![]() "Mike" nospam @ aol.com wrote in message ... "RST Engineering - JIm" wrote in message ... Given the fact that a 1 watt transmitter on one end and a 1 microvolt receiver on the other end have a maximum theoretical range of 1800 miles, how in the world can you say that a 4 watt transmitter is "limited by power output"? The limitation is always by line of sight or antenna configuration. Since all transceivers of this type are limited by the FCC in regards to how much power they can output(and most of them develop the max power allowed at about 1.5w nominal) 47CFR87.131 gives the maximum power permitted in the VHF com band as 55 watts carrier. WHere do you get your misinformation? and since all of them come with essentially identical omnidirectional antennas, An omnidirectional (isotropic) antenna is an impossibility, although we do some mathematical "tricks" to reference all antenna gain to isotropic. Gain (dbi - decibels above or below isotropic or dbd - decibels above or below a dipole) by definition are 2.14 dB different, the dipole having gain perpendicular to the elements of 2.14 dbi. Tell me what the form factor is for an antenna putting out a radiation pattern resembling a grapefruit? I can pretty much assume they will all have very similar ranges, since obviously the transmitter is going to be the limiting factor seeing as how the other end is putting out roughly 7db more power. Either you have no idea what you are talking about or it is well into beer-thirty for you. So you can use the opportunity to mentally masturbate your "engineering" knowledge and talk about theoretical true parabolic reflectors Who said anything about parabolic reflectors? I used a plain old ground plane at both ends. 2.14 dbi gain. End one. One watt AM carrier power into a ground plane. End two receiver with one microvolt sensitivity for 10 dB S+N/N being fed by an identical ground plane. If you like, you can replace the ground plane antennas with a plain old straignt dipole with no measurable gain or loss. Actual range at 127 MHz. is 1366.7 statute miles. How the hell do you think we talk to the space shuttle with essentially the same equipment a few MHz. higher with 1 watt handhelds? and receiver sensitivities that don't even approach practical applications Every transceiver on the market today will give you at least half a microvolt for 10 dB S+N/N. I was being generous by saying a full microvolt, which will give you a much better s/n ratio. Haven't designed many VHF radios, have you sonny? , but you're not really contributing much to the OP's question. Perhaps. Perhaps not. But at least I knew what the hell I was talking about. Jim |
m... "Mike" nospam @ aol.com wrote in message ... "RST Engineering - JIm" wrote in message ... Given the fact that a 1 watt transmitter on one end and a 1 microvolt receiver on the other end have a maximum theoretical range of 1800 miles, how in the world can you say that a 4 watt transmitter is "limited by power output"? The limitation is always by line of sight or antenna configuration. Since all transceivers of this type are limited by the FCC in regards to how much power they can output(and most of them develop the max power allowed at about 1.5w nominal) 47CFR87.131 gives the maximum power permitted in the VHF com band as 55 watts carrier. WHere do you get your misinformation? Sure, you can transmitt 55 watts. Provided you can find a FCC approved device to do so. Good luck with that. Do you ever wonder why Vertex, Icom, Sporty's, and other handhelds all list their specs as 5w PEP, 1.5w carrier? Do you think they provide such limited power just for sh**s and giggles? and since all of them come with essentially identical omnidirectional antennas, An omnidirectional (isotropic) antenna is an impossibility, although we do some mathematical "tricks" to reference all antenna gain to isotropic. Gain (dbi - decibels above or below isotropic or dbd - decibels above or below a dipole) by definition are 2.14 dB different, the dipole having gain perpendicular to the elements of 2.14 dbi. Tell me what the form factor is for an antenna putting out a radiation pattern resembling a grapefruit? You can skip the bullcrap, Jimmy. All handheld airband transceivers on the market today have essentially identical antennas which are close enough to omnidirectional for this discussion even if it isn't for mental masturbators like yourself. So you can continue to **** on everyone's shoes and try to tell them it's raining if you like, but I've already told you your mental wanking exercise is about as useless to this discussion as man nipples. I can pretty much assume they will all have very similar ranges, since obviously the transmitter is going to be the limiting factor seeing as how the other end is putting out roughly 7db more power. Either you have no idea what you are talking about or it is well into beer-thirty for you. No, I have a very good idea what I'm talking about Jimmy, which is very unfortunate for you since you can't pull your usual trick of trying to baffle everyone with bullcrap. Vertex, Icom, Sporty's and a few other lesser known brands all put out 5w PEP/1.5w carrier according to their specs and all of them have virtually identical antenna designs. The FAA radios put out about 7-9w carrier at the antenna which is pretty close to 7db more power. The FAA receivers are undoubtedly more sensitive than the handheld receivers, but not by 7db, and their squelch is set to around 5 microvolts anyway which is probably going to be pretty close to the handheld. So obviously the most significant range limiting factor is the handheld's transmitter. So you