Jerry Wass wrote:
Bill wrote: Make it so that you can pull the torsion bar wrench with the snap on-- against each other. They should read the same. How could the torsion wrench be off if it zeros properly and nothing in the ponter binds? Bill Hale Loveland CO You are correct for a bending rod type wrench--but some torque wrenches have a spring loaded(adjustable)hollow handle that allows a piece to pop out of a Vee notch making an audible click that is also felt in the handle--(very handy for torquing where you can't see the dial or pointer. Jerry In the Air Farce we were supposed to click the break type torque wrench three times at the lowest setting before using it. This was supposed to spread the lubrication inside. I like the idea of taking the wrench to a shop to check calibration. Having said that, in my first shop in the USAF we calibrated torque wrenches so I may be a tad biased. The machine we used was huge and probably weighed close to a ton. Torque wrenches in the USAF are periodically calibrated, I forget the cycle, and taken in for calibration if dropped or abused. I wonder if the electronic torque wrenches are worth the money. Has anyone in RAH tried them? Dan, U.S. Air Force, retired |
"Dan" wrote in message
... Jerry Wass wrote: Bill wrote: Make it so that you can pull the torsion bar wrench with the snap on-- against each other. They should read the same. How could the torsion wrench be off if it zeros properly and nothing in the ponter binds? Bill Hale Loveland CO You are correct for a bending rod type wrench--but some torque wrenches have a spring loaded(adjustable)hollow handle that allows a piece to pop out of a Vee notch making an audible click that is also felt in the handle--(very handy for torquing where you can't see the dial or pointer. Jerry In the Air Farce we were supposed to click the break type torque wrench three times at the lowest setting before using it. This was supposed to spread the lubrication inside. I like the idea of taking the wrench to a shop to check calibration. Having said that, in my first shop in the USAF we calibrated torque wrenches so I may be a tad biased. The machine we used was huge and probably weighed close to a ton. Torque wrenches in the USAF are periodically calibrated, I forget the cycle, and taken in for calibration if dropped or abused. I wonder if the electronic torque wrenches are worth the money. Has anyone in RAH tried them? Dan, U.S. Air Force, retired I have not tried the electronic variety; but my recollection is that the click type torque wrenches were supposed to be calibrated annualy--so long as no incident occured, such as dropping or other abuse. Peter |
snip
In the Air Farce we were supposed to click the break type torque wrench three times at the lowest setting before using it. This was supposed to spread the lubrication inside. I like the idea of taking the wrench to a shop to check calibration. Having said that, in my first shop in the USAF we calibrated torque wrenches so I may be a tad biased. The machine we used was huge and probably weighed close to a ton. Torque wrenches in the USAF are periodically calibrated, I forget the cycle, and taken in for calibration if dropped or abused. snip Dan, U.S. Air Force, retired Heck, Dan, in the Air Force there was an alternate torque measuring system that didn't even require a torque wrench. (PMEL calibrated, of course) Simply "strip" it and back off one half turn. Farm boys from Georgia taught me that. Old Chief Lynn |
coffelt2 wrote:
snip In the Air Farce we were supposed to click the break type torque wrench three times at the lowest setting before using it. This was supposed to spread the lubrication inside. I like the idea of taking the wrench to a shop to check calibration. Having said that, in my first shop in the USAF we calibrated torque wrenches so I may be a tad biased. The machine we used was huge and probably weighed close to a ton. Torque wrenches in the USAF are periodically calibrated, I forget the cycle, and taken in for calibration if dropped or abused. snip Dan, U.S. Air Force, retired Heck, Dan, in the Air Force there was an alternate torque measuring system that didn't even require a torque wrench. (PMEL calibrated, of course) Simply "strip" it and back off one half turn. Farm boys from Georgia taught me that. Old Chief Lynn We used the "tighten it until it breaks, then back off a half turn" and the "finger tight, plus a quarter turn" methods. QC wasn't fond of the response "two clicks of the left elbow" when we were asked what the proper torque was. Wasn't the -2 T.O. series issued to sit on or to protect ones knees on a B-4 stand? Not that I ever did that, you understand, but there was talk. Dan, U.S. Air Force, retired |
