Testing On The Cheap
Old July 5th 09, 03:36 PM posted to rec.aviation.homebuilt
gorgon
Default Testing On The Cheap
On Jul 3, 10:49*am, "rattlesnake" wrote:
Destruct static testing done in a non-silly and relevant manner. Kind
of cool to see that they predicted the failure mode and location. The
wing was designed within a couple of percent of the goal. No weight
sacrificed here.
http://www.youtube.com/watch?v=pe9PVaFGl3o
Old July 5th 09, 04:27 PM posted to rec.aviation.homebuilt
rattlesnake
Default Testing On The Cheap / update
performed static testing on Saturday. Went well except engine mount broke
(§&%!?$ one of the few parts I didn't fabricate by myself) So far about
testing.....
www.ph21.de/guest/Pict0035.jpg
"gorgon" schrieb im Newsbeitrag
sacrificed here.
Old July 5th 09, 07:44 PM posted to rec.aviation.homebuilt
jan olieslagers[_2_]
rattlesnake schreef:
You are strong at foreign languages, mein lieber Herr! Bravo!
But then, cursing is always learnt first, isnt'it...?
Old July 5th 09, 07:53 PM posted to rec.aviation.homebuilt
rattlesnake
if you just scrapped a $1000 item wouldn't you, mon ami?
"jan olieslagers" schrieb im Newsbeitrag
Old July 6th 09, 03:51 AM posted to rec.aviation.homebuilt
Brian Whatcott
Ouch,
glad THAT didn't happen in the air.
Seeing an engine depart must be on about the same excitement level as
seeing aeroelastic vibration in the wing tips.
Makes me think of a reason why I sometimes see a wire cable tether round
a couple of engine fixings back to a bulkhead. A loose engine has a
better CofG that a missing engine, no doubt!
Brian W
testing.....
sacrificed here.
Old July 6th 09, 08:22 AM posted to rec.aviation.homebuilt
rattlesnake
"Brian Whatcott" schrieb im Newsbeitrag
Ouch,
wouldn't happen in the air. Was caused by stupid static load testing.....
Old July 6th 09, 06:06 PM posted to rec.aviation.homebuilt
Brian Whatcott
Ouch,
I'm thinking it would be stupid, or at least careless, if the load
were reacted through just one or two mount fixings.
Is that how the test was rigged?
(I noticed there seemed to be a steel strip
perhaps 3/16 X 1 inch welded into the cluster which seemed to
provide a rather abrupt section change.) Is that the way the plans
were drawn?
Brian W
Old July 6th 09, 06:41 PM posted to rec.aviation.homebuilt
rattlesnake
roughly the setup was like this:
- plane upright
- tail and elevator loaded by about 430 lbs of bricks
- ailerons and flaps loaded by about 290 lbs of bricks
- both wings supported by 1.5 ton car jacks
- engine pushed down by about 1.100 lbs at position of the four attachment
points
I got a bad feeling before the test, but I have only two choices in my
country:
1: do this silly static test
2: reject it and never receive the permit to fly
I think the lower attach points can be repaired. Probably solid 3/4" rond
bars will be welded into the remaining tubes. However I lost some of my
confidence in this flying machine because I don't know what (invisible)
secondary damage may have occured.
Old July 7th 09, 01:52 AM posted to rec.aviation.homebuilt
Peter Dohm
"rattlesnake" wrote in message
- plane upright
points
country:
While it is really tempting to brag about my father's prescience, in his
decision to leave your country many decades ago, this really does not sound
like it should be an outrageous or damaging test it done correctly.
Assuming that the "engine" was simulated with a rigid fixture that mounted
is essentially the same manner as the engine and about 4 time the weight of
the engine was suspended from the CG point of the engine, or alternatively
that the engine was mounted and that about 3 more time the weight of the
engine was suspended below the CG point of the engine, it would appear that
you simply need a new engine mount which is free of defect. In that case,
the test was well designed and appears to have accomplished its purpose.
OTOH, if this was a "dynafocal" mount, and also if the test procedure failed
to maintain the relative orientation of the four engine mounting points,
then the test procedure would appear to be at fault. It that case, you will
probably ned to perform the test again with a new engine mount.
Peter (Damm)
Old July 7th 09, 02:51 AM posted to rec.aviation.homebuilt
Brian Whatcott
- plane upright
points
country:
secondary damage may have occurred.
Let me ask you this: how do feel about a tube that was loaded with 275
lb (if the loading was equal and local) that failed?
Pulling numbers out of the air, lets say the failing tube was 3/4 inch
diameter and the material was 30 ton steel - how thick would it be?
There's something evidently very wrong with my numbers, or your loading
conditions: the tube wall thickness would have been
(using 30 ton sq in = 60000 psi steel)
275 lb force = 60000 X pi X 0.75 X wall thickness
So wall thickness = 275 / (60000 X pi X 0.75 ) = about 2 thousandth
inch??
Certainly not! Perhaps it was light alloy tube rated at 20000 psi?
That leads to a wall thickness of 6 thousandth inch? Certainly not!
So maybe they loaded the engine itself though its centroid.
The tube did not fail in crushing, it looked like it failed in shear??
That's the weakest modulus - but not THAT weak - so I am missing
something about the geometry: a long long engine mount over a narrow
area bulkhead?? I just don't get it!
It should not be possible to weld up an engine mount WEAK enough to fail
at the load you mentioned.....
But inserting a solid rod into a thin tube is an unfavorable fix - the
stress concentration is inviting another failure just past the end of
the rod insert.....
Perhaps you might let someone look at the engine mount drawing. There's
something strange about it. At the very least, there was no post weld
heat treat ?? Critical structure should ALWAYS yield (if its metal)
not crack destructively.
Good luck
Brian W
p.s. If the designer was an absolute genius, and the materials all
produced exactly on specification, at the load test, if the engine mount
was just 2% stronger, then one or several other parts would have yielded
(but NEVER cracked) before the engine mount YIELDED.
You can take it for granted that nobody is that good!
CHEAP Los Angeles C-172 Flying Club CHEAP [email protected] Aviation Marketplace 7 May 7th 09 03:32 PM
CHEAP Los Angeles C-172 Flying Club CHEAP [email protected] Owning 1 May 7th 09 03:32 PM
CHEAP Los Angeles C-172 Flying Club CHEAP Sunho Owning 2 May 7th 09 12:13 AM
CHEAP Los Angeles C-172 Flying Club CHEAP xyzzy Owning 0 April 6th 09 03:31 PM
Testing the Testing of Mogas Jay Honeck Piloting 22 July 24th 06 09:38 PM