can spew all the crap you want about how I have "no idea", but you haven't offered one iota of anything that is even remotely useful to this discussion and all you're really concerned about is trying to impress yourself with what you think you know. It's the same old grind with you, Jimmy. Nobody on RAP can offer any info on radios because they have "no idea" and you're the only one who does. Then when you're done blowing smoke up everyone's drawers you failed to provide any information that's even remotely useful to the discussion. So you can use the opportunity to mentally masturbate your "engineering" knowledge and talk about theoretical true parabolic reflectors Who said anything about parabolic reflectors? I used a plain old ground plane at both ends. 2.14 dbi gain. End one. One watt AM carrier power into a ground plane. End two receiver with one microvolt sensitivity for 10 dB S+N/N being fed by an identical ground plane. If you like, you can replace the ground plane antennas with a plain old straignt dipole with no measurable gain or loss. Actual range at 127 MHz. is 1366.7 statute miles. How the hell do you think we talk to the space shuttle with essentially the same equipment a few MHz. higher with 1 watt handhelds? I'm pretty sure it's not with a ICOM A14, a Sporty's SP-200, or anything remotely resembling one. So again this begs the question, Jimmy, what value does your mental masturbation exercise bring to the subject line of your post? and receiver sensitivities that don't even approach practical applications Every transceiver on the market today will give you at least half a microvolt for 10 dB S+N/N. I was being generous by saying a full microvolt, which will give you a much better s/n ratio. Haven't designed many VHF radios, have you sonny? , but you're not really contributing much to the OP's question. Perhaps. Perhaps not. But at least I knew what the hell I was talking about. So you managed to impress yourself. Good for you, Jimmy. That's all you're really good for, but I must give you credit. At least you're honest about it. |
Mike wrote:
So you can use the opportunity to mentally masturbate your "engineering" knowledge and talk about theoretical true parabolic reflectors and receiver sensitivities that don't even approach practical applications, but you're not really contributing much to the OP's question. Who *IS* this jerk? Brian W |
Who ****ing cares?
Jim "brian whatcott" wrote in message ... Who *IS* this jerk? Brian W |
![]() "brian whatcott" wrote in message ... Mike wrote: So you can use the opportunity to mentally masturbate your "engineering" knowledge and talk about theoretical true parabolic reflectors and receiver sensitivities that don't even approach practical applications, but you're not really contributing much to the OP's question. Who *IS* this jerk? Brian W He appears to be the same wanna be troll that rode Bertie's coat tails for months. He's just trying to spread hate and discontent. |
![]() "Mike" nospam @ aol.com wrote in message ... I had a Vertex that failed completely after about 5 years. I now have the Icom A4 and I like it just fine. A sample size of 1 tells us little. I have owned 2 Vertex aviation portables over the last decade or so with zero problems. (Yes, a sample size of 2 also tells us little) In my experience (too many years in the 2-way radio biz) Vertex and Icom are the "Honda and Toyota" of that market. You are unlikely to go wrong with either brand.. I wouldn't give you a dime for the difference between the two. Vaughn |
"Mike" nospam @ aol.com demonstrates his rudeness:
I got a really good chuckle out of that one, Jimmy boy. Nice dodge, but I'm really going to have to send the BS flag up on that one. Both Vertex and Icom produce amateur radios that are virtually identical in size to their airband models and some use the exact same batteries. Many models have multiple power settings depending on how much battery life you want, and almost all of them produce more power than their airband models. And they all generate this power when transmitting FM, not AM. FM is measured by the constant transmitted power. AM is measured by the carrier power, which is 1/4 of the peak envelope power, but the device still needs to be able to generate that peak power. Thus, the FM units produce more power. Oh yeah, I almost forgot to mention that many of them are also at least half the price of the airband models. Put a stamp on it that says airplane, and get all the governmental approvals, and it costs more. I mean, after all, 1w will go "1366.7 statute miles", so it's kind of a head scratcher that the FAA reuses the same enroute frequencies every 600 miles or so, no? Well, at least for you maybe. Perhaps you had not heard that the earth is approximately spherical, not flat. Alan |
Alan, I had forgotten the old maxim about not mud wrestling with pigs. Both
of you get dirty and the pig likes it. Thanks, Jim "Alan" wrote in message ... Perhaps you had not heard that the earth is approximately spherical, not flat. Alan |
Alan wrote:
"Mike" nospam @ aol.com demonstrates his rudeness: /snip/ Alan You can say THAT again! Brian W |
Blue Angels back in Pensacola - practice session - Diamond heading back to the hangar | Pensacola Beachcomber | Aviation Photos | 0 | March 23rd 08 04:28 PM |
Did VHF transceiver need TSO certificate? | [email protected] | Home Built | 13 | March 31st 07 06:27 PM |
FS: Val Com 760 TSO Transceiver | aieo | Aviation Marketplace | 8 | January 25th 07 04:38 PM |
FA: 760ch transceiver | EOC | Aviation Marketplace | 0 | July 27th 05 08:23 PM |
Transceiver | BoDEAN | Products | 0 | April 7th 04 06:08 AM |
