On 29 Jun., 09:23, John Smith wrote:
wrote: Indeed, the inside wing seemed as if it was racing ahead of the terrain. Therefore, I respectfully add one more comment to your good analysis on low-altitude maneuvering: There may be a strong desire to use inside rudder to slow the perceived speed of the inside wing, and to I don't know what you teach your students. In a turn I'm looking at the horizon, the yaw string and possibly the ASI, but certainly not at the wingtip. Dan has touched upon something very, very important here. Something I am convinced can help explain many of those “unexplainable” stall-spin accidents when down low. However it is important to pay some attention to how our brain handles information. There is the conscious part (logical thinking) and the “reptilian brain” (instincts, automatic and very quick reactions) The reptile brain is the one that will have your hand up to protect your eyes when someone throws something at you, long before you had time to “think” about it But the reptile brain was never intended for flying, and it WILL make wrong judgments! The problem is that the reptile brain will act on input by means of sending very direct commands to our arms and legs, totally bypassing the logical thinking part. So even if you are thinking “I'm looking at the horizon, the yaw string and possibly the ASI” your reptile brain may very well be reacting in an instinctive way to the input from the peripheral sight saying “wow that wingtip moves fast forward over the ground” –Incidentally the reptile brain reacts extra strongly to input from the edges of our field of sight. Probably those that noticed that predator out there early lived longer and got to be our forefathers. Unfortunately, when flying a glider it may have the opposite effect. Be safe out there. Lars Peder DG-600 EE, Denmark |
"Lars P. Hansen" wrote:
However it is important to pay some attention to how our brain handles information. There is the conscious part (logical thinking) and the "reptilian brain" [...] Um, shouldn't that be "mammalian brain?" Or more likely you mean there is the frontal lobe and the parietal lobe? But the reptile brain was never intended for flying, and it WILL make wrong judgments! I thought birds were technically considered to be reptiles? So is the information on this link wrong?: http://www.ucmp.berkeley.edu/diapsids/avians.html |
![]() Dan has touched upon something very, very important here. Something I am convinced can help explain many of those “unexplainable” stall-spin accidents when down low. While I don't disagree with this analysis- or the original post, I wonder how many other 'unexplainable' stall-spin accidents were a result of training where primary students were either flat out taught to lead turns with the rudder, or even taught that it's OK to lead with the rudder (a previous religious debate here... http://tinyurl.com/nrgsh7 and http://tinyurl.com/kk8xdp ), a practice which I personally despise for many reasons. In the case of the recent event that prompted this useful discussion, and in quite a rare situation, we may someday be able to actually ask the PIC what happened, and about his previous training. I for one would *really* like to know if he falls into the lead with rudder crowd. Q: Will a ship spin without rudder input? Q: Will a ship turn without rudder input? -Paul |
I seem to spend a lot of time scratching (due to incompetance), but I
rarely get below 500ft and almost never below 400ft. When scratching below 800ft coordination (yaw string) and airspeed (ASI) are alway high on my agenda, and the workload goes up. When mountain flying (much of flight can be within 500ft of surface), and circling up the side of cliffs, not hitting the mountain and control responsiveness also become important. On the rare occasions when I mess up and find myself doing a ground level turn, I do look down the wing in order to ensure that I dont stick the end in a tree or the ground, I expect my rudder control and coordination is maintained due to the many hours of scratching. When doing some two seater xcountry flying recent, my complaint to all the P2s was about their coordination. I must try to work out about pivot heights. My wing always goes backwards. What is the pivot height for a glider flying a 45 deg banked turn at 55 knots? A formula would be nice. Rory |
Rory,
Good points, the one I wanted to reinforce, .... you have to get both speed and yaw seriously wrong to spin most gliders. For a start, at least one wing needs to stall, so "lack of speed kills", ... not a small error with the the rudder. A small speed error, plus rudder, yes. Of course, good coordination all the time is better, but that can be practiced at any height, why do it at 100', 5knts above stall, with a good wind gradient? I am not sure I would thank an instructor that let me try that. Finally, if you are close enough to terain to need to check the wing tip, I wonder if you are looking to see if anything is missing, or looking to see the collision, or can you navigate the glider this way? I imagine it is a "callibration check", takes a split second to complete, and will not interfere with the aviation work load which always comes first. David. At 19:30 29 June 