Dan wrote:
Drew Dalgleish wrote: On Wed, 24 Jun 2009 08:13:28 -0500, Dan wrote: I'm looking for a simple design for nose wheel steering for retractable gear. Any ideas? Dan, U.S. Air Force, retired Have you considered just having a castering nosewheel? That's what I have on my floats and it works pretty well steering with the brakes. Yes, differential braking is probably the simplest method. I'm not discarding it, just poking around at options. Dan, U.S. Air Force, retired Thisis an interesting pic. http://www.infinityaerospace.com/Oriion_TS_gear.jpg Not a lot of detail there, but the steerable strut seems to poke thru the top and would meet with a steering link (tiller/thingie) there. |
On Jun 24, 10:28*pm, cavelamb wrote:
Dan wrote: Drew Dalgleish wrote: On Wed, 24 Jun 2009 08:13:28 -0500, Dan wrote: * I'm looking for a simple design for nose wheel steering for retractable gear. Any ideas? Dan, U.S. Air Force, retired Have you considered just having a castering nosewheel? That's what I have on my floats and it works pretty well steering with the brakes. * Yes, differential braking is probably the simplest method. I'm not discarding it, just poking around at options. Dan, U.S. Air Force, retired Thisis an interesting pic. http://www.infinityaerospace.com/Oriion_TS_gear.jpg Not a lot of detail there, but the steerable strut seems to poke thru the top and would meet with a steering link (tiller/thingie) there. I keep thinking about the "T-Bar" idea. If the rudder pedals had control horns extending below the pedals hinge line with push rods attached that extended forward to ball bearing rollers that pushed on the right and left of the "T-Bar", that would provide the reverse action to make the steering work right. A push on the right pedal would pull back the push rod and roller attached to it and the left pedal would push it's pushrod and roller forward to turn the "T-Bar" to the right. When the gear was retracted, the pushrods wouldn't have anything to push on. If the nose gear strut was directly below the pedals, the pedals could just have "spurs" with rollers on them. |
bildan wrote:
On Jun 24, 10:28 pm, cavelamb wrote: Dan wrote: Drew Dalgleish wrote: On Wed, 24 Jun 2009 08:13:28 -0500, Dan wrote: I'm looking for a simple design for nose wheel steering for retractable gear. Any ideas? Dan, U.S. Air Force, retired Have you considered just having a castering nosewheel? That's what I have on my floats and it works pretty well steering with the brakes. Yes, differential braking is probably the simplest method. I'm not discarding it, just poking around at options. Dan, U.S. Air Force, retired Thisis an interesting pic. http://www.infinityaerospace.com/Oriion_TS_gear.jpg Not a lot of detail there, but the steerable strut seems to poke thru the top and would meet with a steering link (tiller/thingie) there. I keep thinking about the "T-Bar" idea. If the rudder pedals had control horns extending below the pedals hinge line with push rods attached that extended forward to ball bearing rollers that pushed on the right and left of the "T-Bar", that would provide the reverse action to make the steering work right. A push on the right pedal would pull back the push rod and roller attached to it and the left pedal would push it's pushrod and roller forward to turn the "T-Bar" to the right. When the gear was retracted, the pushrods wouldn't have anything to push on. If the nose gear strut was directly below the pedals, the pedals could just have "spurs" with rollers on them. Here's my fantasy design. Two tiny motorbike master cylinders, one on each rudder pedal, and one slave cylinder on a horn each side of the nose wheel. Then the wheel could rotate and retract, and the hose pipes from brake flexibles, would just flex. (Difficult to make this light enough, I imagine.) Brian W |
F-111 Nose wheel | Glenn[_2_] | Aviation Photos | 0 | April 13th 08 09:30 AM |
A320 nose wheel steering | cam lowes | Simulators | 0 | July 19th 06 12:03 AM |
Looking for Cessna 206 or 310 nose wheel fork | mikem | Aviation Marketplace | 0 | October 27th 03 04:33 PM |
Looking for Cessna 206 or 310 nose wheel fork | mikem | Owning | 0 | October 27th 03 04:33 PM |
Nose wheel shimmy | JFLEISC | Owning | 2 | August 27th 03 03:28 PM |
