spanky wrote:
James Robinson wrote: spanky wrote: My understanding from the pros in other groups, is that message simply says that the autolimiter disconnected, and as mentioned, the limits are clamped at what they were prior to the disconnect. *It is supposedly part of the change from normal to alternate law. ...and if the pitot tubes were providing low airspeed data (which the OP mentioned in his post, saying "the Captains, First Officers, and standby airspeed indicators rolled back to 60kts...") prior to the rudder travel limiter disengage, those travel limits would be far less stringent than if the ADC "knew" the aircraft was travelling at cruise speed. Three separate systems all roll back to the same speed identical simultaneously? That is beyond wild speculation. As soon as one didn't match the others, the system would cut out. This was followed in fairly short order by a TCAS fault, an autothrottle disconnect, a/p disconnect and institution of alternate flight law algorithms. * Look at the failure point of the 447 vertical stab and compare that with the failure point of the AA 300 that went down in 2001 on departure from JFK. * They are different. *Not at all the same type of attachment or type of failure. Wrong. Both failure modes are nearly identical in apparent result (side loads beyond design limits) and the attach fittings (composites with steel/titanium attach points) are nearly identical as well. look at the photographs of both verticals. there is no crushing on the lower leading or lower trailing edges of the AF447 component that would indicate the failure took place fore and/or aft; on the other hand, the AF447 vertical shows skin tears along its lower edge that would indicate that the failure mode was due to sideloads exceeding design limits. Wrong. The AA failure was in the attachment lugs, and the rudder was completely missing. In the photos of the AF VS, you can see the lugs are intact, and that the failure was in the surrounding structure, plus most of the rudder is still attached. Further, the attachment arrangement between the 310 and the 330 was redesigned. Despite having a rudder travel limiter in place and working, The A300 was not a FBW aircraft. So what. The A300-600 has a rudder travel limiter, and its effectiveness has been the subject of numerous NTSB Safety Recommendations, to whit: "A review of the flight data for rudder position showed that, even after accounting for the slow response rate of the RTL, the rudder still appeared to exceed the estimated position at which it should have been limited by the RTL. This exceedance was as high as 4° near the end of the upset. The A300-600 RTL is designed and constructed so that it limits the rudder by reducing the allowable displacement of the rudder pedals. Testing of the RTL determined that if a pilot applies a sufficiently large pedal force when the pedal is at its travel limit, this will further slow or stop the movement and, consequently, the effectiveness of the RTL. As demonstrated by this event, such slowing or stopping of the RTL by application of large pedal forces could result in the rudder position substantially exceeding the designed travel limit. The Safety Board is concerned that such an increase in available rudder beyond the designed RTL restrictions could permit excessive rudder movements and possibly result in high loads on the vertical stabilizer." My point is that the two aircraft are entirely different, as are the controls limiting rudder travel. You might as well be trying to compare a Boeing and an Airbus because they both have two wings and a tail. the 2001 incident proved rather markedly that it is entirely possible, even at climb speeds, to overstress the vertical attach points of the structure. *...at cruise, in what may have been beyond extreme turbulence, that possibility may indeed be a probability in this case. Why would an experienced pilot be using the rudder at all at cruising speed and at that altitude? Because the first word governing an experienced crew's reaction to an emergency is "Aviate." That means (especially in light of a highly experienced crew reacting to an A/P disconnect as well as multiple warnings) put your feet on the pedals and your hands on the yoke and fly the thing until you, and the rest of the crew, can sort it all out. CRM 101. Which means they wouldn't consider using the rudder at high speed and altitude. There is practically no situation I can think of where an experienced crew would consider using the rudder. The rudder simply isn't used to "aviate" at altitude. Using it would be an indication of inexperience. We'll never know until the FDRs and CVRs are found and the data downloaded, but on that subject I have no faith that they will be found and, given Airbus's shenanigans with black boxes from earlier incidents, I have no faith that the company wants them to be found. So they will just hope no other aircraft decide to disappear while in cruise flight? Or do you think they already know what went wrong, and are correcting it behind the curtain? i have no opinion one way or another. all i know is that there was a fly-by accident at a press event years ago involving (if i recall correctly) an A320 where, despite a TOGA command, the aircraft did not respond and sank into the trees at the end of the runway. when the "black boxes" were made available to the NTSB and public the serial numbers (as well as the paint) on what were purported to be the boxes from the accident aircraft were not the same as those that had been installed on the accident aircraft. You certainly do have an opinion, or you wouldn't have been posting this stream of misinformation. BEA is now saying that AF447 entered the water in one piece, in a horizontal attitude, but with a high vertical force. That pretty well describes a flat spin. That would not have happened if the VS separated at high altitude. http://tinyurl.com/mb4mmt (en Francais) And I see a number of US media sources can't translate French aeronautical terms correctly, as they are saying the aircraft went straight down, almost vertically. Il paraît avoir heurté la surface de l'eau en ligne de vol Means that the aircraft struck the surface in a horizontal attitude. avec une forte accélération verticale" Means with high vertical acceleration, meaning it was in an aerodynamic stall. |
BEA is now saying that AF447 entered the water in one piece, in a horizontal attitude, but with a high vertical force. That pretty well describes a flat spin. That would not have happened if the VS separated at high altitude. http://tinyurl.com/mb4mmt (en Francais) And I see a number of US media sources can't translate French aeronautical terms correctly, as they are saying the aircraft went straight down, almost vertically. Il paraît avoir heurté la surface de l'eau en ligne de vol Means that the aircraft struck the surface in a horizontal attitude. avec une forte accélération verticale" Means with high vertical acceleration, meaning it was in an aerodynamic stall. BEA is also reporting that the vertical stabilizer separated from the aircraft from the back to front, with a slight leftward twist. They also said that faulty pitots were a factor in the accident, but not the cause. Whatever conclusions you can draw from those statements. |
On Jul 2, 7:18*am, James Robinson wrote:
spanky wrote: James Robinson wrote: (snip) you're not a pilot, are you? |
FWIW - One magazine's top ten harrowing airports | Paul T. | Aviation Photos | 2 | April 13th 08 06:59 PM |
FWIW, Moller Again ? | Al G[_2_] | Piloting | 62 | July 12th 07 06:59 PM |
FWIW, Moller Again ? | Al G[_2_] | Home Built | 65 | July 12th 07 06:59 PM |
airbus - Latest Plane From Airbus.jpg | [email protected] | Aviation Photos | 14 | June 26th 07 09:41 AM |
Soviet Ekranoplan redux, FWIW | Ogden Johnson III | Naval Aviation | 0 | March 23rd 04 08:44 PM |
