and parachute gear has already back released. .... only if the cable break was down near the winch. If the break was near the glider you could still have several meters of cable and the furled drogue dangling trailing from the hook. Its even more likely that you'll still have the cable attached if the problem is a power fade at the winch rather than a cable break. Diverting attention to the release knob when other critical decisions are pending seems odd when you think about it. It should be in your hand already, so no attention diversion is needed. Note to Schweizer operators: *Schweizer CG hooks require MUCH more force to back release than the Tost release so you folks should pull. There's the other answer: never train somebody to use a technique that is unsafe on some types of glider. Murphy pretty much mandates they'll forget to check the cable is gone when they're flying a type where it matters. -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | I don't think you made your case. I have seen LOTS of wire/rope breaks, including weak link breaks, and nothing has ever stayed on the hook - even with Schweizers. But, even if pulling the release is justified on the assumption that something MIGHT be on the hook AND assuming that something on the hook would cause damage (It won't kill you), why a priority? The reason I brought this up is that I have seen many pilots nearly bungle a recovery while pulling the release. Even with a hand on the release, there's no guarantee a pilot will pull it - I've seen pilots take their hand off the release and pull the spoilers. A launch failure is no time to be multi-tasking. Screw the release - FLY THE GLIDER! I want to see this priority list in order of decreasing urgency: 1. Nose way down NOW! 2. Get a safe airspeed ASAP! 3. Decide on the landing option (Straight or circle.) 4. Execute landing option - concentrate on airspeed and coordination. 5. Pull the release - maybe. I'm not saying don't pull the release - just don't let it get in the way of more urgent actions. |
bildan wrote:
why a priority? Pushing the stick and pulling the release is *one* movement. You don't have to think about it. The reason I brought this up is that I have seen many pilots nearly bungle a recovery while pulling the release. I just don't believe this. But *if* it were true, then those pilots would *urgently* need a couple of training flights. Even with a hand on the release, there's no guarantee a pilot will pull it - I've seen pilots take their hand off the release and pull the spoilers. Again, if this were true, then those pilots would urgently need a couple of training flights. It seems that there's something very wrong with the pilot training at your site. |
On Jun 23, 10:42*am, John Smith wrote:
bildan wrote: why a priority? Pushing the stick and pulling the release is *one* movement. You don't have to think about it. You DO have to think about it and doesn't answer the question, "WHY A PRIORITY?" Just because something is easy doesn't make it a priority. |
bildan wrote:
Pushing the stick and pulling the release is *one* movement. You don't have to think about it. You DO have to think about it and doesn't answer the question, "WHY A PRIORITY?" Just because something is easy doesn't make it a priority. If you have to think about it, then you need more training. Granted, if you don't have that reflex incorporated, *then* you have to think about it. |
On Jun 23, 10:56*am, John Smith wrote:
bildan wrote: Pushing the stick and pulling the release is *one* movement. You don't have to think about it. You DO have to think about it and doesn't answer the question, "WHY A PRIORITY?" *Just because something is easy doesn't make it a priority.. If you have to think about it, then you need more training. Granted, if you don't have that reflex incorporated, *then* you have to think about it. |
On Tue, 23 Jun 2009 09:00:06 -0700, bildan wrote:
I don't think you made your case. I have seen LOTS of wire/rope breaks, including weak link breaks, and nothing has ever stayed on the hook - even with Schweizers. I've seen several strops dropped when the pilot pulled the release after a weak link broke. During a practice power fade the cable often stays on through the push-over, so it follows that this is also likely if the winch fails for real due to engine trouble or a fuel blockage. The reason I brought this up is that I have seen many pilots nearly bungle a recovery while pulling the release. Even with a hand on the release, there's no guarantee a pilot will pull it - I've seen pilots take their hand off the release and pull the spoilers. A launch failure is no time to be multi-tasking. I've never seen this. An ASW-19 or Pegase on finals with the wheel going up and down, yes, but brakes opening after a cable break, never. I want to see this priority list in order of decreasing urgency: 1. Nose way down NOW! 2. Get a safe airspeed ASAP! 3. Decide on the landing option (Straight or circle.) 4. Execute landing option - concentrate on airspeed and coordination. 5. Pull the release - maybe. Move 5 up to 2 and I'll agree with your sequence. Three reasons: (a) you're going to wait some seconds for the airspeed to build so pulling it at this point doesn't delay any other actions. (b) Your hand is on or very near the release, so just do it. (c) As I said above, you may be faced with a power fade rather than a cable break and the cable may still be on. Now, we know that back-release works for a straight backward pull, but what if its a high power fade and you get airspeed and turn. Would you still expect the cable to back release at an angle to the flight path? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
