Soaring Aids Variometer
Old July 2nd 09, 07:15 PM posted to rec.aviation.soaring
Tony Condon[_2_]
Default Soaring Aids Variometer
Tim -
Easy enough I suppose. when I first got the Cherokee it had an old
Crossfeld electric vario in it. the audio part didnt work. Either the
flask or the battery was hooked up backwards and when I was in lift it
showed down and when I was in sink it showed lift. Also, the scale was
way off. The highest I ever saw was like 2 feet per second but usually it
was between 1/2 and 1 fps (down) when i was in lift that was stronger than
that. I actually learned how to read that old thing and got fairly good
at working lift with it.
-Tony Condon
Cherokee II N373Y
Old July 3rd 09, 12:04 AM posted to rec.aviation.soaring
Tim Mara[_2_]
I sold Soaring Aids Variometers many years ago (20 + years or more) they
were made by Marvin Willis in Arlington Texas..these were even then an old
design but a lot of us liked them back then....always worked pretty well at
the time..if you'll drop me a note I'll give you a Tel# you might try...
tim
"Tony Condon" wrote in message
Tim -
-Tony Condon
Cherokee II N373Y
Old July 3rd 09, 06:15 AM posted to rec.aviation.soaring
Steve Leonard[_2_]
If the ports are on opposite sides of the case, you can hold you hand in
front of one port and walk around your house. It will show up when you
block your walking speed from the static connection.
You could do a similar thing by connecting a piece of tubing to it and
bending it around so it points back as you walk. Again, the vario will
show up when the capacity port is open to your walking dynamic pressure.
This is probably safer than taking a battery, wires, and a suspicious
looking package to a tall building and trying to use the express elevator
to get to the top floor.
Steve Leonard
Old July 4th 09, 08:33 AM posted to rec.aviation.soaring
front of one port and walk around your house. *It will show up when you
bending it around so it points back as you walk. *Again, the vario will
Steve Leonard
You crack me up Steve! And I missed you at IVSM
Old July 4th 09, 11:24 AM posted to rec.aviation.soaring
Surfer!
In message , Tim Newport-Peace
] writes
snip
Years ago, there was one of these in a London Gents Outfitters (Horne
Bros, Tottenham Court Road) that had been surreptitiously calibrated for
the purpose testing Varios.
For some reason I cannot imaging you ever going near a Gents Outfitters
- at least not to buy clothes! Did they ever work out what their lift
was being used for? And did it have a lift operator?
Surfer!
Email to: ramwater at uk2 dot net
Soaring Aids Variometer Tony Condon[_2_] Soaring 0 July 2nd 09 04:00 PM
Hearing Aids Casey Wilson Piloting 9 February 20th 06 01:40 AM
Yet another case of AIDS jsmith Piloting 12 March 18th 05 01:20 AM
question about the state of the arts of landing aids on aircraft carriers Charlie Wolf Naval Aviation 0 March 6th 05 02:25 AM
AFMC pilot initiative aids test, operational worlds Otis Willie Military Aviation 0 February 19th 04 12:01 AM
