rattlesnake wrote:
"Brian Whatcott" schrieb im Newsbeitrag ... Ouch, glad THAT didn't happen in the air. wouldn't happen in the air. Was caused by stupid static load testing..... I'm thinking it would be stupid, or at least careless, if the load were reacted through just one or two mount fixings. Is that how the test was rigged? (I noticed there seemed to be a steel strip perhaps 3/16 X 1 inch welded into the cluster which seemed to provide a rather abrupt section change.) Is that the way the plans were drawn? Brian W |
![]() "Brian Whatcott" schrieb im Newsbeitrag ... .... I'm thinking it would be stupid, or at least careless, if the load were reacted through just one or two mount fixings. Is that how the test was rigged? roughly the setup was like this: - plane upright - tail and elevator loaded by about 430 lbs of bricks - ailerons and flaps loaded by about 290 lbs of bricks - both wings supported by 1.5 ton car jacks - engine pushed down by about 1.100 lbs at position of the four attachment points I got a bad feeling before the test, but I have only two choices in my country: 1: do this silly static test 2: reject it and never receive the permit to fly I think the lower attach points can be repaired. Probably solid 3/4" rond bars will be welded into the remaining tubes. However I lost some of my confidence in this flying machine because I don't know what (invisible) secondary damage may have occured. |
![]() "rattlesnake" wrote in message ... "Brian Whatcott" schrieb im Newsbeitrag ... ... I'm thinking it would be stupid, or at least careless, if the load were reacted through just one or two mount fixings. Is that how the test was rigged? roughly the setup was like this: - plane upright - tail and elevator loaded by about 430 lbs of bricks - ailerons and flaps loaded by about 290 lbs of bricks - both wings supported by 1.5 ton car jacks - engine pushed down by about 1.100 lbs at position of the four attachment points I got a bad feeling before the test, but I have only two choices in my country: 1: do this silly static test 2: reject it and never receive the permit to fly I think the lower attach points can be repaired. Probably solid 3/4" rond bars will be welded into the remaining tubes. However I lost some of my confidence in this flying machine because I don't know what (invisible) secondary damage may have occured. While it is really tempting to brag about my father's prescience, in his decision to leave your country many decades ago, this really does not sound like it should be an outrageous or damaging test it done correctly. Assuming that the "engine" was simulated with a rigid fixture that mounted is essentially the same manner as the engine and about 4 time the weight of the engine was suspended from the CG point of the engine, or alternatively that the engine was mounted and that about 3 more time the weight of the engine was suspended below the CG point of the engine, it would appear that you simply need a new engine mount which is free of defect. In that case, the test was well designed and appears to have accomplished its purpose. OTOH, if this was a "dynafocal" mount, and also if the test procedure failed to maintain the relative orientation of the four engine mounting points, then the test procedure would appear to be at fault. It that case, you will probably ned to perform the test again with a new engine mount. Peter (Damm) |
On Jul 6, 5:52*pm, "Peter Dohm" wrote:
(Lotsa stuff clipped) Dear Peter (and the Group) I guess I'm just a sissy but I would never use .035 for an engine mount. In fact, I'd be leery of .049. This isn't about calculations on a sheet of paper, it's about incidental damage that can occur to the tubing over heaven knows how many years of service. I'm talking about dropped wrenches and the like -- falls down, DINGS the lower mount on its way to the bottom of the nacelle or even clear to the ground, if you're lucky ( ...but you seldom are, right? :-) So we fish it out and since there's no apparent damage we assume everything is okay. But gravity sucks and sure as the potential student always barfs on the new upholstery (never on the old), Murphy's Law is ALWAYS waiting in the wings. Ding round tubing and you may as well cut it out and start over; its specs no longer apply and in nine cases out of ten the repair will cost more than the replacement. 3/4 x .035 gottem internal dia, of ,680. Closest match is going to be 5/8ths but using it -- or even making the repair instead of doing a replacement -- is going to depend on where the tube departed from spec. Adjacent to a weld? Or a gradual bend across the entire length of the member... because about the ONLY location where the repair (using an internal sleeve of .5/8) is practical is right in the middle of the member. Any where else, the REPLACEMENT is going to be more practical... except for the engineering. If you replace the failed member with the SAME SIZE tubing, you know it's going to happen again. Indeed, the static test has done it's job; it is telling you to use a sturdier member. But not just there, EVERYWHERE. Because you have to assume there will be occasions when gravity is going to be coming at you from different directions. So that while those upper members may have done fine in the static test, when they are being subjected to TENSION, there is a high probability they will fail when the attitude of the aircraft makes them bear the load in COMPRESSION... or visa versa. Indeed, the static test has already told you so. Are you familiar with the 'Jesus Factor'? That is the uncalculable amount you ADD to every structure -- when ever you can -- so as to cover the realities of serial production, Monday morning hang-overs, Friday afternoon hurry-ups and every other thing you can thing of that might cause the as-fabricated version to depart from the as-calculated version. In a welded steel tube structure we're generally safe with a Jesus Factor of 1.5 for the fuselage, 3.0 for a control surface and 5.0 for the landing gear AND ENGINE MOUNT. Mention the Jesus Factor today and they're liable to start looking for where you parked your bicycle. Perhaps a better tag would be the **** Happens Factor. Call it what you will, there are those who upon learning their engine mount is capable of withstanding 30g's when the specs only call for six, commence to run in circles, waving their hands and emitting tiny shrieks. And perhaps with good reason, if we're talking about a home-built, where the builder is also the test pilot as well as Line Captain. If the calculations call for .049 then you can safely assume it won't be something thinner... although thicker might appear now & then. But whatever you call it and no matter where it is applied, from Farmington, Long Island to a garage in San Diego, you can bet your bolly hooly it DOES exist -- and does so for a purpose. -R.S.Hoover |
