At 15:53 13 July 2009, bildan wrote:
Look, I didn't start this thread. You don't have a perfect winch and neither does anybody else. There's a LOT of room for improvements in every aspect of winch design. Keep an open mind. If you think that automatic gear changes don't matter, put a tension logger on yours for a few launches. The results will astonish you. What gets my dander up is "emotional" opposition to all attempts at innovation based on the idea that your domestic winch is 'perfect'. Sorry to ask you this again Bill, but could you please quantify what problems your alleged 'tension spikes' actually cause? We just don't seem to get weak link or cable breaks associated with gearchanges. Even if they do exist, there is enough elasticity in a 1km plus winch cable to absorb them. As you have been told repeatedly by everyone with a decent quality automatic gearbox winch, the gear changes are totally smooth and imperceptible at the glider end. And can you prove that your mega expensive superwinches will do any better in rough conditions with a wobbly student pilot at the controls of the glider? Derek Copeland |
On Jul 13, 10:30*am, Del C wrote:
At 15:53 13 July 2009, bildan wrote: Look, I didn't start this thread. *You don't have a perfect winch and neither does anybody else. *There's a LOT of room for improvements in every aspect of winch design. *Keep an open mind. If you think that automatic gear changes don't matter, put a tension logger on yours for a few launches. *The results will astonish you. What gets my dander up is "emotional" opposition to all attempts at innovation based on the idea that your domestic winch is 'perfect'. Sorry to ask you this again Bill, but could you please quantify what problems your alleged 'tension spikes' actually cause? We just don't seem to get weak link or cable breaks associated with gearchanges. Even if they do exist, there is enough elasticity in a 1km plus winch cable to absorb them. As you have been told repeatedly by everyone with a decent quality automatic gearbox winch, the gear changes are totally smooth and imperceptible at the glider end. And can you prove that your mega expensive superwinches will do any better in rough conditions with a wobbly student pilot at the controls of the glider? Derek Copeland This is just more rabble rousing. You know the answer, you've seen the data from winches in your own country. Seeing tension oscillate by 80% of the tension limits is very scary and it does lead to problems including wire and weak link breaks. You actually begged me once not to publish the tension charts or even mention the problem. (I saved the e-mail in case you deny it.) I have a LOT more tension charts - really ugly ones. You don't want me to publish them either. All the current winches are priced within a few thousand dollars of each other so there are no "mega expensive winches" - except they're unfortunately all too expensive. My agenda is simple; help build the best winches in the world without constant and distinctly unwelcome interference from people with nothing constructive to add. In all the years you've been posting about winch construction, you've never added a single new idea. But you've campaigned loudly and often against any every offered by anyone else. I've read every BGA publication on winch launch that's ever been published. I've read every training BGA syllabus - and I've read ALL your accident reports. Your accident record is far from the best. It's in a three ring binder about 4" thick on my bookshelf. Your stuff is OK but no better than other sources. So, here's an offer. Stop attacking everything we do and I won't comment about the Skylaunch. We are going to build, publicly test and write detailed articles about our winches. I expect no derogatory commentary from you. We are not British Subjects and certainly not your students. |
At 01:07 14 July 2009, bildan wrote:
This is just more rabble rousing. You know the answer, you've seen the data from winches in your own country. Seeing tension oscillate by 80% of the tension limits is very scary and it does lead to problems including wire and weak link breaks. You actually begged me once not to publish the tension charts or even mention the problem. (I saved the e-mail in case you deny it.) I have a LOT more tension charts - really ugly ones. You don't want me to publish them either. All the current winches are priced within a few thousand dollars of each other so there are no "mega expensive winches" - except they're unfortunately all too expensive. My agenda is simple; help build the best winches in the world without constant and distinctly unwelcome interference from people with nothing constructive to add. In all the years you've been posting about winch construction, you've never added a single new idea. But you've campaigned loudly and often against any every offered by anyone else. I've read every BGA publication on winch launch that's ever been published. I've read every training BGA syllabus - and I've read ALL your accident reports. Your accident record is far from the best. It's in a three ring binder about 4" thick on my bookshelf. Your stuff is OK but no better than other sources. So, here's an offer. Stop attacking everything we do and I won't comment about the Skylaunch. We are going to build, publicly test and write detailed articles about our winches. I expect no derogatory commentary from you. We are not British Subjects and certainly not your students. I am struggling to understand what cable tension has to do with anything. I have been winch launched 10000 times and have driven a winch for many more launches than that over 50 years and the only thing that concerns me is the speed of the cable retrieval at the delivery end. Yes I use the bow in the cable to keep the speed constant but this is a relative thing, not an absolute. I accelerate quicker than most drivers to keep the ground run as short as possible and to give the pilot aerodynamic control as quickly as possible. I also reduce the speed at the top of the launch often causing the glider to back release. It really does not matter how it is done but the important thing is that the control applied by the winch driver is reflected in the response of the winch to his input at the business end. I can think of few, if any accidents that have been caused by "tension spikes" whatever they are, and a lot caused by varying amounts of a lack of skill. It is a real shame that people are being denied an economic alternative launch procedure by ignorance. It does not have to be complicated, in fact given the use to which it is put the simpler the better. The winches we have in the UK work, and they work well. Reading some of the postings about tension control has been interesting in an amusing sort of way, well actually it's been a hoot. Learn from the mistakes of the Munster Van Gelder winch, an excellent winch with many advanced features, most of which are switched off in normal operation. The servicing overhead is massive and the only people able to run them, with one exception is the RAF. Yes it gives an excellent launch, probably the best I have ever had but at a huge cost in maintenance overheads. Why, because it is too complicated with too many advanced features even when driven by what are really proffesional winch drivers. I am also struggling to understand why so much notice is being taken of someone who obviously knows so little about the practical operation of glider winches. As Wayne has said, almost no winching is carried out in the USA so I would have thought it sensible to consult those who do operate winches rather than some crackpot with wild ideas and zero knowledge. |
Just exacly where are you making these tensions measurements????
