When our Tost winches were fitted with 'one speed' (fixed in top)
automatic gearboxes, the ground run acceleration for the heavier two seater was somewhat ponderous, although they could still rocket launch lightweight K8 single seaters. They also tended to overheat the gearbox oil, despite being fitted with big oil coolers with electric fans. This was also why you had to apply full throttle to get the gliders moving and then back off as the gliders entered the full climb, to avoid a huge overspeed. From a winch driver's point of view, it was hard to get this right, which was probably the cause of some of the awful launches we used to have to endure in that era. Derek Copeland At 14:49 13 July 2009, bildan wrote: On Jul 13, 6:30=A0am, Del C wrote: Unless Bill has invented a perpetual motion machine, you can't get more power out of a mechanical device (such as an automatic gearbox) than you put in. You can gear that power down to get more torque, but the Skylaunc= h winch depends on supplying the right amount of power (related to throttle setting) for the given glider type and headwind component. The automatic gearbox is only useful to provide some extra torque at low revs to get th= e glider moving at the start of the ground run without stalling the engine. Derek Copeland At 22:45 12 July 2009, bildan wrote: On Jul 12, 3:30=3DA0pm, David Chapman wrote: But other nonsense posted here . please help me, =3DA0... A standard car auto gearbox has some magic power to automatically adjust the torque to the car wheels on reaching a hill, without changing gear, road speed or engine setting? What magic is that? That 'magic' is called a torque converter which begins to slip and multiply torque under increasing load. =A0Stock units can double torque to the wheels. Modern transmissions use a torque converter locking clutch allowing an even greater torque multipication factor after the clutch disengages under load. =A0The effect can be 4:1 or greater. For basic info, see:http://en.wikipedia.org/wiki/Torque_converter In addition, automobile engine torque curves have peak torque lower than cruise RPM. =A0As the vehicle encounters a load such as a hill, the torque output actually increases as the RPM is pulled down by the increasing load. =A0The typical V8 used in glider winches has a torque peak at about 1800 RPM. The engine/transmission combination acts in exact opposition to what is needed in a glider winch. In fact, with an automatic transmission in the drive line, it's impossible to ever get the rope tension exactly right - certainly not with something as simple minded as a throttle stop. Most of what an automatic actually does in a glider winch is either unnecessary or detrimental. Only the auto-clutch action at idle is useful and there are far better ways to do that. The only justification for using an automatic in a winch is that it's cheap and comes with the engine. The idea that low starting gears are necessary with a glider winch is absurd. Tost gutted their automatics - even while saying automatics were dangerous - to eliminate everything but the torque converter leaving the box in it's straight through 1:1 ratio. Simple torque calculations show that 3rd gear is capable of breaking the strongest weak link during acceleration. Stepping through 1st and 2nd gears only makes it more difficult to achieve accurate acceleration. |
Yeah... well, my point exactly. Over and out.
Bob Lacovara |
Winch Launching in US | john hawkins | Soaring | 11 | June 10th 09 12:18 PM |
Winch Launching | Rolf | Soaring | 27 | January 7th 09 02:48 AM |
Ka8b winch launching | Jimmie L. Coulthard | Soaring | 11 | September 9th 08 08:38 AM |
Aerotow Fuel Costs & Winch Launching | Derek Copeland[_2_] | Soaring | 2 | May 26th 08 03:14 PM |
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 12:33 AM |
