The apparent cable offset was because we were using a retrieve winch.
However the cable always pulled approximately straight under tension as the launch commenced. It was normal to place the launch queue on the downwind side of the retrieve winch, so that any slight weather-cocking at the start of the launch if anything further reduced the angle between the cable and the glider, and also reduced the possibility of the wind getting under the upwind wing. The gliders would have been set up to point at the main winch, or just slightly upwind of it to reduce any yaw at the start. IMHO the use of a retrieve winch actually reduces the possibility of a wing drop, and was not a factor in either case. Particularly in the video, the glider was running straight before the wing drop occured, and was probably due to the student pilot failing to do anything positive to keep the wings level in a slight cross wind from the right, plus a late take-over by a very newly qualified (at the time) instructor. Derek Copeland At 01:00 25 June 2009, Don Johnstone wrote: What is particularly interesting in both the video and the photographs is the direction the glider is pointing relative to the cable. In the video the glider can be seen to yaw as the cable tightens and then further yaw as the it starts to move. In the photographs it is clear that the glider is pointing to the right of the direction of the cable AND stangely is pointed in the same direction as the K13 parked behind it, a co-incidence perhaps. In both cases it would appear possible that the glider was not lined up with the cable prior to launch so that as soon as the cable moved yaw was induced. With a CofG hook the glider will be more unstable about the yaw axis than was the case with the more forward release on older gliders. Perhaps that might explain why this appears to be a "new" phenomenon. At 21:45 24 June 2009, Derek Copeland wrote: Once a wing drops onto the ground, the glider will almost inevitably veer off in the same direction due to ground friction, which is what you see here and what you also see in my video of a wing drop. The photographer didn't quite catch the start of this incident, and I am sure that the glider would have been lined up correctly. The wing tip runner for the K13 was a very experienced pilot and an ex syndicate partner of mine. He told me that it was a cold, windy and very blustery day and that none of our runways lined up with the wind direction, so there was about a 30 degree cross wind from the right. The chain of events started with a violent gust that caused the wing to drop as he let go. The instructor tried to pull off, but his gloved hand slipped round the round release knob, twice in fact. He was successful at the third attempt, but reported that it took a lot more force than he expected to release under tension. By this time he was airborne, so had to take over and fight the glider back onto the ground somehow. What was interesting was the the eventual landing direction was at right angles to the start direction, once the rudder was taken off. The student pilot may not have dealt with the dropping wing very well, but there is no evidence that he contributed to it. After this incident, our CFI wanted to fit T handle releases to our K13s, but EASA said no because it counted as a major modification and would require full design approval (very expensive). Bureaucracy gone mad or what! Derek Copeland At 18:54 24 June 2009, bildan wrote: What I see in that K-13 sequence is the parachute disappearing off the left side of the frame after it was released. It gives the appearance the glider was staged at least 30 degrees off the line of sight to the winch. I also don't see any aileron or rudder applied in the first frame with the wing on the ground indicating the pilot was WAAY behind the glider. Blaming this 100% on a gust seems a reach. |
Pay out winch launch to 2500ft agl.. | WAVEGURU | Soaring | 8 | June 5th 07 07:06 AM |
Winch Launch Videos | Mike Schumann | Soaring | 2 | January 19th 06 11:27 PM |
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 12:33 AM |
Electric winch fatality story in August Soaring | Bill Daniels | Soaring | 0 | August 14th 04 02:37 AM |
Winch launch | M B | Soaring | 0 | October 30th 03 07:33 PM |
