Veeduber wrote:
Hi Guys. Does that title tickle any memory-bones? Well, let's see if I can tickle them again. First-off come the ground rules: The data came from "Handbook of Instruction for Airplane Designers, Structures Tests" Air Corps, U.S.Army (Not available to the public) ...and apparently not available to many Airplane Designers, too. :-) (Because nobody could remember seeing the thing.) Okay, start with the outline of whatever airfoil you're working with... which tells you right off that this isn't going to be good for ALL airfoils. The airfoil used in the Army manual looks suspicious like the USA-35B, which was used in the Piper Cub... and was the first thing C.G.Taylor tossed on the rubbish heap when he designed the Taylorcraft. However, the Army's test wing was tapered and of aluminum construction. It would be interesting to know the history of this manual since, from all appearances it didn't do the Army Air Corps much good. Using whatever outline you're using, starting at the trailing edge, come forward 10% of the airfoil's chord. The next section takes 43.8% of your airfoil's length. Next comes the main load-bearing section: 27.1% of your airfoil's chord, and finally the leading edge section -- 19.1% of the airfoil's chord. The weight is distributed as follows: 20% is suspended on the leading edge section, 40% is suspended on the mid-wing section, and 40% is suspended on the aft-wing section. You will note that NO LOAD is placed on the trailing edge of the wing. The method is a bit unusual (in my opinion) but it matches the This is where your note stops. I expect you wanted to continue by asking for comments. Coupla thoughts: There's a freebee 2-D airfoil calculator from an MIT instructor which shows the shape of the low pressure on the upper surface, and the high pressure on the lower surface for a whole bunch of airfoils. If you cut these two shapes out of - lets say - lead sheet and weighed vertical strips from top and bottom, you would have a representative load for a particular airfoil station. But the last time I had that code was two or three computers ago.... So, getting down and dirty: Say a wing balances at 30% chord, then if you evenly loaded the front 30% with 70% of the load, and the back 70% with 30% of the load, you balance the turning moment (roughly!) Your USAAC cite puts roughly that proportion before and after the 30% point. So it seems to make sense. True, load distribution varies with AoA yada-yada..... Brian W |
On Jul 25, 7:01*pm, brian whatcott wrote:
Your USAAC cite puts roughly that proportion before and after the 30% point. |
veedubber what do your ribs weigh? | Stealth Pilot[_2_] | Home Built | 11 | January 2nd 09 12:59 AM |
Cooking Airplane Ribs | [email protected] | Home Built | 4 | December 6th 07 09:39 PM |
Cracked ribs | Jack Allison | Piloting | 17 | April 1st 06 09:14 AM |
Cracked ribs | Jack Allison | Owning | 6 | April 1st 06 09:14 AM |
Testing Stick Ribs | Bob Hoover | Home Built | 3 | October 3rd 04 02:30 AM |