![]() 1. Nose way down NOW! 2. Get a safe airspeed ASAP! 3. Decide on the landing option (Straight or circle.) 4. Execute landing option - concentrate on airspeed and coordination. 5. Pull the release - maybe. Move 5 up to 2 and I'll agree with your sequence. Three reasons: (a) you're going to wait some seconds for the airspeed to build so * * pulling it at this point doesn't delay any other actions. (b) Your hand is on or very near the release, so just do it. (c) As I said above, you may be faced with a power fade rather than * * a cable break and the cable may still be on. Now, we know that * * back-release works for a straight backward pull, but what if * * its a high power fade and you get airspeed and turn. Would you * * still expect the cable to back release at an angle to the flight * * path? -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | OK, maybe, as long as it isn't priority 1 - but now you are introducing a power fade which is a different animal. Power fades are demonstrated and practiced along with simulated rope breaks just so pilots know the difference. No one has ever said, "Wow, that's confusing - how do you tell the difference?" (C.) However, this one deserves serious consideration. A break is an obvious "thump" and an upward surge. (Spectra/Dyneema rope generates a much more obvious thump than steel.) Assuming the pilot is monitoring airspeed, a power fade means the nose will coming down and be down to a normal glide attitude and airspeed as power is totally lost - just as at the top of a normal launch. It will be managed as if it were a normal launch with a normal release pull - just at a lower height. Just as with a normal launch, the winch driver will be alert to the rope not detaching from the glider and fire the guillotine For a winch power loss to be confused with a rope break, the power failure would need to be a rare kind - some sort of explosive loss of mechanical integrity or seizing up of the winch. But, if the rope is still attached at the winch, there won't be the upward surge. |
On Tue, 23 Jun 2009 14:42:24 -0700, bildan wrote:
OK, maybe, as long as it isn't priority 1 - but now you are introducing a power fade which is a different animal. They aren't taught as distinct happenings here - just as winch launch failures. I agree that they are seldom confused, but the actions to be taken after a cable break or after a power fade is recognised are the same: (1) nose down to establish approach speed, (2) make sure cable is off (3)..... No one has ever said, "Wow, that's confusing - how do you tell the difference?" ....and I didn't say or imply that anybody confuses the two. (C.) However, this one deserves serious consideration. A break is an obvious "thump" and an upward surge. (Spectra/Dyneema rope generates a much more obvious thump than steel.) Even when it breaks at the winch end? I wouldn't know - I've not yet flown on the stuff. Assuming the pilot is monitoring airspeed, a power fade means the nose will coming down and be down to a normal glide attitude and airspeed as power is totally lost - just as at the top of a normal launch. If its a slow fade the airspeed may easily be lower than approach speed. IME a slow fade is harder to recognize and deal with than a sudden cut or a break. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Even when it breaks at the winch end? I wouldn't know - I've not yet flown on the stuff. It doesn't matter where it breaks - the whole rope weighs around 30 Lbs so the feel in the glider is the same. Assuming the pilot is monitoring airspeed, a power fade means the nose will coming down and be down to a normal glide attitude and airspeed as power is totally lost - just as at the top of a normal launch. If its a slow fade the airspeed may easily be lower than approach speed. IME a slow fade is harder to recognize and deal with than a sudden cut or a break. Not if the pilot is controlling, or just monitoring, the airspeed. The pilot will lower the nose appropriately to maintain the selected airspeed. When the power is all gone, the glider will be gliding at the selected speed - a perfect recovery even if the pilot didn't recognize the power failure. Lowering the nose is the signal for more speed so it works in all cases. |
Pay out winch launch to 2500ft agl.. | WAVEGURU | Soaring | 8 | June 5th 07 07:06 AM |
Winch Launch Videos | Mike Schumann | Soaring | 2 | January 19th 06 11:27 PM |
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 12:33 AM |
Electric winch fatality story in August Soaring | Bill Daniels | Soaring | 0 | August 14th 04 02:37 AM |
Winch launch | M B | Soaring | 0 | October 30th 03 07:33 PM |