rattlesnake wrote:
.... roughly the setup was like this: - plane upright - tail and elevator loaded by about 430 lbs of bricks - ailerons and flaps loaded by about 290 lbs of bricks - both wings supported by 1.5 ton car jacks - engine pushed down by about 1.100 lbs at position of the four attachment points I got a bad feeling before the test, but I have only two choices in my country: 1: do this silly static test 2: reject it and never receive the permit to fly I think the lower attach points can be repaired. Probably solid 3/4" rond bars will be welded into the remaining tubes. However I lost some of my confidence in this flying machine because I don't know what (invisible) secondary damage may have occurred. Let me ask you this: how do feel about a tube that was loaded with 275 lb (if the loading was equal and local) that failed? Pulling numbers out of the air, lets say the failing tube was 3/4 inch diameter and the material was 30 ton steel - how thick would it be? There's something evidently very wrong with my numbers, or your loading conditions: the tube wall thickness would have been (using 30 ton sq in = 60000 psi steel) 275 lb force = 60000 X pi X 0.75 X wall thickness So wall thickness = 275 / (60000 X pi X 0.75 ) = about 2 thousandth inch?? Certainly not! Perhaps it was light alloy tube rated at 20000 psi? That leads to a wall thickness of 6 thousandth inch? Certainly not! So maybe they loaded the engine itself though its centroid. The tube did not fail in crushing, it looked like it failed in shear?? That's the weakest modulus - but not THAT weak - so I am missing something about the geometry: a long long engine mount over a narrow area bulkhead?? I just don't get it! It should not be possible to weld up an engine mount WEAK enough to fail at the load you mentioned..... But inserting a solid rod into a thin tube is an unfavorable fix - the stress concentration is inviting another failure just past the end of the rod insert..... Perhaps you might let someone look at the engine mount drawing. There's something strange about it. At the very least, there was no post weld heat treat ?? Critical structure should ALWAYS yield (if its metal) not crack destructively. Good luck Brian W p.s. If the designer was an absolute genius, and the materials all produced exactly on specification, at the load test, if the engine mount was just 2% stronger, then one or several other parts would have yielded (but NEVER cracked) before the engine mount YIELDED. You can take it for granted that nobody is that good! |
Peter, Brian,
thanks for the bright thoughts. Think I know what caused the problem. Per the plans my engine requires about 1.5" long spacers between the mount's attach points and the engine itself. This creates an extra bending moment which may have triggered the failure. The mount is made of 3/4" 4130 tube with 0.035" wall thickness. My current idea of repair is to weld a short round bar into the remaining tube and so rebuilding the attach points. Maybe I'll shorten the spacers a bit and bring some ballast further forward instead (battery). |
rattlesnake wrote:
Peter, Brian, thanks for the bright thoughts. Think I know what caused the problem. Per the plans my engine requires about 1.5" long spacers between the mount's attach points and the engine itself. This creates an extra bending moment which may have triggered the failure. The mount is made of 3/4" 4130 tube with 0.035" wall thickness. My current idea of repair is to weld a short round bar into the remaining tube and so rebuilding the attach points. Maybe I'll shorten the spacers a bit and bring some ballast further forward instead (battery). See if you can find some tube that will fit inside or outside the failed tube. perhaps 50 thou wall. fish mouth the ends. Rossette and end weld. Take a look at CAM18. It gives specific instructions on repairing tubes. Brian W |
hmmm....
found a tube which fits inside the faild tube, but how can I weld it in then - just asking "Brian Whatcott" schrieb im Newsbeitrag ... rattlesnake wrote: Peter, Brian, thanks for the bright thoughts. Think I know what caused the problem. Per the plans my engine requires about 1.5" long spacers between the mount's attach points and the engine itself. This creates an extra bending moment which may have triggered the failure. The mount is made of 3/4" 4130 tube with 0.035" wall thickness. My current idea of repair is to weld a short round bar into the remaining tube and so rebuilding the attach points. Maybe I'll shorten the spacers a bit and bring some ballast further forward instead (battery). See if you can find some tube that will fit inside or outside the failed tube. perhaps 50 thou wall. fish mouth the ends. Rossette and end weld. Take a look at CAM18. It gives specific instructions on repairing tubes. Brian W |
rattlesnake wrote:
hmmm.... found a tube which fits inside the failed tube, but how can I weld it in then - just asking .... The ends of the insert are tapered. Holes are drilled in the failed tube to allow rosette welds of the interior tube, which have much the same effect as through bolts, but rather lighter and stronger, if well done. Brian W |
oh, think I got it now with rossettes and fishmouths :-))
CHEAP Los Angeles C-172 Flying Club CHEAP | [email protected] | Aviation Marketplace | 7 | May 7th 09 03:32 PM |
CHEAP Los Angeles C-172 Flying Club CHEAP | [email protected] | Owning | 1 | May 7th 09 03:32 PM |
CHEAP Los Angeles C-172 Flying Club CHEAP | Sunho | Owning | 2 | May 7th 09 12:13 AM |
CHEAP Los Angeles C-172 Flying Club CHEAP | xyzzy | Owning | 0 | April 6th 09 03:31 PM |
Testing the Testing of Mogas | Jay Honeck | Piloting | 22 | July 24th 06 09:38 PM |
