AOA INDICATORS
Quotes from earlier in this thread... "However, I think significantly fewer accidents would have happened if angle of attack indicators were universally installed." "As for an AOA indicator, you're damn right I'd be looking at it - and flying a much safer recovery as a result." What additional benefit would an AOA indicator give over deciding on an appropriate approach speed before the launch starts and maintaining it, once attained, after a launch failure by monitoring the airspeed indicator frequently? An AOA indicator might just be a distraction! 180 DEGREE TURNS. As pointed by others a 180 turn does not line one up with the runway so unless its a very large airfield additional manoeuvring is required which makes it more complex than at first sight. It is also more likely to put a glider into conflict with landing traffic. It is also quite difficult to avoid landing long if there is a tail-wind component which may tend to make pilots fly more slowly downwind!! The case for a 180 turn after a winch launch failure is very weak. HAND ON RELEASE "First, we're really only talking about an aero tow ground roll. Once airborne in turbulent air, keeping a death grip on the release isn't a good idea." The hand should be touching the release (not holding it) during the early part of the launch so that one can easily grip it properly and pull it without having to look for it. Holding it firmly is likely to create additional risks due to premature releases. So when is it safe to stop touching it? On aerotow probably above 800' - 1000' when the risk of killing the tug pilot if you inadvertently get too high is reducing. "airborne in turbulent air" is one of those situations when you may get out of position - so keep your hand just touching it. On a winch launch you will need to use the release in little over a minute after the launch commences - why not continue to touch it all the way? Flapped gliders where the setting needs to be changed from negative during the ground run are an interesting case. Starting (aerotow) launches in negative reduces the probability of a wing drop, but one's hand is in the wrong place to react if it does. What is the best option for those guys? |
On Fri, 26 Jun 2009 13:15:04 +0000, Big Wings wrote:
Flapped gliders where the setting needs to be changed from negative during the ground run are an interesting case. Starting (aerotow) launches in negative reduces the probability of a wing drop, but one's hand is in the wrong place to react if it does. What is the best option for those guys? Good question. When I had an ASW-20 I kept my hand on the release until the ailerons bit, moved the flap lever to position 3 and put my hand back on the release with minimum delay. I always assumed this was close to the optimum, but was that a correct assumption? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
When I had a flapped Nimbus 2, I always set the flaps to zero for the
ground run and selected the first stage of positive once I was established in the full climb. That way I could keep my hand on the release knob during the ground run. The rapid acceleration of a winch launch gives you almost instant control. For aerotows I started in full negative and notched the flaps back as I gained speed and control. Derek Copeland At 14:23 26 June 2009, Martin Gregorie wrote: On Fri, 26 Jun 2009 13:15:04 +0000, Big Wings wrote: Flapped gliders where the setting needs to be changed from negative during the ground run are an interesting case. Starting (aerotow) launches in negative reduces the probability of a wing drop, but one's hand is in the wrong place to react if it does. What is the best option for those guys? Good question. When I had an ASW-20 I kept my hand on the release until the ailerons bit, moved the flap lever to position 3 and put my hand back on the release with minimum delay. I always assumed this was close to the optimum, but was that a correct assumption? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Fri, 26 Jun 2009 15:30:05 +0000, Del C wrote:
When I had a flapped Nimbus 2, I always set the flaps to zero for the ground run and selected the first stage of positive once I was established in the full climb. That way I could keep my hand on the release knob during the ground run. The rapid acceleration of a winch launch gives you almost instant control. For aerotows I started in full negative and notched the flaps back as I gained speed and control. I should have made it clear that was for aero tow: starting the roll in position 2 (-6 degrees) and going to position 3 (zero) once the ailerons are fully effective is SOP for an ASW-20 on aero tow. I flew winch launches entirely in position 3 - zero flap. Martin At 14:23 26 June 2009, Martin Gregorie wrote: On Fri, 26 Jun 2009 13:15:04 +0000, Big Wings wrote: Flapped gliders where the setting needs to be changed from negative during the ground run are an interesting case. Starting (aerotow) launches in negative reduces the probability of a wing drop, but one's hand is in the wrong place to react if it does. What is the best option for those guys? Good question. When I had an ASW-20 I kept my hand on the release until the ailerons bit, moved the flap lever to position 3 and put my hand back on the release with minimum delay. I always assumed this was close to the optimum, but was that a correct assumption? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
The SOP for most flapped gliders is to start in full negative, it makes the
ailerons more effective and enables you to plant the tail wheel firmly on the ground which helps in preventing yaw. It is necessary to ensure that a non negative setting is selected before the tug leaves the ground because if it is not the glider is going by road. This tends to be very bumpy and frightens tug pilots. For winch launching it presents more of a problem, the ASW17 for example has a release hook which is more forward than most modern gliders and in order to get any height it is necessary to move from zero flap, where it was set for takeoff to a plus setting fairly quickly, in fact as soon as the glider was off the ground. I got round the problem of being able to operate the flap and release quickly by looping para cord around the release knob and round my wrist making it long enough to ensure that I could not pull the release inadvertently, and short enough to ensure that I could release before my elbow hit the rear of the cockpit. I could therefore hold the flap lever but instantly release if required. The para cord could be stowed at the top of the launch. At 17:24 26 June 2009, Martin Gregorie wrote: On Fri, 26 Jun 2009 15:30:05 +0000, Del C wrote: When I had a flapped Nimbus 2, I always set the flaps to zero for the ground run and selected the first stage of positive once I was established in the full climb. That way I could keep my hand on the release knob during the ground run. The rapid acceleration of a winch launch gives you almost instant control. For aerotows I started in full negative and notched the flaps back as I gained speed and control. I should have made it clear that was for aero tow: starting the roll in position 2 (-6 degrees) and going to position 3 (zero) once the ailerons are fully effective is SOP for an ASW-20 on aero tow. I flew winch launches entirely in position 3 - zero flap. Martin At 14:23 26 June 2009, Martin Gregorie wrote: On Fri, 26 Jun 2009 13:15:04 +0000, Big Wings wrote: Flapped gliders where the setting needs to be changed from negative during the ground run are an interesting case. Starting (aerotow) launches in negative reduces the probability of a wing drop, but one's hand is in the wrong place to react if it does. What is the best option for those guys? Good question. When I had an ASW-20 I kept my hand on the release until the ailerons bit, moved the flap lever to position 3 and put my hand back on the release with minimum delay. I always assumed this was close to the optimum, but was that a correct assumption? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Pay out winch launch to 2500ft agl.. | WAVEGURU | Soaring | 8 | June 5th 07 07:06 AM |
Winch Launch Videos | Mike Schumann | Soaring | 2 | January 19th 06 11:27 PM |
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 12:33 AM |
Electric winch fatality story in August Soaring | Bill Daniels | Soaring | 0 | August 14th 04 02:37 AM |
Winch launch | M B | Soaring | 0 | October 30th 03 07:33 PM |
