On 2 July, 20:21, Brian wrote:
I totally believe most stall spin accident soccur because the pilot is not thinking about a stall spin and is not on the hair trigger ready to recover, .i.e. they are distracted from this issue. I believe that many of the spin accidents in the UK occur because most pilots are trained ab initio in unspinnable gliders and, whatever their instructors say, end up believing deep down that spins have to be specially provoked in specially prepared or chosen aircraft. What glider has killed most pilots in spins? The K21. Ian |
That is a bit unfair on the K21!. The training glider that has killed the
most pilots in spin related accidents in the UK is easily the Puchacz, latest count about 14 I believe. The K21 is a very safe glider in itself, but even that will do enough of a wing drop to have you into the ground off a poorly executed low final turn. My club still uses K13s as its basic trainer as it will just about drop wings and spin if you force it to, but it is still more docile than many single seaters. You are getting into the debate about whether deliberate spin training kills more people than accidental spins. I know from personal experience that an unexpected spin, e.g. in a rough thermal, can come as a bit of a shock, and it can take time to remember what to do about it. Derek Copeland At 09:17 03 July 2009, Ian wrote: On 2 July, 20:21, Brian wrote: I totally believe most stall spin accident soccur because the pilot is not thinking about a stall spin and is not on the hair trigger ready to recover, .i.e. they are distracted from this issue. I believe that many of the spin accidents in the UK occur because most pilots are trained ab initio in unspinnable gliders and, whatever their instructors say, end up believing deep down that spins have to be specially provoked in specially prepared or chosen aircraft. What glider has killed most pilots in spins? The K21. Ian |
At 11:00 03 July 2009, Del C wrote: (Snip)
The training glider that has killed the most pilots in spin related accidents in the UK is easily the Puchacz, latest count about 14 I believe. And no positively identified cause, the conclusion has always been that the spin in was caused by an error of skill by the pilot but that is difficult to confirm. It could be that under certain loading conditions the Putchaz is irrecoverable from a spin, we may never know for certain. We do know that the Putchaz is a very dangerous glider, and has been involved in more than it's fair share of accidents. You are getting into the debate about whether deliberate spin training kills more people than accidental spins. There is no debate, more people are killed in deliberately induced spins than in accidental ones and yet people still deliberately spin at ridiculously low altitudes, and by that I mean below 2500ft. This despite the fact that knowing the spin recovery procedure would be unlikely to help in the most common spin, that off the final turn. The only thing that would help there is spotting the impending spin before it happened but little or no emphasis is placed on this in current training. We have the situation where the most life threatening situation is not addressed by proper training and an aspect, which gives an instructor the opportunity to scare his pupil witless, is very well covered. Current spin training is more about addressing the needs of the instructors than about addressing the need of their pupils. I would suggest that not commencing spin recovery procedure in a low spin, as off the final turn, would be more likely to save your life than getting part way through the recovery. More emphasis is needed on recognition of the lead up and prevention, if that was done properly then we might improve things. By all means teach it but rather than checking recovery every year check the ability to recognise and prevent. Less risk and the potential of greater benefit, it would also reduce the need for clubs to own the potentially lethal Putchaz as the recognition and prevention could be done in any two seater. |
On 3 July, 15:45, Don Johnstone wrote:
We do know that the Putchaz is a very dangerous glider, and has been involved in more than it's fair share of accidents. That is a correlation, not a causation. Most Puchacz spin accidents occur with instructors on board: perhaps the problem lies with instructor training? You are getting into the debate about whether deliberate spin training kills more people than accidental spins. There is no debate, more people are killed in deliberately induced spins than in accidental ones... That's meaningless unless we know how many deliberate and accidental spins there are, what proportion result in deaths, and how many deliberate spins those who die in accidental ones have done. And I'm still not sure I believe it. How many of the spins of a broken cable or at the final turn are deliberate. Less risk and the potential of greater benefit, it would also reduce the need for clubs to own the potentially lethal Putchaz as the recognition and prevention could be done in any two seater. As long as there are spinnable single seaters out there, that's just asking for trouble. Ian |
Ian
In one message you said: "Juniors have a complicated spin mode which is generally three turns nose down and recoverable, three flat and unrecoverable, rinse, repeat. If you don't recover in the first three turns (Turn 1: ****, better get the nose up. Turn 2: why didn't that work? Turn 3: What's spin recovery again?) you just have to sweat it out for a few hundred feet or your current altitude, whichever is less." and elsewhere "You are quite right - I should have said that the oscillation is at lighter weights / after CoGs." So a Junior behaves strangely with an aft CofG, and in your words is unrecoverable. My first point is the glider should not be flying and should certainly never have been certified under JAR if that is true, unless of course the CofG is aft of the permitted limit. What is really interesting is what you say about the Puchaz, which comes from the same design shop and that is: "That is a correlation, not a causation. Most Puchacz spin accidents occur with instructors on board: perhaps the problem lies with instructor training?" In fact I cannot recall an accident where a Puchacz has spun in solo. You are