On Tue, 21 Oct 2003 21:26:48 -0500, "John Stricker"
wrote: I found this web site to be interesting. The guy looks like he did a good job on the conversion for his purposes. I also can't see one item on it that makes any better than the Franklin. He has the overhaul cost at $40,000. For a Franklin? Lot's of guys were working on the Franklin's in Cozy's because they were 3-4 thousand CHEAPER than a 360 Lycoming. The problem, as I understood it, was that parts for the model of Franklin used in the Seabee could not be found anymore. Hence the conversion. You are asking the wrong person your questions, I just posted the link so that people who are interested in auto conversion can have a look at this one. If you really feel you need answers to your questions I suggest you contact the guys who are flying the Seabee conversion. Corky Scott |
Ron Wanttaja wrote:
snip I suspect it probably would have been easier to replace the old 215 Franklin with the new 220 HP model with far less work than it took to convert the Chevy.... Yes, but it would not have been nearly as irritating to Barnyard BOb. He is still around, isn't he? Not that I can tell. -- David Hill david at hillREMOVETHISfamily.org Sautee-Nacoochee, GA, USA filters, they're not just for coffee anymore The following needn't bother to reply, you are filtered: Juan E Jimenez, Barnyard BOb, Larry Smith, John Nada |
On Wed, 22 Oct 2003 22:32:47 GMT, David Hill
wrote: Ron Wanttaja wrote: snip I suspect it probably would have been easier to replace the old 215 Franklin with the new 220 HP model with far less work than it took to convert the Chevy.... Yes, but it would not have been nearly as irritating to Barnyard BOb. Well, like I always say, it depends on what your mission goals are... :-) Ron Wanttaja |
![]() I suspect it probably would have been easier to replace the old 215 Franklin with the new 220 HP model with far less work than it took to convert the Chevy.... Yes, but it would not have been nearly as irritating to Barnyard BOb. He is still around, isn't he? Not that I can tell. -- David Hill Sautee-Nacoochee, GA, USA filters, they're not just for coffee anymore The following needn't bother to reply, you are filtered: Juan E Jimenez, Barnyard BOb, Larry Smith, John Nada ++++++++++++++++++++++++++++++++++ David who? Barnyard BOb -- |
On 22 Oct 2003 05:31 AM, Ron Wanttaja posted the following:
The current Franklin company only supports two engines, a 125 HP four-cylinder and a 220 HP six. The 165 HP Franklin as used in my old Stinson 108-3 was NOT one of the engines produced in Poland or currently supported. We had to jump through many hoops to keep this engine running; I think one of the main rebuilders even reworks auto piston rings for use in the 165 Franklin. According to a SeaBee site, the 'Bee used the 215 HP Franklin 6A8-215- B8F. The Franklin engines site says the current 220 HP is the 6A-350- C1R. Don't know what parts commonality there is, but it's quite possible that they're totally different engines. However, that said, I suspect it probably would have been easier to replace the old 215 Franklin with the new 220 HP model with far less work than it took to convert the Chevy.... Even support for the "current" models is sketchy at the moment. One of the instructors at the A&P school here in Anchorage has the 220hp Franklin in his 172, and can't get the parts he needs to get it working again (he has a cracked case, on a 2nd or 3rd run engine) or even a complete new engine. He's been trying since at least April or May with no success so far. Something to do with the factory in Poland having found more lucrative things to build. ---------------------------------------------------- Del Rawlins- Remove _kills_spammers_ to reply via email. Unofficial Bearhawk FAQ website: http://www.rawlinsbrothers.org/bhfaq/ |
Corky
Remember the messenger always gets shot ![]() Big John You are asking the wrong person your questions, I just posted the link so that people who are interested in auto conversion can have a look at this one. If you really feel you need answers to your questions I suggest you contact the guys who are flying the Seabee conversion. Corky Scott |
I don't have a dog in this fight, yet, so I figured I'd throw mine in.
All this talk of reliability, statistics, redundant systems, engine failure, and dying is the perfect place to put in my 2 cents about using 2 single ignition engines to get a dual everything. Its like the brakes in your car. Brakes are pretty important right? But, you don't pay a zillion dollars for single special purpose super reliable brake system, that you have to have professionally inspected every year. No, you design a cross coupled redundant system that granny can drive and say "It pulls to the left", when one of the 2 circuits fails. Read all about it at: http://inline_twin.tripod.com/concept.html I'm thinking folding props might be better than the CS full feathering type I'm using now in the model. There is a guy that was (still is?) flying a push pull power pod sea plane with a Mazda 13B in back and a Rotax (I think) in front. Talk about mixing and matching. Maybe he was going for that "disimilar" idea you see in voting flight control systems on the big 'uns. |
Jay, have you calculated weight and balance yet?
Corky Scott Ya, thats how the nose got so long. That part is easy with the modeling software. I'm a little concerned because the design will have a very large moment of inertia in pitch and yaw, which on one hand will make it stable, and on the other hand will make spin recovery a challenge. Definitely a XC design. If you're interested, I'll e-mail you the model and you can fly it. BTW, thanks for reposting my message, it got lost in the car brand debate. |
human powered flight | patrick timony | Home Built | 10 | September 16th 03 03:38 AM |
Illusive elastic powered Ornithopter | Mike Hindle | Home Built | 6 | September 15th 03 03:32 PM |
Pre-Rotator Powered by Compressed Air? | nuke | Home Built | 8 | July 30th 03 12:36 PM |
Powered Parachute Plans | MJC | Home Built | 4 | July 15th 03 07:29 PM |
Powered Parachute Plans- correction | Cy Galley | Home Built | 0 | July 11th 03 03:43 AM |
