On Jul 3, 5:45*pm, Don Johnstone wrote:
At 21:31 03 July 2009, John Smith wrote: Don Johnstone wrote: with the Junior, and is that problem in fact worse to the extent that there is no recovery? We cannot know for sure but there is evidence that points that way. Yes, we can and do know. The Puchacz as well as the Junior have been frequently flown in aerobatics contests. To my knowledge, no Puch nor Junior has been spun into the ground during a contest. So they do recover. More, they even do recover forseeably and precisely, otherwise they wouldn't be flown in contests. Yes, but are they flown in contests with the CofG aft and in the case of the Puchacz with the rear seat occupied with a heavier pilot? I doubt it. I am not saying that under all loading conditions *that there is a problem. What I am suggesting is that under some loading conditions there may well be. What has been said in previous posts tends to indicate there might be. Evidence from pilots who recover is unhelpful, evidence from pilots who don't is not available. My one experience (in a Puchacz) showed me that there was a problem and I resolved from that day that I would never walk under one let alone fly in one again. I assume the instructor filed a report, at the time I was not involved with the BGA at all. I think the Puchacz spin characteristics are well explained in this report. http://www.tsb.gc.ca/eng/rapports-re...4/a05o0204.asp Note the paragraph where is states that after extensive testing they found that the only way a recovery could be prevented is by holding full back stick. It further states that the nose must be pushed to a very steep nose down attitude, which appears from the cockpit to be past the vertical, to get reliable recovery. They suggest that failed spin recoveries likely result from pilots unwilling to push the nose that far down. The Puchacz POH can be found he http://soargbsc.com/members/manuals/puchacz.pdf It has two pages devoted to spins. It specifies that the ailerons MUST be held neutral, otherwise oscillations will result. It also says that with the CG aft of the mid point, the stick has to go forward of neutral elevator and to expect the spin may continue beyond one turn after anti- spin controls are applied. It also says rudder and elevator control forces are high during the spin recovery. It seems reasonable to say that Puchacz are spun in by pilots who are unfamiliar with its special spin recovery characteristics - perhaps by pilots who haven't bothered to read the POH and believe all they have to know is the "standard spin recovery" technique. The Puchacz is not a dangerous glider. There may be dangerous pilots who fly them, however. |
At 21:15 04 July 2009, bildan wrote: (snip)
The Puchacz is not a dangerous glider. There may be dangerous pilots who fly them, however. How would you describe a glider in which so many people have been killed in spinning incidents? Unlucky? Challenging? or Misunderstood perhaps? I fully accept the reports of the pilots who tested the glider and found that it recovered, if it had not they would not have been able to report that it didn't. Of course no-one is going to design a glider that cannot recover from a spin, and of course no-one is going to design an airliner where the doors fall off either, causing major structural failure. I do not think that the level of expertise found at McDonnell-Douglas exists in a glider design facility. Design faults are found in aircraft after release to service and mostly something is done or at least restrictions are put in place to counteract the fault, not so with the Puchacz. The reason why no-one has reported that a Puchacz is impossible to recover is that if it has happened the pilots have not survived to do so. It is easy to blame someone when they are not around to challenge that finding and this is certainly what the Canadian report does. Is the best explanation that anyone can come up with is that the glider attracts more than it's fair share of dangerous pilots. I have little doubt that the Putchacz will go on killing people while it is permitted to continue to fly, it won't be me, I will never fly in one again. |
I have done quite a few flights in the Puchacz. It is a perfectly nice
glider, albeit with a slightly greater tendency to spin than most West European designs. Ditto the Junior. They will both recover using the standard spin recovery, although you may have to get the stick well forward and hold it there until the spin stops. I personally prefer training gliders that spin properly and require a positive recovery. With the K13 for example, you are never quite sure whether it will go into a spin or a spiral dive, and it will usually recover from a spin as soon as the stick is moved off the backstop. not very realistic! Derek Copeland At 23:30 04 July 2009, Don Johnstone wrote: At 21:15 04 July 2009, bildan wrote: (snip) The Puchacz is not a dangerous glider. There may be dangerous pilots who fly them, however. How would you describe a glider in which so many people have been killed in spinning incidents? Unlucky? Challenging? or Misunderstood perhaps? I fully accept the reports of the pilots who tested the glider and found that it recovered, if it had not they would not have been able to report that it didn't. Of course no-one is going to design a glider that cannot recover from a spin, and of course no-one is going to design an airliner where the doors fall off either, causing major structural failure. I do not think that the level of expertise found at McDonnell-Douglas exists in a glider design facility. Design faults are found in aircraft after release to service and mostly something is done or at least restrictions are put in place to counteract the fault, not so with the Puchacz. The reason why no-one has reported that a Puchacz is impossible to recover is that if it has happened the pilots have not survived to do so. It is easy to blame someone when they are not around to challenge that finding and this is certainly what the Canadian report does. Is the best explanation that anyone can come up with is that the glider attracts more than it's fair share of dangerous pilots. I have little doubt that the Putchacz will go on killing people while it is permitted to continue to fly, it won't be me, I will never fly in one again. |
Any Spins Lately?? | Ol Shy & Bashful | Piloting | 28 | September 6th 07 10:22 PM |
Found on another site 08-747 Spiral stairs to lounge 08.jpg (1/2) | Just Plane Noise[_2_] | Aviation Photos | 0 | August 10th 07 02:39 PM |
Found on another site 08-747 Spiral stairs to lounge 08.jpg (2/2) | J.F. | Aviation Photos | 0 | August 10th 07 02:14 PM |
Spiral Dives Explanation. | Sandy Stevenson | Soaring | 6 | August 26th 05 12:34 PM |
Paraglider spiral dive, throws chute and ends up in the trees | Stewart Kissel | Soaring | 8 | March 1st 05 10:04 PM |
