Did VHF transceiver need TSO certificate?
Old March 27th 07, 02:40 PM posted to rec.aviation.homebuilt
Default Did VHF transceiver need TSO certificate?
Gentleman,
We want to know whether VHF transceiver in ultralight aircraft need
TSO certificate. Is there non TSO VHF transceiver which was used in
ultralight aircrafts?
Thanks for all.
Luo
Old March 28th 07, 10:33 AM posted to rec.aviation.homebuilt
User
A VHF radio only needs to be TSO'd if the aircraft is registered in the
IFR category. Thanks Michael
Gentleman,
Thanks for all.
Luo
Old March 28th 07, 05:05 PM posted to rec.aviation.homebuilt
RST Engineering
That is NOT true.
"user" wrote in message
Old March 28th 07, 06:06 PM posted to rec.aviation.homebuilt
Gig 601XL Builder
Your right in the US Jim and that is probably where the OP was asking from
but look at the address of "user." He is in the land down under. Maybe they
do have to be TSO'd there.
RST Engineering wrote:
That is NOT true.
the IFR category. Thanks Michael
Old March 29th 07, 04:50 PM posted to rec.aviation.homebuilt
Ron Natalie
It would have to be, as there is no such thing as "IFR Category" here
(but there is on Oz).
Old March 29th 07, 05:01 PM posted to rec.aviation.homebuilt
Gig 601XL Builder
asking from but look at the address of "user." He is in the land
down under. Maybe they do have to be TSO'd there.
Very true and sort of confusing when it comes to homebuilts. I can't quite
understand the reasoning behinde the fact that "I" can install any NAV/COM
in my plane including one I built myself if I so desired and shoot IFR
approches in IMC but can't use a brand new 430W that "I" install to shoot
GPS IFR approches but can use the same 430W to shoot ILS approches.
Old March 30th 07, 07:48 AM posted to rec.aviation.homebuilt
On Mar 27, 5:40 am, wrote:
Gentleman,
Thanks for all.
Luo
TSO is only required for part 135 operation (comercial) in the US. For
example, the KX-170B that was the main NAV/COM used for many years, is
not TSO'd. The KX-175 is the TSO version of it.
Bud
FS: Val Com 760 TSO Transceiver aieo Aviation Marketplace 8 January 25th 07 05:38 PM
FA: 760ch transceiver EOC Aviation Marketplace 0 July 27th 05 09:23 PM
CFI's who use a transceiver or handheld GPS? BoDEAN Piloting 10 April 9th 04 04:03 AM
Transceiver BoDEAN Products 0 April 7th 04 07:08 AM
WANTED: KX-99 Transceiver Scott Soaring 0 January 8th 04 08:04 AM
