I soared from the Minden area down to abeam Independence then back to
Mono Lake before needing my engine to get home to the Bay Area. (I also used the engine to get me to Minden.) As long as I stayed with the clouds, lift was fantastic east of the Sierras. I saw 13 kts on my averager several times, and 10 knots while dolphin flying. South of Mono Lake, there were clouds that could take you to the Whites or the Sierras and, since I'm a sucker for soaring the Sierras, I took that fork in the clouds. Made it to abeam Independence before turning around. Lift on the Sierras was spottier -- as usual, but still very good. When I got home and checked my SPOT messenger track was missing an hour and twenty minutes -- a new record. The last message before the dropout was at 12:10 PM PDT and the next one was around 1:30 PM. Did anyone else with a SPOT have a similar problem today? If anyone wants to compare data, my shared page is http://share.findmespot.com/shared/f...QTLgQBTp7N ax but, as usual, it will disappear in a few days or a week. Thanks for any help on this question. Martin |
Martin,
I've had several flights with that long of a gap in the tracking messages. No one has come up with a good explanation. Is your flight on OLC ... ? Thirteen knots, you gotta share that! ted/2NO |
On Jul 16, 6:04*am, Tuno wrote:
Is your flight on OLC ... ? Thirteen knots, you gotta share that! Alas, I've been unable to read the files from my Colibri data logger since I upgraded my PC's OS -- the Colibri uses a serial port and either my serial-USB adapter doesn't work since that upgrade or the Colibri itself is broken. I've seen 11 kts before on the averager, but I am pretty sure 13 is a new record for mine, especially in 3 or 4 thermals in the same flight. Once I took the fork to the Sierras, the lift was nowhere as good -- though that was partly expected. I was willing to sacrifice thermal strength (and maybe even having to turn on the engine) for the fantastic views the Sierras offer compared to the more barren ranges to the east. Meadows, lakes, glacial remnants make for great sightseeing, but do cut into thermals. Coming home to the Bay Area was a bit problematic in that the clouds made an arc far to the east before I could cross the Sierras, so I had to turn on the engine for about 10 minutes near Mammoth Lakes to gain enough altitude to safely cross as a glider at Yosemite. But I'd kinda expected that since the BLIPMAP showed that would be the case at 5 PM local time. Even so, I had a 6.6 hour flight with only 1.0 engine time. Sorry not to be able to post the track, but an earlier one-day trip is described (including a SeeYou map, showing engine use) at http://tinyurl.com/5ahbcm Martin PS The ship is for sale. I'll miss it, but a project is taking too much time and passion that used to go in here. If interested, http://tinyurl.com/56qseu has a description of that project -- and even connects it to soaring. |
Martin:
I did a serious investigation on the problem involving some experiments and analysis and I made a presentation to my local club. My presentation is available for download from my Wing Rigger website: www.wingrigger.com. (click Extra Soaring Content in lower right corner). Here is the bottom line: the radio link between Spot and the Global Star network is a bit fussy. There are some 40 Global Star satellites in low earth orbit. Statistically 2 or 3 satellites are likely to be in view but sometimes just one. When you consider the geometry of the low earth orbit and the statistical distribution of the satellites it will almost always be the case that the satellites are very near to the horizon. So what matters is that Spot has a line of site view to the horizon. Since you don’t know exactly where on the horizon the Global Star will be, the only sure thing is to have a clear view of the entire horizon. This is often rather difficult. My experiments proved that when you do have a 360 degree view of the horizon Spot works perfectly. So part of the answer relates to the mounting location in your glider. What I found works best is a location behind my headrest high against the underside of the canopy. I have a picture of this mounting in the mentioned presentation. There is more to the story. Even with optimal mounting you will miss some Spot transmissions because gliders spend a portion of their time in banked turns. When the glider is banked, a certain percentage of the horizon becomes blocked by the glider’s wings, fuselage etc. If there aren’t any satellites in the unblocked portion of the horizon, your message won’t get out. I studied this effect by carefully time correlating the exact times at which Spot succeeded or failed in its transmissions to the time stamped record created by an IGC file that I examined in See You. I did this for two long flights. With my “optimal mounting” I miss about 20% of transmissions while banked and I miss only 2% when in substantially level flight. So my Spot tracking performance is pretty good, but certainly not perfect. One other consideration relates to the performance of the patch antenna that is used in the Spot device. The antenna preferentially transmits to one hemisphere. So the unit works best when the unit is mounted flat – label side up. Any other mounting angle reduces your chance of linking to a satellite on the horizon. I’m sure this also comes into play when the glider is in a banked turn. Steve Koerner (GW) |
