Does anybody know the tolerance or how to properly set the left and
right Cobra surge brake cabling(where the surge brake rod running from front to axle meets the coupling for the left and right cable for each of the brakes). What I found, like most, is that the surge brake can make the wheels freakin' hot on 6% grade AND in my case, is actually responsible for the dangerous trailer sway we see over 60mph(particularly downhill). On a recent trip I just disabled it entirely and it eliminated the sway and the hot hubs altogether...it was like towing my old Komet again. So am contemplating keeping it that way unless I can figure out how to prevent the surge brake cabling from creating this oscillating condition. When disabling the surge I also loose the parking brake, so would like to have that back. TIA, Darren |
On Jul 16, 3:37*pm, db_sonic wrote:
Does anybody know the tolerance or how to properly set the left and right Cobra surge brake cabling(where the surge brake rod running from front to axle meets the coupling for the left and right cable for each of the brakes). What I found, like most, is that the surge brake can make the wheels freakin' hot on 6% grade AND in my case, is actually responsible for the dangerous trailer sway we see over 60mph(particularly downhill). On a recent trip I just disabled it entirely and it eliminated the sway and the hot hubs altogether...it was like towing my old Komet again. *So am contemplating keeping it that way unless I can figure out how to prevent the surge brake cabling from creating this oscillating condition. *When disabling the surge I also loose the parking brake, so would like to have that back. TIA, Darren http://www.cobratrailer.com/Bremsein...englisch_1.pdf From the cobra website Chip F. |
On Jul 16, 12:56*pm, chipsoars wrote:
On Jul 16, 3:37*pm, db_sonic wrote: Does anybody know the tolerance or how to properly set the left and right Cobra surge brake cabling(where the surge brake rod running from front to axle meets the coupling for the left and right cable for each of the brakes). What I found, like most, is that the surge brake can make the wheels freakin' hot on 6% grade AND in my case, is actually responsible for the dangerous trailer sway we see over 60mph(particularly downhill). On a recent trip I just disabled it entirely and it eliminated the sway and the hot hubs altogether...it was like towing my old Komet again. *So am contemplating keeping it that way unless I can figure out how to prevent the surge brake cabling from creating this oscillating condition. *When disabling the surge I also loose the parking brake, so would like to have that back. TIA, Darren http://www.cobratrailer.com/Bremsein...englisch_1.pdf From the cobra website Chip F.- Hide quoted text - - Show quoted text - Thanks, I will try this adjustment to see if I can equalize the surge brake. If not I'll get out the old angle grinder or go electric. |
At 19:37 16 July 2009, db_sonic wrote:
How is the "Oleo" at the tongue? It should have plenty of resistance. Bob Does anybody know the tolerance or how to properly set the left and right Cobra surge brake cabling(where the surge brake rod running from front to axle meets the coupling for the left and right cable for each of the brakes). What I found, like most, is that the surge brake can make the wheels freakin' hot on 6% grade AND in my case, is actually responsible for the dangerous trailer sway we see over 60mph(particularly downhill). On a recent trip I just disabled it entirely and it eliminated the sway and the hot hubs altogether...it was like towing my old Komet again. So am contemplating keeping it that way unless I can figure out how to prevent the surge brake cabling from creating this oscillating condition. When disabling the surge I also loose the parking brake, so would like to have that back. TIA, Darren |
On Jul 16, 2:40*pm, db_sonic wrote:
On Jul 16, 12:56*pm, chipsoars wrote: On Jul 16, 3:37*pm, db_sonic wrote: Does anybody know the tolerance or how to properly set the left and right Cobra surge brake cabling(where the surge brake rod running from front to axle meets the coupling for the left and right cable for each of the brakes). What I found, like most, is that the surge brake can make the wheels freakin' hot on 6% grade AND in my case, is actually responsible for the dangerous trailer sway we see over 60mph(particularly downhill). On a recent trip I just disabled it entirely and it eliminated the sway and the hot hubs altogether...it was like towing my old Komet again. *So am contemplating keeping it that way unless I can figure out how to prevent the surge brake cabling from creating this oscillating condition. *When disabling the surge I also loose the parking brake, so would like to have that back. TIA, Darren http://www.cobratrailer.com/Bremsein...englisch_1.pdf From the cobra website Chip F.- Hide quoted text - - Show quoted text - Thanks, I will try this adjustment to see if I can equalize the surge brake. *If not I'll get out the old angle grinder or go electric. You don't have to give up your parking brake to get rid of the surge brake. Just build a solid clamp that fills the surge gap and that way it will not work, but you can still use the manual lever for the parking brake and use the safety cable as well if you like. |
On Jul 16, 2:15*pm, Robert Gaines
wrote: At 19:37 16 July 2009, db_sonic wrote: *How is the "Oleo" at the tongue? *It should have plenty of resistance. Bob It's been well greased through the zerk fittings and with some effort/ put some weight into it - can be made to move by hand. So you can see it push on a bellcrank that in turn pulls this surge brake rod to enable the brakes like it's meant to. I think in my case it is just the left and right brakes are not equalized. |
Does anybody know the tolerance or how to properly set the left and right Cobra surge brake cabling(where the surge brake rod running from front to axle meets the coupling for the left and right cable for each of the brakes). What I found, like most, is that the surge brake can make the wheels freakin' hot on 6% grade AND in my case, is actually responsible for the dangerous trailer sway we see over 60mph(particularly downhill). On a recent trip I just disabled it entirely and it eliminated the sway and the hot hubs altogether...it was like towing my old Komet again. *So am contemplating keeping it that way unless I can figure out how to prevent the surge brake cabling from creating this oscillating condition. *When disabling the surge I also loose the parking brake, so would like to have that back. TIA, Darren Check the condition of the gas strut in the tongue. If it is pooped, the trailer easily over runs and then adds brake. I had this condition and cured it by replacing the strut. this strut helps modulate the way the brakes come on. Strut should positively push the tongue back out. Good luck Uh |
| Thread Tools | |
| Display Modes | |
| Greasing Al-Ko Surge Brake | rlovinggood | Soaring | 3 | March 17th 09 05:29 AM |
| Hydraulic trailer surge brakes means no parking brake? | [email protected] | Soaring | 11 | March 18th 08 05:19 AM |
| Cobra surge brakes on mountain grades. | [email protected] | Soaring | 12 | May 21st 07 03:15 AM |
| Cobra Brake Parts or Axle | WDM | Soaring | 1 | October 11th 04 06:09 AM |
| Eberle Surge Brake Rebuild | Jim Hendrix | Soaring | 0 | June 18th 04 09:28 PM |
