Engine Out Operation
Old July 16th 09, 09:42 PM posted to rec.aviation.rotorcraft,rec.aviation.military
Charles Talleyrand
Default Engine Out Operation
On Jul 16, 4:07*am, Dan wrote:
Charles Talleyrand wrote:
I'm curious. *Can a Blackhawk, Chinook, or other large military
helicopter hover with one engine out? *What is the procedure for one-
engine-out operations for large helicopters? *I assume no one auto
rotates a 30,000 lbs helicopter???
The obvious internet searches didn't help.
-Much Thanks
-Charles Talleyrand
* *H-3,H-53 and H-60 can auto rotate. Watching an H-53 recover from auto
rotation is truly impressive. As far as I know all helicopters can auto
rotate. Every helicopter crew I have been around trains to do so.
* *As for single engine hovering they can do it depending on air density
and load. Above a certain density altitude no helicopter can hover.
* *An empty H-53 or H-60 can take off on a single engine at sea level..
An H-3 can take off on a single engine, but given the choice I'd prefer
number one engine since the other tends to run a tad weak due to the FOD
shield.
If the large helicopters can autorotate, and cannot hover with a
reasonable load on just one engine, why do they have two engines? It
would seem that you would have smaller odds of failure with one large
engine rather than two smaller engines. If you have two engines, and
failure of either leaves you kinda screwed, it is not better to just
have one engine?
Or am I missing something?
-Curious
-Charles Talleyrand
Old July 16th 09, 09:54 PM posted to rec.aviation.rotorcraft,rec.aviation.military
Paul J. Adam[_3_]
In message
Charles Talleyrand writes
Because it's often cheaper & easier to use two engines rather than one
for the power needed - you don't end up with an exaggerated hunchback
from one big turbine & gearbox. (Or three engines, as some types - our
Merlin, the US Sea Stallion - go for.)
Even small helicopters often have two engines, such as our Lynx,
especially if they expect to get shot at.
It
have one engine?
"It's better to lose *an* engine than *the* engine." Not being able to
hover doesn't mean you can't sustain flight: if you're in cruise, you
get a lot of lift from the rotor disc and can stay airborne on a lot
less power than you need for a hover. (Landing may be interesting, but
autorotating or a rolling landing are both options).
On the other hand, with one engine, losing it means autorotating in
*now*.
He thinks too much, such men are dangerous.
Paul J. Adam
Old July 16th 09, 10:37 PM posted to rec.aviation.rotorcraft,rec.aviation.military
JohnO
On Jul 17, 8:54*am, "Paul J. Adam"
In message
Really?
& easier
Really?
Really?
A bit different for the heavies, but light twins such as A109 and
AS355 cost more to purchase, fly and maintain than their single
siblings A119 and AS350, and offer little or no performance benefit
(in fact AS355 has less performance than AS350B3).
In addition to double the engine maintenance, twins have an additional
gearbox element to maintain.
Now you are talking.
It
engine rather than two smaller engines. *If you have two engines, and
have one engine?
*now*.
Yep. That second engine will get you out of enemy territory to a
friendly crash location.
Paul J. Adam
Old July 16th 09, 11:32 PM posted to rec.aviation.rotorcraft,rec.aviation.military
Paul J. Adam[_3_]
In message
JohnO writes
Really?
Yes, if you have two engines each providing half the horsepower compared
to having to develop a new engine. (Changes if there's an off-the-shelf
turbine that puts out the required power, of course)
& easier
Really?
Yes, depending on dimensions and gearing.
Really?
Yes, really.
Absolutely so. Now, how often do they get shot at, flown through
brownouts, and so forth?
The flipside argument - why do light twins like the A109 and AS335 ever
sell, if they're so much more expensive for no apparent benefit?
*now*.
Which is why many of the later UH-1s went twin-engine and so many
military helos like to have more than one powerplant, even if it's less
strictly efficient than a single engine.
Being able to jettison payload and limp home, or at least to pick a
safer spot to come down, can be quite important to the aircrew.
Paul J. Adam
Old July 17th 09, 01:05 AM posted to rec.aviation.rotorcraft,rec.aviation.military
JohnO
On Jul 17, 10:32*am, "Paul J. Adam"
In message
JohnO writes
Really?
No need to develop a new engine. Just use an existing one.
*& easier
Really?
Really?
Yes, really.
Again, I restrict myself to light twins, and if you look at the
examples I gave the bulgy profiles are always on the twins not the
singles. Two small engines always take more space than one large one.
The gearbox for twins is always bigger than for singles due to the
requirement to combine them.
Well it would be very difficult to find any helicopter with a track
record for surviving battle damage than a single engined Huey.
In large part it's due to regulations mandating their use.
I would like to see statistics showing they are any safer than
singles.
*now*.
Which is exacly what I said.
Paul J. Adam
Old July 16th 09, 10:33 PM posted to rec.aviation.rotorcraft,rec.aviation.military
JohnO
-Much Thanks
-Charles Talleyrand
shield.
reasonable load on just one engine, why do they have two engines? *It
have one engine?
-Curious
-Charles Talleyrand- Hide quoted text -
- Show quoted text -
They might not be able to sustain a hover but they are likely to be
able to maintain altitude in level flight.
In other words, the remaining engine will allow them to fly to a more
convenient crash site!
Operation Chastise - Lancaster B1 engine servicing Dave Kearton[_3_] Aviation Photos 14 May 28th 09 02:03 PM
Engine-out procedures and eccentric forces on engine pylons Mxsmanic Piloting 18 May 26th 07 01:03 AM
Saturn V F-1 Engine Testing at F-1 Engine Test Stand 6866986.jpg [email protected] Aviation Photos 1 April 11th 07 04:48 PM
F-1 Engine for the Saturn V S-IC (first) stage depicts the complexity of the engine 6413912.jpg [email protected] Aviation Photos 0 April 9th 07 01:38 PM
1710 allison v-12 engine WWII p 38 engine Holger Stephan Home Built 9 August 21st 03 08:53 AM
