Could this be used in a sailplane?
Old June 29th 09, 03:51 PM posted to rec.aviation.soaring
Default Could this be used in a sailplane?
On Jun 29, 7:26*am, Spam wrote:
If I had one of these ......
http://www.batterystuff.com/solar-chargers/
.....would I be able to fly continously without ever removing the
battery and charging it overnight?
I figured there's alot of smart folks on here who have already thought
this through!
Scott
This is true, search this message board. Unless you are powering just
a radio and vario I doubt if you would get enough power fron cell
inside on the glaresheild.
However, I just saw a SUNPOWER 60 watt kit at COSTCO, less than $5/
watt including inverter and charger and controller. Much better
prices than your link.. One could put a single 15w panel on your
trailer and the battery would be charged before you launch probably...
MM
Old July 2nd 09, 04:54 PM posted to rec.aviation.soaring
CoggFly
There are also flat panels that you can inlay behind the cockpit. I
have 5mAh to keep the batteries topped off in flight.
Another Sailplane Ben Jeffrey Aviation Photos 2 June 24th 08 08:11 PM
Sailplane quiz Mike[_8_] Soaring 5 April 3rd 07 03:45 PM
Pacific D-8 Sailplane tdfsks Soaring 5 March 30th 07 05:42 AM
registering a sailplane in UT Ron Gleason Soaring 4 May 5th 06 01:23 AM
Sailplane Upholstery Gadget Guy Soaring 3 February 15th 06 09:54 PM
