On pre-flight inspections
Old July 28th 09, 05:48 AM posted to rec.aviation.piloting
Dave Doe
Default On pre-flight inspections
In article , lefty133
@bellsouth.net says...
"vaughn" wrote in message
"a" wrote in message
I did watch a PA28 do turns around a tiedown once because the PIC
didn't untie the left wing before trying to taxi out.
I once watched a rental 172 return from an apparently uneventful flight
with the rudder lock still attached to the rudder. Take-home lesson: Some
folks fly flat-footed.
Also, at least twice I have ran down and stopped planes on the taxiway
with flags flying from left-on pitot covers. Take-home lesson: One good
reason to put flags on them is so someone else can save your bacon after
you do a crappy preflight.
Vaughn
I nearly started an engine with a propeller lock still in place--and was
fortunate enough to have someone wave my down in time. Due to lucky timing
and the good samaritan, there was no damage.
How on earth did your pre-flight (spin the prop over?) not catch that
one!
Duncan
Old July 28th 09, 06:59 AM posted to rec.aviation.piloting
Franklin[_7_]
Vaughn
one!
It is obvious that Vaughn is very inexperienced.
Old July 28th 09, 02:32 PM posted to rec.aviation.piloting
Peter Dohm
"Dave Doe" wrote in message
Some
good
after
Vaughn
timing
one!
Duncan
It was a bit more than 25 years ago and I've forgotten the bit of trivia
that led to the error, other than the fact that I was only there to exercise
the engine and not to fly; but it was also a good illustration of why
maintenance operations need the same attention to detail and safety as
flight operations.
The cowling shape of the particular aircraft allowed a cable type lock to
remain partially hidden from view, when seated in the left front, and my
solution was to add a bright yellow wrapping with tassels--so that any
repetition would be obvious from inside the cabin and also nearly impossible
to forget on the walkaround.
Peter
annual inspections [email protected] Soaring 1 October 20th 07 01:08 AM
100 Hour Inspections Judah Piloting 26 December 1st 06 02:30 PM
Homebuilt Inspections john smith Home Built 8 December 25th 04 02:20 PM
Time Measurement for Inspections O. Sami Saydjari Owning 15 April 7th 04 05:26 AM
Pre-buy inspections Paul Folbrecht Owning 12 March 1st 04 12:27 AM