2009, Rory Oconor wrote: I seem to spend a lot of time scratching (due to incompetance), but I rarely get below 500ft and almost never below 400ft. When scratching below 800ft coordination (yaw string) and airspeed (ASI) are alway high on my agenda, and the workload goes up. When mountain flying (much of flight can be within 500ft of surface), and circling up the side of cliffs, not hitting the mountain and control responsiveness also become important. On the rare occasions when I mess up and find myself doing a ground level turn, I do look down the wing in order to ensure that I dont stick the end in a tree or the ground, I expect my rudder control and coordination is maintained due to the many hours of scratching. When doing some two seater xcountry flying recent, my complaint to all the P2s was about their coordination. I must try to work out about pivot heights. My wing always goes backwards. What is the pivot height for a glider flying a 45 deg banked turn at 55 knots? A formula would be nice. Rory |
On Jun 29, 1:30*pm, Rory Oconor wrote:
I seem to spend a lot of time scratching (due to incompetance), but I rarely get below 500ft and almost never below 400ft. When scratching below 800ft coordination (yaw string) and airspeed (ASI) are alway high on my agenda, and the workload goes up. When mountain flying (much of flight can be within 500ft of surface), and circling up the side of cliffs, not hitting the mountain and control responsiveness also become important. On the rare occasions when I mess up and find myself doing a ground level turn, I do look down the wing in order to ensure that I dont stick the end in a tree or the ground, I expect my rudder control and coordination is maintained due to the many hours of scratching. When doing some two seater xcountry flying recent, my complaint to all the P2s was about their coordination. I must try to work out about pivot heights. My wing always goes backwards.. *What is the pivot height for a glider flying a 45 deg banked turn at 55 knots? A formula would be nice. Rory My experience is that airspeed and coordination need to be monitored when flying low. If those are within safe bounds, there's no need to fear stall/spins. There are many optical illusions that can trick you when flying below pivotal altitude - your instruments can be your best friend. Long ago a retired WWII Marine Corp Instructor Pilot taught me something he had learned landing F4U Corsairs on straight deck carriers. If you try, he said, you can train your brain to use a part of your peripheral vision to monitor airspeed even while your gaze is outside the cockpit. At first, with your eyes out of the cockpit, all you can do is locate the ASI but not read it. Still, that helps guide quick glances to the instrument. Soon, those quick glances will not only pick up airspeed, they will also see the trend. In time, it will seem as if you are seeing the ASI full-time with your eyes outside and maybe you are. Even with sunglasses, your pupils are very small in bright light giving you what photographers call a large "depth of field". What you are learning to do is focus your eyes on the "hyper-focal" distance so both the distant horizon and the panel are just within the "depth of field". Try it while thermalling. Human brains are very plastic and can be trained to do this. It's useful not only in landings but also when the natural horizon isn't visible as in canyons or near a ridge. |
On Jun 30, 7:30*am, Rory Oconor wrote:
When mountain flying (much of flight can be within 500ft of surface), and circling up the side of cliffs, not hitting the mountain and control responsiveness also become important. Absolutely. And pretty soon you're not letting the closeness of terrain and changed view put you off normal coordinated flying. I must try to work out about pivot heights. My wing always goes backwards.. *What is the pivot height for a glider flying a 45 deg banked turn at 55 knots? A formula would be nice. I'm not sure it's important, but it's pretty trivial to work out. The condition will be tan(bank_angle) = pivot_height / turn_radius Rearranging: pivot_height = turn_radius * tan(bank_angle) Now of course turn_radius is related to bank_angle by a=v^2/r (centripedal force) and a=tan(bank_angle)*g (g = gravity = 9.8 m/s^2) giving: turn_radius = v^2 / (tan(bank_angle) * g) Substituting: pivot_height = (v^2 / (tan(bank_angle) * g)) * tan(bank_angle) = v^2/g That's pretty remarkable actually. The pivot height depends only on speed, not on bank angle. To convert to knots and feet: pivot_height = speed^2 / 11.3 At 40 knots it is 142 ft. At 55 knots it is 268 ft.. At 75 knots it is 498 ft. At 100 knots is it 885 ft. At 150 knots it is 1991 ft. |
Gldier Pilot Missing after High Altitude Flight | Paul Remde | Soaring | 2 | January 19th 09 03:12 AM |
Vector altitude for ILS below GS intercept altitude? | M | Instrument Flight Rules | 23 | May 20th 06 07:41 PM |
Typical speeds on a low altitude flight? | Bjørnar Bolsøy | Military Aviation | 5 | September 22nd 04 02:59 PM |
Altitude loss for 5h Duration Flight | nyffeler | Soaring | 9 | August 28th 04 11:12 AM |
Pressure Altitude or Density Altitude | john smith | Piloting | 3 | July 22nd 04 10:48 AM |