absolutely correct then when you say the accidents only occur with an instructor on board, or more correctly when the back seat is occupied. So we have a different loading situation in a glider which comes from the same design shop as another glider with known spin recovery problems if the CofG is moved aft. So is there the same problem with the Puchacz as with the Junior, and is that problem in fact worse to the extent that there is no recovery? We cannot know for sure but there is evidence that points that way. Does this not raise any concerns? I know we cannot prove that the Puchacz will not recover under certain loading conditions any more that we can prove that the spin ins have been caused by pilot error. The truth is that the Puchacz has been proved to be a glider that frequently kills people. I experienced a spin recovery in a Puchacz that was prolonged to an extent that I thought it was not going to recover. It did eventually. It is very easy to blame the unknown on pilot error but I suggest that we should at least consider the possibility that there is a major problem with the Puchacz, one which should mean that it is not intentionally spun as an absolute minimum. We are never going to have a pilot tell us "This glider was impossible to get out of a spin", because if that is the case he is dead and not saying much. My personal view is that there is sufficient evidence to show that the Puchacz is a dangerous glider, so dangerous in fact that it should never be flown again. |
with the Junior, and is that problem in fact worse to the extent that there is no recovery? We cannot know for sure but there is evidence that points that way. Yes, we can and do know. The Puchacz as well as the Junior have been frequently flown in aerobatics contests. To my knowledge, no Puch nor Junior has been spun into the ground during a contest. So they do recover. More, they even do recover forseeably and precisely, otherwise they wouldn't be flown in contests. |
At 21:31 03 July 2009, John Smith wrote:
Don Johnstone wrote: with the Junior, and is that problem in fact worse to the extent that there is no recovery? We cannot know for sure but there is evidence that points that way. Yes, we can and do know. The Puchacz as well as the Junior have been frequently flown in aerobatics contests. To my knowledge, no Puch nor Junior has been spun into the ground during a contest. So they do recover. More, they even do recover forseeably and precisely, otherwise they wouldn't be flown in contests. Yes, but are they flown in contests with the CofG aft and in the case of the Puchacz with the rear seat occupied with a heavier pilot? I doubt it. I am not saying that under all loading conditions that there is a problem. What I am suggesting is that under some loading conditions there may well be. What has been said in previous posts tends to indicate there might be. Evidence from pilots who recover is unhelpful, evidence from pilots who don't is not available. My one experience (in a Puchacz) showed me that there was a problem and I resolved from that day that I would never walk under one let alone fly in one again. I assume the instructor filed a report, at the time I was not involved with the BGA at all. |
On Jul 3, 4:31*pm, John Smith wrote:
Don Johnstone wrote: with the Junior, and is that problem in fact worse to the extent that there is no recovery? We cannot know for sure but there is evidence that points that way. Yes, we can and do know. The Puchacz as well as the Junior have been frequently flown in aerobatics contests. To my knowledge, no Puch nor Junior has been spun into the ground during a contest. So they do recover. More, they even do recover forseeably and precisely, otherwise they wouldn't be flown in contests. I can cite more than one instance where an "experienced pilot" has spun a "well known" design, under "normal" circumstances resulting in "unexpected" characteristics. There are dozens, or more, variables involved and to assume that you have seen all the possibilities is shortsighted to say the least. You should not assume that you are doing everything the same way every time, with identical equipment. I've experienced such episodes and no longer will "explore" that part of a flight envelope. An appropriate phrase for such activity is "practice bleeding". |
It will be important for Soaring pilots to know whether the recent
crashes were from a spinning or a spiraling ship..That most likely can be determined by the type of impact. Simply, every pilot should recognize and recover from an incipient spin. If he or she is not sure, one should be shown in a Blanik or similar spin happy ships. A glider in flight should really never come close to a spiral, since it is approaching red line fast. I feel the reason gliders get into spirals is not only the lack of spin recognition of the pilot, but poor flying technique. Yaw string, airspeeds, coordination. Of course all those problems can happen to a pilot becomming sick, passing out or similar. I have programmed myself to immidiately pull the trim all the way back and let go of the controls. Not sure if that would help, depends on the ship? soarski |
![]() My personal view is that there is sufficient evidence to show that the Puchacz is a dangerous glider, so dangerous in fact that it should never be flown again. Detailed 'puchy' spin analysis found he http://www.ssa.org/members/johnson/f...72-1994-06.pdf It's actually pronounced poo-hots BTW, but I'm not sure how it translates in plurality... regardless, it is odd how many have drilled into the ground with competent pilots and instructors onboard though. Of course there's the rudder pedal theory (rear pilot's feet obstructing mechanism's full travel...), but it's just that- a theory. -Paul |
Any Spins Lately?? | Ol Shy & Bashful | Piloting | 28 | September 6th 07 10:22 PM |
Found on another site 08-747 Spiral stairs to lounge 08.jpg (1/2) | Just Plane Noise[_2_] | Aviation Photos | 0 | August 10th 07 02:39 PM |
Found on another site 08-747 Spiral stairs to lounge 08.jpg (2/2) | J.F. | Aviation Photos | 0 | August 10th 07 02:14 PM |
Spiral Dives Explanation. | Sandy Stevenson | Soaring | 6 | August 26th 05 12:34 PM |
Paraglider spiral dive, throws chute and ends up in the trees | Stewart Kissel | Soaring | 8 | March 1st 05 10:04 PM |