Are you making them at the weak link?? Are you making these measurements at the winch end of things? I'd really like to know... |
At 22:34 14 July 2009, Gary Emerson wrote:
Just exacly where are you making these tensions measurements???? Are you making them at the weak link?? Are you making these measurements at the winch end of things? I'd really like to know... That is the question that is puzzling me too. The tension sensed by the winch will, and should be constantly changing during the launch, measuring that would be, how can I put it, useless. The tension at the glider release hook will be relatively constant but measuring that introduces the problem of the addional weight of the device that does it and a reliable transmission of data to the ground. |
At 00:30 15 July 2009, Don Johnstone wrote:
At 22:34 14 July 2009, Gary Emerson wrote: Just exacly where are you making these tensions measurements???? Are you making them at the weak link?? Are you making these measurements at the winch end of things? I'd really like to know... That is the question that is puzzling me too. The tension sensed by the winch will, and should be constantly changing during the launch, measuring that would be, how can I put it, useless. The tension at the glider release hook will be relatively constant but measuring that introduces the problem of the addional weight of the device that does it and a reliable transmission of data to the ground. That is the bit that the proponents of constant tension winch launching seem to gloss over. How do you measure tension in a long and thrashing cable that is being wound into a winch at up to 70 knots as the glider lifts off? There are gadgets called running line tensiometers that are used in underground cable laying, but they don't work at the sort of speeds required. The other approach is to mount a load cell at the glider end and transmit the data back to the winch in some way, such as a radio link. Even if you can directly measure tension in the cable, you have to bear in mind that the glider has to pull against that tension and that changes in its pitch angle due to pilot inputs or gusts will temporarily increase or reduce the tension. You would therefore have to damp the system or it would tend to hunt. I know as a glider pilot and winch driver myself, that the less you can change the pitch angle of the glider and the throttle setting of the winch, the steadier the launch becomes. If the pilot is trying to control the airspeed with the stick at the same time that the winch is trying to sense and maintain a constant tension, there is a risk that they will end up chasing each other, especially when separated by a long, sagging (even Dyneema sags slightly) and slightly elastic cable. In practice the Skylaunch approach of limiting the power setting as appropriate to the glider type, headwind component and weak link strength seems to work well. If the pilot pulls back harder, or the glider runs into a thermal, it slows the winch engine down by just the right amount. Easing forward or hitting sink allows the engine to speed up. Since we replaced Tost winches with Skylaunches, broken weak links have almost become a thing of the past and the vast majority of the launches are correctly speeded given correct pilot inputs. The pilot can control the airspeed by changing the pitch angle. Derek Copeland |
People trying to design tension controlled winches are re-inventing
the wheel. Conventional winches already do that. IF the power setting is retained constant in conventional winches with a torque converter, the tension will be constant excluding the inertia factor. Every winch will have inertia and delay and none will be able to respond instantaneously to changes in wire load. A tension meter can be installed in any type of winch, electric, hydraulic or conventional. There is no difference between the different types there and power can be controlled by one if desired. The issue is, does it make sense? Is the approximation calculated by the British design good enough? Or do we need a real time tension control winch? Would the inertia i the system even make this possible or desirable? I would say that setting the desired tension according to type and conditions by approximation, ala Skylaunch, and not worrying about the fluctuations is plenty good enough. The main reason is because designing a winch to be truly controlled in real time by the actual and current tension, micro second by microsecond, is probably very expensive, unproven and would not solve the inertia delay issue of the winch. Trying to chase the gusts so to speak - how would that work? A conventional winch type already lets the drum slow down and/or pulls the engine revs down if the cable tension increases due to a gust or thermal - thus reducing the tension - this is already a mechanically built in constant torque effect. This is by no means perfect, but certainly good enough to give mostly smooth launches. In gusty conditions, there is no winch in the world, not even on paper, that can react fast enough to dampen away the oscillations in cable tension and airspeed, due to the time delay in reacting to the changes in cable tension. We just need to figure out how to make a cheap reliable winch and find places to use them at. At $10-$15 a launch, a glider club or operator would quickly make a nice income, like European clubs do. The real cost of a winch launch is something like $3-5 per launch including maintenance, reserves and replacements. 30 launches a week x $10 profit = $1,200 extra a month. That's one very nice glider upgrade every 5 years. This is one of the main reasons why European clubs have such nice equipment. Tom |