PS:
Martin: Here is a link to my Spot log for a long flight I made in AZ/UT the day before yours: www.tinyurl.com/4fuc2h I missed only one transmission in eight hours on that flight. That's better than I would have expected. Since it was a high altitude flight, I'm thinking that might have helped the odds of seeing more horizon distance. PPS: Tuno: Were you sleeping during my lecture? Steve |
On Jul 16, 7:48*am, Steve Koerner wrote:
I did a serious investigation on the problem involving some experiments and analysis and I made a presentation to my local club. My presentation is available for download from my Wing Rigger website:www..wingrigger.com. *(click Extra Soaring Content in lower right corner). Steve, Thanks for that detailed analysis of SPOT behavior. While it helps in understanding SPOT generally, my question -- and big concern -- is why that flight was different from all other flights. I don't believe I've never had more than a 30 minute gap (2 missed transmissions) before, yet this time the gap was 90 minutes (8 missed transmissions). I was asking if anyone else had a track from that specific day and time (JUL 15, 1900-2020 Z) and general location (roughly from Oakland, CA to Lake Tahoe). If so, I wanted to know if they had coverage or also had around a 90 minute hole in their data. Martin |
On Jul 17, 9:08*pm, Hellman wrote:
On Jul 16, 7:48*am, Steve Koerner wrote: I did a serious investigation on the problem involving some experiments and analysis and I made a presentation to my local club. My presentation is available for download from my Wing Rigger website:www.wingrigger.com. *(click Extra Soaring Content in lower right corner). Steve, Thanks for that detailed analysis of SPOT behavior. While it helps in understanding SPOT generally, my question -- and big concern -- is why that flight was different from all other flights. I don't believe I've never had more than a 30 minute gap (2 missed transmissions) before, yet this time the gap was 90 minutes (8 missed transmissions). I was asking if anyone else had a track from that specific day and time (JUL 15, 1900-2020 Z) and general location (roughly from Oakland, CA to Lake Tahoe). If so, I wanted to know if they had coverage or also had around a 90 minute hole in their data. Martin Martin You want to end the guessing game and tell us where your SPOT messenger is mounted? On your harness? On your shoulder? Obstructed by your head? What is the effective field of view of the antenna? You were tracking roughly the same heading for all that time. And that heading (very) roughly lines up with one of the inclined planes of the GlobalStar constellation. The GlobalStar satelites orbit in a interweaved pattern with two inclined planes at +/- 80 degrees or so (you can see a simulation here http://www.youtube.com/watch?v=G8VPEueequM or you can actually play with the SaVi software shown in the video, see http://savi.sourceforge.net).. It is quite possible that things happen like the satelites flying from the south west to north east are obscured over your left shoudler if say your SPOT messenger was to the right side of your head and all those passes could be obscured and maye the next parallel path to the east is too far away. That leaves the satellites tracking north-west to south-east and just maybe again if your head partially obscured those then the satellite does not see the spot until it is further overhead and out of the optimal bent-pipe geometry to reach the Alberta, Canada ground station. So maybe in the whole time you just get maybe one shot when the SPOT fires off its track message where it manages to see a satellite to get it a bent path to the Texas ground station. Maybe you just managed to get things timed so bad that you never happened to have a satellite with bent-pipe view to any ground station when your SPOT happened to fire the TRACK message. This is all very uninteresting if the SPOT messenger is mounted say on your parachute harness and inclined or significantly obscured. Tell me it is out flat in the open and I'll actually care. Darryl |
On Jul 17, 10:34*pm, Darryl Ramm wrote:
On Jul 17, 9:08*pm, Hellman wrote: On Jul 16, 7:48*am, Steve Koerner wrote: I did a serious investigation on the problem involving some experiments and analysis and I made a presentation to my local club. My presentation is available for download from my Wing Rigger website:www.wingrigger.com. *(click Extra Soaring Content in lower right corner). Steve, Thanks for that detailed analysis of SPOT behavior. While it helps in understanding SPOT generally, my question -- and big concern -- is why that flight was different from all other flights. I don't believe I've never had more than a 30 minute gap (2 missed transmissions) before, yet this time the gap was 90 minutes (8 missed transmissions). I was asking if anyone else had a track from that specific day and time (JUL 15, 1900-2020 Z) and general location (roughly from Oakland, CA to Lake Tahoe). If so, I wanted to know if they had coverage or also had around a 90 minute hole in their data. Martin Martin You want to end the guessing game and tell us where your SPOT messenger is mounted? *On your harness? On your shoulder? Obstructed by your head? What is the effective field of view of the antenna? You were tracking roughly the same