V-4 Missile Possibilities
Old January 7th 04, 05:58 PM
robert arndt
steve gallacci wrote in message ...
First of all, it's not a "thingy". It is positively a Pabst ramjet as
evidenced by its connection to one of the Fw Triebflugel's wings seen
in the photo. And it is being windtunnel tested.
That, except for the Triebflg. wing (more likely a simple streamlined
strut)was what I was suggesting. The guy was being a dunderhead. Of
course it wasn't moving, it was a test article in a wind tunnel! Jeez.
You're possibly correct on the wing except that other simlar test rigs
don't match the Triebflugels wing. Anyway the pic is from a
Triebflugel site.
I didn't think the "V-4" ramjet looked
all that much like a Pabst ramjet though.
Really? OK, here's a comparison of all the late-war ramjets available
to the Germans:
The Pabst engines were usually proportionally shorter, but all in all,
that isn't all that important.
It is when compared to the two other available ramjet engines of which
we both agree CANNOT be the one depicted above the V-4. The Germans
didn't have any other types...
Still think it might have been
a Rheinbote like missile with a ramjet sustainer, which could have been
done with a minimum of effort.
On the Unicraft page the first depiction shows the V-4 missile with a
RATO unit slung underneath for catapult launch. Rhinebote was powered
by a rocket engine and launched off a SSM erector. The V-4 was
launched like the V-1:
You're not thinking like an engineer. The Rheinbote was a dirt simple
rocket stack, a tube with fuel and fins. To rethink the function with a
ramjet instead of solids is almost a no-brainer. That makes the
development of the "V-4" more credible, even if it wasn't done by the
Rheinbote team, anyone with some ramjet R&D and even a hint of a notion
of V-1 or Rheinbote ops could easily put it together.
Not possible at all at that time. The V-1 (aka Fi-103, FZG-76) took
years to develop. Rheinbote was started in 1943. One is a short range
artillery rocket, the other a long range flying bomb meant to hit
Sweden. There's no comparison between the two other than you thinking
it is a derivative of the Rheinbote due to (I assume) general
appearance without the ramjet. BTW, an engineer cannot simply strap on
an experimental ramjet onto a Rheinbote-like missile, add wings, and
hope it makes it to Sweden. On Misdroy they had catapults aimed
towards Sweden, not the West. The ramps were for the V-4. Misdroy was
also the testing ground for the long-range V-3 weapon which fired
shells at Luxembourg. The Rheinbote, OTOH, was made by
Rheinmetall-Borsig and used to shell Antwerp in Nov '44- 220 being
fired. Its maximum range was 135 miles. No Rheinbote was on Misdroy.
Misdroy was the testing ground for long-range missiles and shells.
The two other depictions of the V-4 on the Unicraft page suggest
postwar research done by the Russians at N-II-88. The V-4 on top of
the V-2 looks remarkably similar to the Russian EKR concept, but in
that case the V-4 was replaced with a Sanger-looking missile.
I suspect the "V-4" on top of an A-4 was little more than wishful
thinking at the time.
For that matter, the "V-4" was likely little more than a vaporware
threat rather than a credible piece of hardware.
It wouldn't make any sense to threaten a neutral nation like Sweden
with a non-existant weapon in 1945 with the Allies closing in on
Germany. If you remember postwar it was Sweden that complained about
the "Ghost Rockets" coming from the same region. Most "Ghost Rockets"
were described as long cigar-shaped burning objects. These were
suspected of being Russian modified extended-body V-1s but looking at
the V-4... it looks like a strong possibility, especially if a Swede
saw it from below, the ramjet unseen burning above the body.
Rob
Old January 8th 04, 03:44 AM
steve gallacci
No, but they could strap on a ram jet and wings to see how much range
they could get, and develop from there. Considering how much impulse
they got out of the first stage of the Rheinbote, I'm suprised there
wasn't more R&D done with the system. Using a ramjet instead of another
stage or two(or three) would seem to be a logical growth direction. And
the arti guys were no entirely unaware of ramjets, with the R&D done
with ramjet shells and such.
But to have this "V-4" spring up out of nowhere, without any R&D trail
or name attached to its manufacture seems a bit iffy. If it was purpose
designed, then why not a better configuration? A better length/diameter
ratio or tapered rear fuselage would have been obvious. Now, a lack of
taper could be to accommodate a tail mounted rocket motor to supplement
the catapult and rato strap ons. But unless the was based on something
else, the length/diameter ratio seems off.
Where was "Misdroy"? My refs mention it too, but can't find it on a map.
I don't know about "ghost rockets" but at least one A-4 ended up in that
direction. But in general, the whole threaten Sweden things soulds more
than a bit iffy, and given the nature of the time, Germany did have all
kinds of scary things so even a bluff would have had weight, on the one
hand, and on the other, the Swedes would have known that the German's
days were numbered and even a wonder weapon threat would have seemed a
bit toothless.
Even if some kind of launch rig was built, that doesn't mean there as
anything to launch, other than, perhaps, more V-1s.
Old January 16th 04, 11:16 AM
JasiekS
Uzytkownik "steve gallacci" napisal w wiadomosci
[snip...]
You cannot find this place if you didn't have BdV (Bund der Vertriebener)
approved maps. Try finding Miedzyzdroje (or better Miedzyzdroje), which is
proper Polish name for this city located on Wolin island East of Swinoujscie
(Swinemuende) and North of Szczecin (Stettin). If you are a little bit
nostalgic you can see a strange German-Polish site http://www.misdroy.de/ or
even buy pre-war photos
http://www.sammler-bonn.de/online-sh...pommern/misdro
y/misdroy.htm.
[snip...]
Regards
JasiekS
Warsaw, Poland
Australia to participate in US missile defence program David Bromage Military Aviation 40 December 13th 03 01:52 PM
AIM-54 Phoenix missile Sujay Vijayendra Military Aviation 89 November 3rd 03 09:47 PM
Poland: French Missile Report Was Wrong Michael Petukhov Military Aviation 8 October 7th 03 10:54 PM
Surface to Air Missile threat PlanetJ Instrument Flight Rules 1 August 14th 03 02:13 PM
Rafael's AIM-AIR IR Missile Countermeasure JT Military Aviation 8 July 13th 03 03:41 AM