![]() At 04:19 15 July 2009, tommytoyz wrote: We just need to figure out how to make a cheap reliable winch and find places to use them at. At $10-$15 a launch, a glider club or operator would quickly make a nice income, like European clubs do. The real cost of a winch launch is something like $3-5 per launch including maintenance, reserves and replacements. 30 launches a week x $10 profit = $1,200 extra a month. That's one very nice glider upgrade every 5 years. This is one of the main reasons why European clubs have such nice equipment. There are winches already in operation in the US, there are groups who want to operate them, and there are groups trying to design and manufacture them. I think we need all of the above. I'm part of a wanna-be operating group, with limited funds. That pretty much means either finding a rebuildable Gehrlein, importing an inexpensive used winch from Europe, or homebrewing a new winch (based on the UK spec). I prefer the latter, as I think there is still plenty of room for optimization, both in fabrication and operation. While I respect those who are trying to push the envelope with advance power systems and launch automation, a simple single drum winch based on automotive components will be good enough for our local group get started. If you aren't a member of the Yahoo Winch Design group, please consider joining. While we have our share of spats, there is progress being made towards coming up with component designs for a cheap reliable non-automated winch... Marc |
On Tue, 14 Jul 2009 21:19:50 -0700 (PDT), tommytoyz
wrote: The real cost of a winch launch is something like $3-5 per launch including maintenance, reserves and replacements. 30 launches a week x $10 profit = $1,200 extra a month. That's one very nice glider upgrade every 5 years. This is one of the main reasons why European clubs have such nice equipment. Unfortunately this is not the reason... There might be a few clubs in Europe that charge the prices you mentioned, but all the clubs I know charge between 2 and 5 Euro, sufficient only to cover the costs. Cheers Andreas |
At 22:34 14 July 2009, Gary Emerson wrote: Just exacly where are you making these tensions measurements???? Are you making them at the weak link?? Are you making these measurements at the winch end of things? I'd really like to know... That is the question that is puzzling me too. The tension sensed by the winch will, and should be constantly changing during the launch, measuring that would be, how can I put it, useless. The tension at the glider release hook will be relatively constant but measuring that introduces the problem of the addional weight of the device that does it and a reliable transmission of data to the ground. Which is why I suggested we think about metrics. If there were not big changes in tension at the Winch end you would have a REAL problem. Go check it - on our 2km run the glider has not moved before the winch is 1-1.5s into power up - until then there is a lot of tension going into the cable at the winch and zero happening at the glider end. We have had a ham fisted learner winch driver snap the cable neatly (1880KN breaking strain cable) at the drum without even moving the chute at the launch point. So - The place it has to be reasonably gentle (smooth curve) is at the glider hook. Now we get into a whole new debate about the relative advantage of UHMDPE (Spectra / Dyneema etc.) and steel cable. Steel has much more elasticity and inertia to absorb those transient loads. The spring steel wire acts like a spring storing energy and smoothing loads. Inconveniently this means that when it breaks under tension you get a backlash that can result in big overwinds and injuries. The plastic rope is - counter-intutively given the name, far less elastic and very light. Result is that winches so equipped may need to have smoother delivery. And (I am not a good enough engineer here) it is possible that the tension at the winch on these is similar to that experienced by the aircraft hook. Would depend on hysteresis and all sorts of other things that are probably best measured rather than calculated / guessed. Any one with facts? |
Winch Launching in US | john hawkins | Soaring | 11 | June 10th 09 12:18 PM |
Winch Launching | Rolf | Soaring | 27 | January 7th 09 02:48 AM |
Ka8b winch launching | Jimmie L. Coulthard | Soaring | 11 | September 9th 08 08:38 AM |
Aerotow Fuel Costs & Winch Launching | Derek Copeland[_2_] | Soaring | 2 | May 26th 08 03:14 PM |
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 12:33 AM |