heading for all that time. *And that heading (very) roughly lines up with one of the inclined planes of the GlobalStar constellation. The GlobalStar satelites orbit in a interweaved pattern with two inclined planes at +/- 80 degrees or so (you can see a simulation herehttp://www.youtube.com/watch?v=G8VPEueequMor you can actually play with the SaVi software shown in the video, seehttp://savi.sourceforge.net). It is quite possible that things happen like the satelites flying from the south west to north east are obscured over your left shoudler if say your SPOT messenger was to the right side of your head and all those passes could be obscured and maye the next parallel path to the east is too far away. That leaves the satellites tracking north-west to south-east and just maybe again if your head partially obscured those then the satellite does not see the spot until it is further overhead and out of the optimal bent-pipe geometry to reach the Alberta, Canada ground station. So maybe in the whole time you just get maybe one shot when the SPOT fires off its track message where it manages to see a satellite to get it a bent path to the Texas ground station. Maybe you just managed to get things timed so bad that you never happened to have a satellite with bent-pipe view to any ground station when your SPOT happened to fire the TRACK message. This is all very uninteresting if the SPOT messenger is mounted say on your parachute harness and inclined or significantly obscured. Tell me it is out flat in the open and I'll actually care. Darryl- Hide quoted text - - Show quoted text - I don't think I agree with the notion that mounting a spot on the parachute harness near the shoulder is bad idea. Mine is on the parachute harness and I get around 10% drops, as good as anyone else who mounts their Spot perfectly horizontally. I just checked my spot messages from today: 5 missing messages in 7.5 hours fligh = 10% Since installing on the parachute harness is the easiest, and provide easy access during flight, and will stay with you in case of bailout, I wouldn't recommend against it. Ramy |
On Jul 17, 11:50*pm, Ramy wrote:
On Jul 17, 10:34*pm, Darryl Ramm wrote: On Jul 17, 9:08*pm, Hellman wrote: On Jul 16, 7:48*am, Steve Koerner wrote: I did a serious investigation on the problem involving some experiments and analysis and I made a presentation to my local club.. My presentation is available for download from my Wing Rigger website:www.wingrigger.com. *(click Extra Soaring Content in lower right corner). Steve, Thanks for that detailed analysis of SPOT behavior. While it helps in understanding SPOT generally, my question -- and big concern -- is why that flight was different from all other flights. I don't believe I've never had more than a 30 minute gap (2 missed transmissions) before, yet this time the gap was 90 minutes (8 missed transmissions). I was asking if anyone else had a track from that specific day and time (JUL 15, 1900-2020 Z) and general location (roughly from Oakland, CA to Lake Tahoe). If so, I wanted to know if they had coverage or also had around a 90 minute hole in their data. Martin Martin You want to end the guessing game and tell us where your SPOT messenger is mounted? *On your harness? On your shoulder? Obstructed by your head? What is the effective field of view of the antenna? You were tracking roughly the same heading for all that time. *And that heading (very) roughly lines up with one of the inclined planes of the GlobalStar constellation. The GlobalStar satelites orbit in a interweaved pattern with two inclined planes at +/- 80 degrees or so (you can see a simulation herehttp://www.youtube.com/watch?v=G8VPEueequMoryou can actually play with the SaVi software shown in the video, seehttp://savi.sourceforge.net). It is quite possible that things happen like the satelites flying from the south west to north east are obscured over your left shoudler if say your SPOT messenger was to the right side of your head and all those passes could be obscured and maye the next parallel path to the east is too far away. That leaves the satellites tracking north-west to south-east and just maybe again if your head partially obscured those then the satellite does not see the spot until it is further overhead and out of the optimal bent-pipe geometry to reach the Alberta, Canada ground station. So maybe in the whole time you just get maybe one shot when the SPOT fires off its track message where it manages to see a satellite to get it a bent path to the Texas ground station. Maybe you just managed to get things timed so bad that you never happened to have a satellite with bent-pipe view to any ground station when your SPOT happened to fire the TRACK message. This is all very uninteresting if the SPOT messenger is mounted say on your parachute harness and inclined or significantly obscured. Tell me it is out flat in the open and I'll actually care. Darryl- Hide quoted text - - Show quoted text - I don't think I agree with the notion that mounting a spot on the parachute harness near the shoulder is bad idea. Mine is on the parachute harness and I get around 10% drops, as good as anyone else who mounts their Spot perfectly horizontally. I just checked my spot messages from today: 5 missing messages in 7.5 hours fligh = 10% Since installing on the parachute harness is the easiest, and provide easy access during flight, and will stay with you in case of bailout, I wouldn't recommend against it. Ramy But just don't do that and complain about gaps in your SPOT data. So folks complaining about SPOT problems lets start with where is the SPOT unit mounted and how much sky can it see? And Ramy you have been on here complaining about gaps in your SPOT track in the past. I get less than 10% drops. The next person with slightly more obscuration who's flight happens to track the satellites in just the wrong way may get a lot more. If you don't give them a really good sky view you are going to see gaps in the data. That is your trade-off, just don't be surprised when it happens. Maybe Martin's is mounted with a clear sky view.. who knows. Darryl |
