Franklin "Franklin wrote: On Mon, 27 Jul 2009 14:25:04 -0700, Ron Garret wrote: In article , "Peter Dohm" wrote: "vaughn" wrote in message ... "a" wrote in message ... I did watch a PA28 do turns around a tiedown once because the PIC didn't untie the left wing before trying to taxi out. I once watched a rental 172 return from an apparently uneventful flight with the rudder lock still attached to the rudder. Take-home lesson: Some folks fly flat-footed. Also, at least twice I have ran down and stopped planes on the taxiway with flags flying from left-on pitot covers. Take-home lesson: One good reason to put flags on them is so someone else can save your bacon after you do a crappy preflight. Vaughn I nearly started an engine with a propeller lock still in place--and was fortunate enough to have someone wave my down in time. Due to lucky timing and the good samaritan, there was no damage. Heh, funny you should mention that. I once forgot to remove an orange cone that the FBO had "helpfully" placed in front of the prop. It's amazing what a propeller -- even one not moving at full speed -- can do to an orange cone. That one set me back quite a bit as well. rg Are cones expensive or are your poor? Franklin Cones are cheap, but engine rebuilds after a prop strike aren't. (I was, of course, referring not to money, but to the time it took to consult with a mechanic to convince myself that a rebuild would not be necessary.) rg |
On Mon, 27 Jul 2009 23:09:30 -0700, Ron Garret wrote:
In article , Franklin "Franklin wrote: On Mon, 27 Jul 2009 14:25:04 -0700, Ron Garret wrote: In article , "Peter Dohm" wrote: "vaughn" wrote in message ... "a" wrote in message ... I did watch a PA28 do turns around a tiedown once because the PIC didn't untie the left wing before trying to taxi out. I once watched a rental 172 return from an apparently uneventful flight with the rudder lock still attached to the rudder. Take-home lesson: Some folks fly flat-footed. Also, at least twice I have ran down and stopped planes on the taxiway with flags flying from left-on pitot covers. Take-home lesson: One good reason to put flags on them is so someone else can save your bacon after you do a crappy preflight. Vaughn I nearly started an engine with a propeller lock still in place--and was fortunate enough to have someone wave my down in time. Due to lucky timing and the good samaritan, there was no damage. Heh, funny you should mention that. I once forgot to remove an orange cone that the FBO had "helpfully" placed in front of the prop. It's amazing what a propeller -- even one not moving at full speed -- can do to an orange cone. That one set me back quite a bit as well. rg Are cones expensive or are your poor? Franklin Cones are cheap, but engine rebuilds after a prop strike aren't. (I was, of course, referring not to money, but to the time it took to consult with a mechanic to convince myself that a rebuild would not be necessary.) rg Please be more clear for the beginners next time. Franklin |
"Franklin " "Franklin wrote in message
... On Mon, 27 Jul 2009 23:09:30 -0700, Ron Garret wrote: In article , Franklin "Franklin wrote: On Mon, 27 Jul 2009 14:25:04 -0700, Ron Garret wrote: In article , "Peter Dohm" wrote: "vaughn" wrote in message ... "a" wrote in message ... I did watch a PA28 do turns around a tiedown once because the PIC didn't untie the left wing before trying to taxi out. I once watched a rental 172 return from an apparently uneventful flight with the rudder lock still attached to the rudder. Take-home lesson: Some folks fly flat-footed. Also, at least twice I have ran down and stopped planes on the taxiway with flags flying from left-on pitot covers. Take-home lesson: One good reason to put flags on them is so someone else can save your bacon after you do a crappy preflight. Vaughn I nearly started an engine with a propeller lock still in place--and was fortunate enough to have someone wave my down in time. Due to lucky timing and the good samaritan, there was no damage. Heh, funny you should mention that. I once forgot to remove an orange cone that the FBO had "helpfully" placed in front of the prop. It's amazing what a propeller -- even one not moving at full speed -- can do to an orange cone. That one set me back quite a bit as well. rg Are cones expensive or are your poor? Franklin Cones are cheap, but engine rebuilds after a prop strike aren't. (I was, of course, referring not to money, but to the time it took to consult with a mechanic to convince myself that a rebuild would not be necessary.) rg Please be more clear for the beginners next time. Franklin It was sufficiently clear to the rest. |
On Tue, 28 Jul 2009 18:29:14 -0400, Peter Dohm wrote:
"Franklin " "Franklin wrote in message ... On Mon, 27 Jul 2009 23:09:30 -0700, Ron Garret wrote: In article , Franklin "Franklin wrote: On Mon, 27 Jul 2009 14:25:04 -0700, Ron Garret wrote: In article , "Peter Dohm" wrote: "vaughn" wrote in message ... "a" wrote in message ... I did watch a PA28 do turns around a tiedown once because the PIC didn't untie the left wing before trying to taxi out. I once watched a rental 172 return from an apparently uneventful flight with the rudder lock still attached to the rudder. Take-home lesson: Some folks fly flat-footed. Also, at least twice I have ran down and stopped planes on the taxiway with flags flying from left-on pitot covers. Take-home lesson: One good reason to put flags on them is so someone else can save your bacon after you do a crappy preflight. Vaughn I nearly started an engine with a propeller lock still in place--and was fortunate enough to have someone wave my down in time. Due to lucky timing and the good samaritan, there was no damage. Heh, funny you should mention that. I once forgot to remove an orange cone that the FBO had "helpfully" placed in front of the prop. It's amazing what a propeller -- even one not moving at full speed -- can do to an orange cone. That one set me back quite a bit as well. rg Are cones expensive or are your poor? Franklin Cones are cheap, but engine rebuilds after a prop strike aren't. (I was, of course, referring not to money, but to the time it took to consult with a mechanic to convince myself that a rebuild would not be necessary.) rg Please be more clear for the beginners next time. Franklin It was sufficiently clear to the rest. Which has nothing to do with my remark. Troll on. Franklin |
annual inspections | [email protected] | Soaring | 1 | October 20th 07 01:08 AM |
100 Hour Inspections | Judah | Piloting | 26 | December 1st 06 02:30 PM |
Homebuilt Inspections | john smith | Home Built | 8 | December 25th 04 02:20 PM |
Time Measurement for Inspections | O. Sami Saydjari | Owning | 15 | April 7th 04 05:26 AM |
Pre-buy inspections | Paul Folbrecht | Owning | 12 | March 1st 04 12:27 AM |