![]() "Dan" wrote in message ... coffelt2 wrote: snip In the Air Farce we were supposed to click the break type torque wrench three times at the lowest setting before using it. This was supposed to spread the lubrication inside. I like the idea of taking the wrench to a shop to check calibration. Having said that, in my first shop in the USAF we calibrated torque wrenches so I may be a tad biased. The machine we used was huge and probably weighed close to a ton. Torque wrenches in the USAF are periodically calibrated, I forget the cycle, and taken in for calibration if dropped or abused. snip Dan, U.S. Air Force, retired Heck, Dan, in the Air Force there was an alternate torque measuring system that didn't even require a torque wrench. (PMEL calibrated, of course) Simply "strip" it and back off one half turn. Farm boys from Georgia taught me that. Old Chief Lynn We used the "tighten it until it breaks, then back off a half turn" and the "finger tight, plus a quarter turn" methods. QC wasn't fond of the response "two clicks of the left elbow" when we were asked what the proper torque was. Wasn't the -2 T.O. series issued to sit on or to protect ones knees on a B-4 stand? Not that I ever did that, you understand, but there was talk. Dan, U.S. Air Force, retired Oh, yeah! Been retired for more than 30 years, and knees still have the B-4 stand grate imprint. Never realized the -2 was so versatile! Old Chief Lynn |
coffelt2 wrote:
"Dan" wrote in message ... coffelt2 wrote: snip In the Air Farce we were supposed to click the break type torque wrench three times at the lowest setting before using it. This was supposed to spread the lubrication inside. I like the idea of taking the wrench to a shop to check calibration. Having said that, in my first shop in the USAF we calibrated torque wrenches so I may be a tad biased. The machine we used was huge and probably weighed close to a ton. Torque wrenches in the USAF are periodically calibrated, I forget the cycle, and taken in for calibration if dropped or abused. snip Dan, U.S. Air Force, retired Heck, Dan, in the Air Force there was an alternate torque measuring system that didn't even require a torque wrench. (PMEL calibrated, of course) Simply "strip" it and back off one half turn. Farm boys from Georgia taught me that. Old Chief Lynn We used the "tighten it until it breaks, then back off a half turn" and the "finger tight, plus a quarter turn" methods. QC wasn't fond of the response "two clicks of the left elbow" when we were asked what the proper torque was. Wasn't the -2 T.O. series issued to sit on or to protect ones knees on a B-4 stand? Not that I ever did that, you understand, but there was talk. Dan, U.S. Air Force, retired Oh, yeah! Been retired for more than 30 years, and knees still have the B-4 stand grate imprint. Never realized the -2 was so versatile! Old Chief Lynn Checklists were also great on grates. Pity they weren't good for protection from joining the KC-135 waffle head club, I joined in 1975. Dan, U.S. Air Force, retired |
![]() "coffelt2" wrote in message ... snip In the Air Farce we were supposed to click the break type torque wrench three times at the lowest setting before using it. This was supposed to spread the lubrication inside. I like the idea of taking the wrench to a shop to check calibration. Having said that, in my first shop in the USAF we calibrated torque wrenches so I may be a tad biased. The machine we used was huge and probably weighed close to a ton. Torque wrenches in the USAF are periodically calibrated, I forget the cycle, and taken in for calibration if dropped or abused. snip Dan, U.S. Air Force, retired Heck, Dan, in the Air Force there was an alternate torque measuring system that didn't even require a torque wrench. (PMEL calibrated, of course) Simply "strip" it and back off one half turn. Farm boys from Georgia taught me that. Old Chief Lynn Hey don't forget the proper torque on the propellor retaining nut on the 4360 was "All you can with both hands on the Cheater Bar, then a 1/4 turn more". Note proper Cheater Bar was 6' long. Stu Fields B-36 engine change crew. |