On Jul 17, 10:34*pm, Darryl Ramm wrote: On Jul 17, 9:08*pm, Hellman wrote: On Jul 16, 7:48*am, Steve Koerner wrote: I did a serious investigation on the problem involving some experiments and analysis and I made a presentation to my local club.. My presentation is available for download from my Wing Rigger website:www.wingrigger.com. *(click Extra Soaring Content in lower right corner). Steve, Thanks for that detailed analysis ofSPOTbehavior. While it helps in understandingSPOTgenerally, my question -- and big concern -- is why that flight was different from all other flights. I don't believe I've never had more than a 30 minute gap (2 missed transmissions) before, yet this time the gap was 90 minutes (8 missed transmissions). I was asking if anyone else had a track from that specific day and time (JUL 15, 1900-2020 Z) and general location (roughly from Oakland, CA to Lake Tahoe). If so, I wanted to know if they had coverage or also had around a 90 minute hole in their data. Martin Martin You want to end the guessing game and tell us where yourSPOT messenger is mounted? *On your harness? On your shoulder? Obstructed by your head? What is the effective field of view of the antenna? You were tracking roughly the same heading for all that time. *And that heading (very) roughly lines up with one of the inclined planes of the GlobalStar constellation. The GlobalStar satelites orbit in a interweaved pattern with two inclined planes at +/- 80 degrees or so (you can see a simulation herehttp://www.youtube.com/watch?v=G8VPEueequMoryou can actually play with the SaVi software shown in the video, seehttp://savi.sourceforge.net). It is quite possible that things happen like the satelites flying from the south west to north east are obscured over your left shoudler if say yourSPOTmessenger was to the right side of your head and all those passes could be obscured and maye the next parallel path to the east is too far away. That leaves the satellites tracking north-west to south-east and just maybe again if your head partially obscured those then the satellite does not see thespotuntil it is further overhead and out of the optimal bent-pipe geometry to reach the Alberta, Canada ground station. So maybe in the whole time you just get maybe one shot when theSPOTfires off its track message where it manages to see a satellite to get it a bent path to the Texas ground station. Maybe you just managed to get things timed so bad that you never happened to have a satellite with bent-pipe view to any ground station when yourSPOThappened to fire the TRACK message. This is all very uninteresting if theSPOTmessenger is mounted say on your parachute harness and inclined or significantly obscured. Tell me it is out flat in the open and I'll actually care. Darryl- Hide quoted text - - Show quoted text - I don't think I agree with the notion that mounting aspoton the parachute harness near the shoulder is bad idea. Mine is on the parachute harness and I get around 10% drops, as good as anyone else who mounts theirSpotperfectly horizontally. I just checked myspot messages from today: 5 missing messages in 7.5 hours fligh = 10% Since installing on the parachute harness is the easiest, and provide easy access during flight, and will stay with you in case of bailout, I wouldn't recommend against it. Ramy- Hide quoted text - - Show quoted text - Couple of new feedbacks: 1 - Yesterday (8/9) I had 1 hour gap in messages along the Sierras between Mammoth and Whitney. This was the longest gap I noticed so far, long enough to get my wife concerned. As in Martin's case, there was nothing special about this part of the flight then the rest. I actually had more cloud coverage in other part of the flights then at this section, so this rules out the clouds. My Spot is attached to my parachute at 45 degrees. This is just FYI, not to restart the debate re spot instalation... 2 - The Spot should not be attached to the parachute in the shoulder area in a way that it may interfer with deployment. See important notice from Allen Silver at http://www.silverparachutes.com/file...ce_2009-07.pdf Ramy |
New Pix From Today 7 (Fantastic Sunset) | Canuck[_3_] | Aviation Photos | 0 | April 23rd 09 06:17 AM |
Spot deal, today only, buy service get a free Spot | Tim Taylor | Soaring | 3 | December 1st 08 10:30 PM |
[Fwd: Fantastic Falcon Flick] | Jack[_1_] | Soaring | 11 | October 20th 08 02:46 AM |
i was lighting to line you some of my fantastic magnitudes | Kaye U. Hurley | Piloting | 0 | August 13th 07 10:32 PM |
Fantastic DIY flight sim. | news.ozemail.com.au | Simulators | 0 | May 17th 06 10:25 AM |
