When I had a flapped Nimbus 2, I always set the flaps to zero for the
ground run and selected the first stage of positive once I was established in the full climb. That way I could keep my hand on the release knob during the ground run. The rapid acceleration of a winch launch gives you almost instant control. For aerotows I started in full negative and notched the flaps back as I gained speed and control. Derek Copeland At 14:23 26 June 2009, Martin Gregorie wrote: On Fri, 26 Jun 2009 13:15:04 +0000, Big Wings wrote: Flapped gliders where the setting needs to be changed from negative during the ground run are an interesting case. Starting (aerotow) launches in negative reduces the probability of a wing drop, but one's hand is in the wrong place to react if it does. What is the best option for those guys? Good question. When I had an ASW-20 I kept my hand on the release until the ailerons bit, moved the flap lever to position 3 and put my hand back on the release with minimum delay. I always assumed this was close to the optimum, but was that a correct assumption? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Fri, 26 Jun 2009 15:30:05 +0000, Del C wrote:
When I had a flapped Nimbus 2, I always set the flaps to zero for the ground run and selected the first stage of positive once I was established in the full climb. That way I could keep my hand on the release knob during the ground run. The rapid acceleration of a winch launch gives you almost instant control. For aerotows I started in full negative and notched the flaps back as I gained speed and control. I should have made it clear that was for aero tow: starting the roll in position 2 (-6 degrees) and going to position 3 (zero) once the ailerons are fully effective is SOP for an ASW-20 on aero tow. I flew winch launches entirely in position 3 - zero flap. Martin At 14:23 26 June 2009, Martin Gregorie wrote: On Fri, 26 Jun 2009 13:15:04 +0000, Big Wings wrote: Flapped gliders where the setting needs to be changed from negative during the ground run are an interesting case. Starting (aerotow) launches in negative reduces the probability of a wing drop, but one's hand is in the wrong place to react if it does. What is the best option for those guys? Good question. When I had an ASW-20 I kept my hand on the release until the ailerons bit, moved the flap lever to position 3 and put my hand back on the release with minimum delay. I always assumed this was close to the optimum, but was that a correct assumption? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
The SOP for most flapped gliders is to start in full negative, it makes the
ailerons more effective and enables you to plant the tail wheel firmly on the ground which helps in preventing yaw. It is necessary to ensure that a non negative setting is selected before the tug leaves the ground because if it is not the glider is going by road. This tends to be very bumpy and frightens tug pilots. For winch launching it presents more of a problem, the ASW17 for example has a release hook which is more forward than most modern gliders and in order to get any height it is necessary to move from zero flap, where it was set for takeoff to a plus setting fairly quickly, in fact as soon as the glider was off the ground. I got round the problem of being able to operate the flap and release quickly by looping para cord around the release knob and round my wrist making it long enough to ensure that I could not pull the release inadvertently, and short enough to ensure that I could release before my elbow hit the rear of the cockpit. I could therefore hold the flap lever but instantly release if required. The para cord could be stowed at the top of the launch. At 17:24 26 June 2009, Martin Gregorie wrote: On Fri, 26 Jun 2009 15:30:05 +0000, Del C wrote: When I had a flapped Nimbus 2, I always set the flaps to zero for the ground run and selected the first stage of positive once I was established in the full climb. That way I could keep my hand on the release knob during the ground run. The rapid acceleration of a winch launch gives you almost instant control. For aerotows I started in full negative and notched the flaps back as I gained speed and control. I should have made it clear that was for aero tow: starting the roll in position 2 (-6 degrees) and going to position 3 (zero) once the ailerons are fully effective is SOP for an ASW-20 on aero tow. I flew winch launches entirely in position 3 - zero flap. Martin At 14:23 26 June 2009, Martin Gregorie wrote: On Fri, 26 Jun 2009 13:15:04 +0000, Big Wings wrote: Flapped gliders where the setting needs to be changed from negative during the ground run are an interesting case. Starting (aerotow) launches in negative reduces the probability of a wing drop, but one's hand is in the wrong place to react if it does. What is the best option for those guys? Good question. When I had an ASW-20 I kept my hand on the release until the ailerons bit, moved the flap lever to position 3 and put my hand back on the release with minimum delay. I always assumed this was close to the optimum, but was that a correct assumption? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Pay out winch launch to 2500ft agl.. | WAVEGURU | Soaring | 8 | June 5th 07 07:06 AM |
Winch Launch Videos | Mike Schumann | Soaring | 2 | January 19th 06 11:27 PM |
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 12:33 AM |
Electric winch fatality story in August Soaring | Bill Daniels | Soaring | 0 | August 14th 04 02:37 AM |
Winch launch | M B | Soaring | 0 | October 30th 03 07:33 PM |