On Jun 29, 9:53*pm, "coffelt2" wrote:
snip * In the Air Farce we were supposed to click the break type torque wrench three times at the lowest setting before using it. This was supposed to spread the lubrication inside. * I like the idea of taking the wrench to a shop to check calibration.. Having said that, in my first shop in the USAF we calibrated torque wrenches so I may be a tad biased. The machine we used was huge and probably weighed close to a ton. Torque wrenches in the USAF are periodically calibrated, I forget the cycle, and taken in for calibration if dropped or abused. snip Dan, U.S. Air Force, retired * * *Heck, Dan, in the Air Force there was an alternate torque measuring system that didn't even require a torque wrench. (PMEL calibrated, of course) Simply "strip" it and back off one half turn. Farm boys from Georgia taught me that. Old Chief Lynn Yeah, but ya gotta know the difference between metric and SAE torque. SAE = 1 3/4 grunts Metric = Gutentieght |
bildan wrote:
On Jun 29, 9:53 pm, "coffelt2" wrote: snip In the Air Farce we were supposed to click the break type torque wrench three times at the lowest setting before using it. This was supposed to spread the lubrication inside. I like the idea of taking the wrench to a shop to check calibration. Having said that, in my first shop in the USAF we calibrated torque wrenches so I may be a tad biased. The machine we used was huge and probably weighed close to a ton. Torque wrenches in the USAF are periodically calibrated, I forget the cycle, and taken in for calibration if dropped or abused. snip Dan, U.S. Air Force, retired Heck, Dan, in the Air Force there was an alternate torque measuring system that didn't even require a torque wrench. (PMEL calibrated, of course) Simply "strip" it and back off one half turn. Farm boys from Georgia taught me that. Old Chief Lynn Yeah, but ya gotta know the difference between metric and SAE torque. SAE = 1 3/4 grunts Metric = Gutentieght Good'n'tight is GI German for good day. Peter strain or I'll be the same are GI German for goodbye. Not that I would know anything about that stuff there. Dan, U.S. Air Force, retired |
![]() "Dan" wrote in message ... bildan wrote: On Jun 29, 9:53 pm, "coffelt2" wrote: snip In the Air Farce we were supposed to click the break type torque wrench three times at the lowest setting before using it. This was supposed to spread the lubrication inside. I like the idea of taking the wrench to a shop to check calibration. Having said that, in my first shop in the USAF we calibrated torque wrenches so I may be a tad biased. The machine we used was huge and probably weighed close to a ton. Torque wrenches in the USAF are periodically calibrated, I forget the cycle, and taken in for calibration if dropped or abused. snip Dan, U.S. Air Force, retired Heck, Dan, in the Air Force there was an alternate torque measuring system that didn't even require a torque wrench. (PMEL calibrated, of course) Simply "strip" it and back off one half turn. Farm boys from Georgia taught me that. Old Chief Lynn Yeah, but ya gotta know the difference between metric and SAE torque. SAE = 1 3/4 grunts Metric = Gutentieght Good'n'tight is GI German for good day. Peter strain or I'll be the same are GI German for goodbye. Not that I would know anything about that stuff there. I beg to differ. Good'n'tight is German for virgin. |
Thin 3/8" wrench | RST Engineering | Home Built | 10 | November 17th 06 12:52 PM |
Flight wrench question | R.H. | Piloting | 14 | June 25th 06 03:48 PM |
Ignition lead nut-wrench | jerry wass | Aviation Marketplace | 0 | April 8th 06 03:55 AM |
Wrench size for KI214 & KI201 OBS knob | Roy Page | Owning | 7 | March 11th 05 10:07 PM |
Volkslogger Calibration | Ray Lovinggood | Soaring | 5 | September 13th 03 04:56 PM |
