Great news....
I suggest you replace the internal battery inside the L-Nav. When this gets low the unit will do all sorts of funny things. The L-Nav needs this voltage to retain the proper settings. It's just a watch battery that you can get at most drug stores. Regards, Pat Russette "CQ" Mike Ash wrote: In article , Papa3 wrote: I'm sure an email to Gary Kamerer at Nielsen Kellerman will yield the right answer, but in my experience, this is usually the sign of Bad Things to come. You can start with the Calibrate function and try to get the offset back to zero, by my guess is that you will run out of adjustment. Here's the text from the manual on this: e. [Variometer] This screen shows the Variometer A/D reading. With no lift or sink, the reading should be 511. If is not, you may add or subtract an offset with the UP or DOWN arrow keys. If the offset is more than 40 counts, consider sending your unit to Cambridge over the winter. When this happened to me in the past, it required swapping out of one of the main bits of magic. I'm Jim's partner, and I just wanted to let you know that this was it. I popped into this screen and the offset was set to about -50 and the A/D reading was way down in the 400s somewhere. Bringing the offset back up to 0 got the A/D reading right to the intended 511 mark and the vario subsequently worked just great all day today. We have no idea how it got set to -50 in the first place, but that it works now is the important part. Thank you very much for this suggestion! |
| Thread Tools | |
| Display Modes | |
| Some questions.... | [email protected] | Piloting | 7 | August 14th 06 03:49 AM |
| IPC questions? | Roy Smith | Instrument Flight Rules | 12 | June 1st 04 11:40 AM |
| More KAP 140 questions | News | Instrument Flight Rules | 41 | October 26th 03 07:52 AM |
| Mig-29 questions & general aviation questions 2003 | Steven | Military Aviation | 1 | October 20th 03 07:06 AM |
| Seven Questions For Michael Moore from a Blogger (was Questions for Mr. Bush, from Michael Moore) | Jim Yanik | Military Aviation | 2 | October 9th 03 10:36 PM |
